Question about Garden
My Husqvarna 22HP 46" cut lawn tractor will not start. It was working fine until it was pulled up on ramps to have deck cleaned underneath and then it would not even start to back it off the ramps. Please help! Thanks
  • 86 Answers
Sounds like a saftey switch ,first check to see if everything is set in right place such as deck is turned off transmission is in neutrel brake set.If these are in place you could have knocked off your wires to safety switch on deck (some tractors you have to sit on to start,does the engine turn over ?
Posted on May 09, 2009
Mowing lower on right side than the left
Loosen the adjuster on one side of the deck and level off the deck and retighten. This should be done on top of a solid surface so u get it perfectly parallel to the ground.
Aug 30, 2015 | Husqvarna YTH22V46 46" 22HP Lawn Tractor...
I have an 2004 husqvarna yth2148 that starts fine. when i take my foot off the break/clutch it shuts off. i checked the sensor under th eseat and its fine. what could be the problem
all the safety switches tie into a central relay which keeps you from spinning the deck and/or starting the engine unless everything is copacetic. start by replacing that relay as it sounds like you have a problem at that point.
Aug 07, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
MOWING DECK WILL NOT "TURN
A wiring diagram and a test light are needed. If you don't have the wiring diagram, use a test light, start at the clutch and work your way back checking for current at each switch/connector. It maybe the ignition switch, there should be one terminal on it that feeds 12v to the clutch curcuit.
could be your ignition switch but thats the best way to find out where its not getting power to.
May 28, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
I have a husqvarna YTH150 hydrostatic kohler motor 1995-1999 upon starting it takes many tries then when started its like its on a steady idle it'll idle high then low in a steady rotation until it cuts...
Sounds like fuel starvation, clean the fuel filter and lines, make sure there's no muck in the fuel tank. It's also possible the choke is sticking, although the exhaust would smoke and smell of petrol (gasoline).
Aug 20, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How do I install a mulching Kit on my Husqvarna riding lawn mower?
having trouble with mulching unit on 22hp tractor.Mulching kit installed by dealer at time of purchase.What is happening is grass is kicking up on the top of the mowing unit,covering the belts and everything else.I need to do a major cleaning every time I use the tractor.Any one got some solution.
Apr 09, 2010 | Husqvarna 22 Hp 46" Deck Yard Tractor
Drive belt diagram
go to sears.com and put in model# for parts look up and they will have it or call 1-800-4my home to get owner manual
Apr 30, 2009 | Husqvarna 22 Hp 46" Deck Yard Tractor
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
