Question about HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive
Noise from computer
Whenever I start the computer, a noise that sounds like a fan spinning comes from under the keyboard. It is very annoying and continues whenever the computer is in use. I reinstalled Windows to no avail. It much be a hardware malfunction. Any suggestions? Thanks.
  • s_whelan May 09, 2009
    Thanks, I have a HP Pavilionzv6000. The noise started a month or so ago for no apparant reason. The keyboard really heats up too so I don't think the fan is working.I tries your suggestions and did not notica any difference in the noise.
    President:
  • 1,884 Answers
It could very well be the noisy fan. Try tapping the computer lightly to see if the noise stops or changes to confirm if it indeed is the fan. Or it could be a noisy HDD.  There is nothing you can do about a noisy HDD but about a noisy fan you can stop worrying as it will cause no probs as long as it is working, noisily or otherwise. You will have to tolerate it. Sometimes it is the detatchable sides of the computer (you wrote 'computer' in your question). See if the noise stops or lessens when you touch the sides a little harder.
Posted on May 09, 2009
My Desktop PC assembled is emitting quite a bit of noise. Whenever an application or a download is started, the cpu usage shoots up and the noise / vibration also increases. What can I do?
I would think the SMPS fan, sounds like it's not keeping your computer cool. CPU fans usually never cause much trouble, but maybe you could look into getting quieter fans.
Mar 17, 2015 | Computers & Internet
Fan making annoying sound
Electro-mechanical fans make noise when wear and tear create sufficient gaps between the mating surfaces to cause vibration or axial movement of the moving part. Fan replacement is the most effective solution, and if you are not a good diy-er send it to a laptop repair shop. You may some tips in the Thinkpads forum where some chaps tinkered with their noisy fans.
Mar 14, 2014 | Lenovo Ibm L3000 G400 15.4" Laptop Lcd...
Good morning. my pc and 'an Alienware Aurora desktop and the problem' in the system fan turns to more 'of 1200 rpm using online games and the noise and' annoying. when the PC happens to all...
Good Day Ilreleonebia!
You should try cleaning all the fans inside your PC once in a while.
Fans, especially in your video card would spin faster whenever you used the video card performance by playing online games that rely on graphics.
It is very normal. What is not is the annoying sounds you are hearing. It should not be. These sounds is cause by dirt accumulating on your blowers and fans. Just clean and the annoying sounds will go away.
Jun 09, 2011 | Alienware PC Systems Alienware Aurora High...
Have a Packard Bell tj65 and whenever i connect the power cable it makes a very loud and annoying noise. Could it be the keyboard?
Hello may be their is something stuck in power supply fan or CPU fan open your pc case and see where the noise coming from i hope it helps. Please rate my comment.
Feb 23, 2011 | Packard Bell (030069) Sound Card
Squeaking noise just started happening. sounds like coming from rear of fridge. very annoying and can't figure out what is causing it. I unplug it, it stops.
There are a few things that can cause fan noise to come from your refrigerator. Check out this tip that I wrote about refrigerator fan noise.
Refrigerator Fan Noise
heatman101
Jan 17, 2011 | Whirlpool Refrigerators
Put new mother board in refrigerator and it sounded like everything was working good but in the morning there was a loud noise in the freezer
sounds like the circulating fan is wearing out, this fan has a dc motor that wears down over time, when it starts the noise it generates is very annoying. What happens is the stator or spinning part of the motor wears down. This fan motor is around $80.00 if you purchase it and replace the motor yoursefl. But the minimum cost to repair/replace this fan assembly labor and parts is around $300.00
Jul 23, 2009 | Refrigerators
Annoying noise from inside my Vaio
I had the same problem with my Vaio, and I called in Sony Support and they called in a technician who came to my house in 2 days! Apparantly Sony got a batch of defective fans and if you are still under warranty they will replace it for free. Good luck!
May 30, 2009 | Sony VAIO VGN-CS110E/W NoteBook
Clicking sound on passanger side of GMC Envoy
The fan assembly moved out of position during impact. Loosen the assembly, and remove for inspection. Sometimes leaves or debris come out of a vent during impact, and lie against the rotating squirrel cage assembly---thus the annoying noise.
Feb 09, 2009 | 1994 Volvo 850
Hello, I have got a problem with my acer aspire 5520, at first it worked well but after about 3 months everytimes I play the warcraft 3 game the fan start rambling and the computer bcomes really laggy, the...
Unplug the computer..take the case off (usually a couple phillips screw on the back) check all your fans , make sure they have good compression and dont just spin freely. clean the heatsincs under the fans with some canned air.--dont forget the fan on the video card if you've added a non integrated video card...then check all the ram and cadd-in cards , make sure they're properly seated in thier spots.
You might fire it up with the case off and try to locate the noisy fan or device... most fans can be replaced..any computer store will carry them.
Keep in mind a fan CAN make annoying noises as it starts to go bad..replace it BEFORE it causes other damage, don't put it off if it sounds bad.
Oct 29, 2008 | Computers & Internet
HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive Logo
131 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
