Question about Sony Ericsson P910i Smartphone
Touch system no work correct
Touch system no woking correctly
  • discodiva Nov 27, 2007
    I have the same problem, and the suggested solution was excellent. For a brief moment of sliding some paper between frame and screen I cleared dirt and there was touch screen activity. But then I went too far and ended up wedging a thicker piece of cd inlay sleeve in the corner and now I seem to have made it inactive again.
    But thanks for the suggestion, it made sense. Now I must try remove the frame or correct my mistake.
  • 4,889 Answers
I have heard that this can be caused by something getting caught between the edge of the screen and the frame - perhaps after a cleaning session. If this happens, the screen gets "jammed" because something is constantly pressing it in one location. Have a close look around the 4 sides and remove anything you find. It might work.
There is also a small possbility that this has been caused by a software issue: Switch off the phone, pull out the battery and wait for 5 minutes.
During this period, prayer, chanting - or whatever you are into - may help. But I doubt it ... Let me know if it worked
Posted on Oct 16, 2007
  • eagle338
    eagle338 Oct 17, 2007
    When you describe your problem soooooooo clearly in two words and that in crooked english how can you rate it as not helpful...Anyways try to be more specific with the problem
SOURCE:
Mysql> desc contact_info -> ; --------------
Hi David,
It looks like you're missing two more null's in the third record, the column count is only 21 and you have 23 fields in your destination table.
All your data matches up to the columns, but you'll need to insert ", null, null" before the last paren to cover CompanyURL and companyPhone):
('Karson', 'B', 'Campbell', null, 'Dr.', 'Chief Resident', 'Pediatrics', '[email protected]', null, null, '585-544-1212', 'home', '1955-01-05', 'Wife: Molly Kids: Cassidy, Justine, and Cory.', 'Mountain View Hospital', null, null, null, null, null, null, null, null, null, null )
Sep 06, 2013 | Sun MySQL
Need codes for ht3916 to chage remotes
Description=Durabrand Home Theater System (HT-3916)
Remote.name=URC-6131nwB00 PVR Remote 2K
Remote.signature=PVR0PVR0
DeviceType=Amp
DeviceIndex=3
SetupCode=1568
Protocol=00 5a
Protocol.name=NEC2
ProtocolParms=24 null null
FixedData=01 e7 e7
Function.0.name=Power
Function.0.hex=c7
Function.1.name=Mute
Function.1.hex=e7
Function.2.name=Source
Function.2.hex=d7
Function.3.name=Channels
Function.3.hex=67
Function.4.name=Reset
Function.4.hex=cf
Function.5.name=Front (-)
Function.5.hex=6f
Function.6.name=Front (+)
Function.6.hex=5f
Function.7.name=Center (-)
Function.7.hex=57
Function.8.name=Center (+)
Function.8.hex=df
Function.9.name=Rear (-)
Function.9.hex=47
Function.10.name=Rear (+)
Function.10.hex=ef
Function.11.name=Subwoofer (-)
Function.11.hex=77
Function.12.name=Subwoofer (+)
Function.12.hex=ff
Function.13.name=Master Volume Down
Function.13.hex=4f
Function.14.name=Master Volume Up
Function.14.hex=f7
Button.8=Mute'null'null
Button.3=Power'null'null
Jul 23, 2011 | Durabrand HT-3915 System
The Battery Charge light Turns red and shows no charge on the battery.
This can happen if your battery is older and has gone bad. They only have a limited life. It could also indicate that the battery charging system on the computer is failing. Unfortunately, this means a motherboard replacement.
Also make sure your power adapter is putting out the correct voltage which is ~18-19 volts.
var fctb_tool=null; function FCTB_Init_1cdb0c6e867444a6854f75ea128b0e91(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_5b5e35c2681644fea8f6bdda50b08a4e(t) { fctb_tool=t; start(fctb_tool); }
Feb 07, 2011 | Gateway Computers & Internet
Replaced my Antec True 380S power supply with an Antec SL450 power supply (Antec box with Intel D875PBZ motherboard). I reconnected the new power connectors to the peripherals (correctly, I believe) and...
Thoughts: There are two connections from the power supply to the motherboard. One has 24 pins and the other has 4. Make sure they both are correctly (and fully) inserted.
Try powering the computer on with all the devices disconnected (hard drive, CD, etc).
var fctb_tool=null; function FCTB_Init_15e8cfb4d7a84105bf2a8d1b62aaa04e(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_1c3c34bdb69a4e1f8440979fca0d4587(t) { fctb_tool=t; start(fctb_tool); }
Jan 29, 2011 | Computers & Internet
Letters coming off keyboard
Can't help you much. Suggest you either learn touch-typing or maybe get little white stick-on letters. var fctb_tool=null; function FCTB_Init_a3855d1bf0c4466b98949379cae0685c(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_c4fce50ced7a4e61840aa3099f0fb9cb(t) { fctb_tool=t; start(fctb_tool); }
Dec 29, 2010 | HP Multimedia Cordless Keyboard/Mouse...
I have a wireless keyboard and mouse and I can't type anything I changed the batteries and its acting like it has no power, nothing is working on the key board but the mouse is working. Thanks Tate
1) make sure your batteries are inserted correctly
2) make sure when you insert the USB sending unit into a port that the USB port is working
3) press the connect button on the sending unit and also the connect buttons on the bottom of the keyboard and mouse.
3) make sure in the system setup that USB is enabled.
var fctb_tool=null; function FCTB_Init_7207035e866d4ce295e256df09c8897a(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_9fd4111ba11a4016a30810809c03e786(t) { fctb_tool=t; start(fctb_tool); }
Dec 18, 2010 | Dell Wireless Keyboard Optical Mouse w0147
My computer that has PSW2.0 crashed. It had Windows XP. I have a new HP computer with Windows 7. What do I have to do to make it work on my new computer?
From Singerco.com FAQs: Q. My computer only has USB ports. Can you recommend a Serial (nine pin) to USB converter cable that will work with the Professional Sew Ware™ 2.00a? A. We have found that the PSW works best on newer computers when the USB serial adapter cable has not only compatible drivers for the Windows operating system but also a FTDI chip. We have found this FTDI chip in the cable which is listed below:
CUSB-232A available from Computerplug.com and Cablesalesusa.com.
Any USB to serial adapter with an FTDI chip will work. These cables will work for Windows XP, VISTA, and 7.
Sep 23, 2010 | Singer Professional Sew Ware Options 2.0...
Webpage error details
100% working IDM fake key block problem
http://atips4pc.blogspot.com/2012/02/how-to-solve-idm-fake-key-serial-number.html
Mar 16, 2010 | Microsoft Internet Explorer 8
Open Questions:
Sony Ericsson P910i Smartphone Logo
37 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
