Question about Boating
Intermitent spark #1 i don't know the year the plate is gone it is a 50 hp hydro-electrec drive 50TH ANVERRSY the engin will start when it wants and when it dont it has no spark andi wate a wile bangit around a bit and it starts but i am scared to go on the river this boat used to be my grandpa's boat and meens aloat!!
  • 1 more comment
  • jjslickzz May 09, 2009
    ELECTRONIC NO POINTS DONT KNOW YEAR WOULD NOT START SO I CHECKED SPARK NO SPARK HAD NO SPARK IT IS GETTING FULE SO I YOOK TO FRENDS TO LOOK AT WHEN I GOT THERE THE PICE OF **** STARTED I GOT BACK HOME STILL RUNNING GOOD WHENT TO RIVER PUT BOAT IN WATER PICE OF **** WON'T WONT START!!
    thank u for ur help u rock
  • Jerry Cramer May 11, 2010
    A little more imformation,is there any change in the way it starts when its hot or was there before this happened? newer or older engine ? points or electronic ?
  • 86 Answers
Did you check spark right when it died on the lake ? If so you have a bad electronic module ,If you didnt when you get it started again do this,I have had one or two that had a problem with the on off switch ,but its rare.
Posted on May 09, 2009
1992 geo storm complete loss of power while accelerating now car will not start
Could be fuel pump or something in the ignition system. Have you checked for spark?
Nov 20, 2015 | 1992 Geo Storm
It will not start acts like it not getting any spark
is it just turning over. Take the #1 spark plug wire off and just let it sit about a 1/2 inch from tip of spark plug. don't hold it. have someone turn engine over. this is to see if u r getting spark. your module may be gone.which will let it keep turning over and not start.
Nov 28, 2011 | 1996 Jeep Grand Cherokee
My '99 Eldorado will start-up O.K. and you can
It does sound like some of the engine cylinders are filling up with water (hydro-locking). Head gasket issues are common with these engines. The no.1 cause of it is from not using the coolant pellets suggested by mfr. Green antifreeze is too strong for the aluminum engine and slowly eats away at the gasket seals.
Sep 01, 2011 | 1999 Cadillac Eldorado
My refrigerator stopped cooling/freezing.
You can start with replacing the start capacitor and relay to see if the compressor will run again, but you have about a 50 -50 chance that the compressor has gone bad and will need to be replaced....
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Asker's Testimonial " Very helpful. Will give it a try and let you know outcome. Thanks!!!
Apr 08, 2010 | Maytag 21.6 Cu. Ft. Counter-Depth...
I have a 20 hp craftsman lawn( hydro gear transaxle ) tractor in terrific shape that losses drive on a grade. I replaced the worn drive belt and it was good for the first few mows, Now Im right back to...
It sounds like the oil in transaxle is degraded.The transaxle is supposed to be a sealed unit requiring no service but over time the oil will get dirty enough to cause problems like you are describing.Remove the back hitch plate and look at the transaxle it will have a rubber vent hose or a 1/4 alllen wrench fitting on top. You will need to purchase a battery suction bulb from sears automotive and use it to remove as much oil from transaxle as possible. Warm the transaxle up first by running it around,then suction the oil out.Refill with a good synthetic motor oil 15w-50 or 20w-50 like Amsoil or Mobil 1.Do not use transmission fluid or hydraulic fluid. When adding the new oil back fill it to within 1.5 in from the top,be sure to allow this amount of air space in top of transaxle for expansion.
Jul 15, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Put new drive belt on, but it still does not move
I'm having the same problem, except mine is not hydrostatic. A 1996 craftman tractor 15.5 briggs 42 ' deck. About to start pulling out my hair!!! Just put on a new drive belt and still no movement.
Jun 05, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
91 BUICK REGAL - NO SPARK
The cam sensor is most likely the cause.
The sensor is getting hot and shorting out intermitantly. I would have the vehicle check by your local mechanic.
Mar 27, 2009 | 1991 Buick Regal
Husqvarna 400 e series- I mixed the fuel 40-1 instead of 50-1
Hi
If you have good compression and spark at the spark plug try priming the engine(put some fuel mixture in the spark plug hole),set the carb adjustment(highh speed H=3/4 turn and lowspeed L=1 1/4 turn,turn the scews clockwise until the end and then set them.Try to start the engine.If it runs only the gas you puted inside the cilinder and then stops you have a fuel delivery problem to find and fix.First disassembly ,check and clean the carb.Then the fuel filter and the hoses.Let me know. best regards savumihai71
Feb 07, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Boating Logo
49 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
