Question about Sony Playstation 3 (PS3) Console
Sony Surround Sound, LG TV and PS3 connection problems
I have a 47LG5010 LCD TV and a PS3. I bought a Sony DAV-DZ280 Home theatre system and it works, but I can't work out how to get the PS3 to work with it. There is no optical in, and only a HDMI out on the Home Cinema. HELP!
  • aqua_ke May 09, 2009
    Only solution i can see is o buy a new surround sound d'oh!
  • 37 Answers
Sounds like you are going to have to get the component cables for the PS3, you can get them on amazon, the only thing about the component cables is that the quality cant go as high as the HDMI cable but its close. but thats the only way i can tell you to have surround sound with your PS3
Posted on Jul 12, 2009
4 Suggested Answers
SOURCE: ps3 Surround sound
ttttttttttttttttttttttttttttttt
Posted on Dec 29, 2007
  • 7 Answers
SOURCE: no sound from ps3 to home cinema via an optical cable
If you have not run the set up you will need to, however I'm guessing you did because you would have had to make some changes to the settings to get the image to come up on the screen but without being physically at your location I can just guess.
In order to view your PS3 in full 1080p you need the HDMI cable which you already have. If you have not gone into your video settings then you are not viewing via the HDMI cable and you will need to to get things working right.
In order to view via the HDMI cable you would have had to had both the standard PS3 interface cable that comes in the box (the one that goes from the PS3 to your tv with the composite video (yellow) and the left and right audio (red and white) and the HDMI cable pluged into your PS3 and your tv at the same time. then you turn on the PS3 making sure your TV was set to whatever imput the composite and left/right audio is pluged into (typically VIDEO 1,2,3 ect.) and enter the menu, go to the settings and then down to your display settings and change it to HDMI, the image should then leave the screen (because it switched to HDMI) you will need to have your TV remote handy for this because you will need to switch sources on your tv to HDMI 1,2,3 ect, which ever one you have it pluged into. When you have switched to the right HDMI imput there should be an on the screen that is counting down and asking you if you want to accept the changes. Select yes and Move on through the settings selecting the maximum resolution your tv is capeable of
720, 1080i, 1080p) which can be found on the box the tv came in or somewhere on the tv or manual. While running this settings change it should ask you the audio source you are using make sure you select Digital Optical and that it is pluged in to you PS3 and your reciever. Once this is all done you can remeove the standard PS3 hook up that came with the box and put it away you wont need it any more, unless you move the PS3 around and the tv you move it to does not have HDMI in which case you will have to change the settings before you move it back to the standard cable or you will not be able to see it displayed on the tv sceen you move to and it will be impossible to run the settings.
If you have already done that and just want to verify that your source for audio originating from the PS3 is digital optical you can check that in the same settings menu under audio settings. Then make sure the reciver is on and set to whatever imput you have the cable pluged into and you should be good to go.
If all that I have described has been done already then the audio cable could be bad or the problem lies internaly with the PS3 or the reciever.
Good Luck hope this helps
Posted on Oct 04, 2008
  • 11 Answers
SOURCE: PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Posted on Dec 22, 2009
I can't get the tv to have the surround sound work
This effect varies greatly from one set to another, it may only barely perceptible.
Dec 25, 2014 | Sony DAV-TZ140 Home Cinema System Home...
Hissing and Humming when trying to use the speakers for the tv
The sony manual tells you how to connect to a TV however most of us now watch TV connected to a SKY box. The Scart lead needs to be connected to the Sky box for the sound to work correctly. Ignore the Manual and connect the Scart lead from the DVD Unit directly into you're sky box. It works fine.
Apr 04, 2010 | Sony Audio Players & Recorders
No sound from back surround speakers
We just hooked ours up and had the same problem, we switched around the s-air cards and that solved the sound problem immediatly.
Jan 11, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
I have just bought a Sony DAV-dz260 home theatre system. I connected it viz HDMI to my 1080p tv and it works fine. I also have a Sony PS3 connected via HDMI to my TV and this works fine too. I have...
i have the same dav dz260 and all my stuff works on mine. this is how i set it up i have conected y dz to the tv via scart and my sky and ps3 via hdmi cable. to get sound from sky and ps3 i conected a optical cable from the dz260 to the tv and when i want sound for sky or ps3 all i did was change the function on the dz260 to tv and the tv setting to the hdmi im using and hey presto sound hope it helps
Nov 11, 2008 | Televison & Video
I have an LG LCD TV (LG 37LG5000 37IN). I also have an older DVD Home Theatre System (SONY DAV-DZ100). It seems that the surround system works well with DVDs but I cannot get the sound to work with DIGITAL...
It works fine if you plug the surround system SCART lead into the AV2 input. I believe this is a 'smart' scart plug (same as SONY but it is not mentioned as in the literature). The AV1 is only good for inputs NOT outputs as well.
Oct 04, 2008 | Televison & Video
Connection/sound issues!
the best thing to do is if ur lcd has a phono in/out is to connect ur theatre system through phono straight to the tv as then everything that comes up on the tv comes throught the theatre system
Feb 10, 2008 | Sony DAV-IS10 System
Home theatre problems sound
Did you try to connect AUDIO OUT from your TV to AUDIO IN on your package?
Oct 04, 2007 | Sony DAV-C700 System
Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Oct 01, 2007 | Sony DAV-HDX500 System
Sony Playstation 3 (PS3) Console Logo
378 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
