Question about Teac DRH300DAB Receiver
Klh model 52 audio receiver
My 30+ year old klh model 52 audio receiver seems to have a bad volume control/off-on switch. The loudness range goes from 0 to 10 and in the lower range (0 to 4 or so) I get a lot of static and either the left or right channel but not both. Above 5 or so the static goes away and I get both channels coming through but then the volume is a bit too loud for normal conversation. I have chatted on-line with the folks at klh and I was told that they no longer support that model, they have no parts and no manuels. Do you think you can help?
    Problem Solver:
  • 20 Answers
Open the receiver and locate the potentiometer for the volume. There should be small openings in which you can spray electrical contact cleaner. The spray can be found at any electronic supply store (Radio Shack). Make sure the product says no or zero residue. I use a product called "Electrosolve". After spraying, immediately rotate the pot back and forth a few times. You may need to repeat this process two or three times. You might as well hit the other controls while you're at it. If several attempts don't eliminate the problem, the pot will need to be replaced.
Posted on Oct 11, 2007
  • 1,175 Answers
I concur with Bruteaudio.
Spray electrical contact cleaner inside the pot innerards and rotate it serveral dozen times.
I use De-Oxit which can be found at Radio Shack too
Posted on Jan 05, 2009
My KLH 5100 System worked fine for nearly a year. Very suddenly the remote control seems to have no effect on the unit. It doesn't switch it on, or off, or change the volume...nothing. I changed the...
Read this procedure to possibly fix the remote:
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Sep 08, 2011 | KLH R5100 Receiver
Mackie 450, signal light off, Sound only comes out when amp. turned up above 75%, when usually used at 40-50%. too loud at 75% and UP, does not Work at ALL below 75%. only 2 years old, with 25 uses... i...
Doesn't sound like a fuse. They don't fix themselves when you reach 75%.
Try shaking the volume knob while in the 30-50% range and/or try (with the power off) rotating the volume knob numerous times from 0% to 100%. If when you plug it back in it responds ANY differently, you might have a bad volume potentiometer. If when you shake the knob you hear static or intermittent sound, you have a bad volume pot.
The only other thing I can think of is that the wiper of the volume pot is not in contact with the windings inside the pot until you reach the 75% mark. When the volume comes on at 75%, does it start off kind of "static" then come in loud and clear? Also try this.... adjust the volume pot to 74% (or when the sound just begins to come on). At this point shake the knob. If you hear static, replace the volume pot.
Unplugging it when still on shouldn't cause any damage... in fact it probably hasn't considering it works at 75% plus.
Mar 14, 2008 | Audio Players & Recorders
Can I hookup a Sony receiver STR-DE505 to a Bassbite 2 KLH Audio system and how??
It's frustrating that KLH manuals seem impossible to find anywhere online BUT a simple picture will suffice...
Go here and supersize the picture of the rear of the sub...
Run your front channel speaker wires to the CLEARLY-MARKED connectors on the sub and daisy-chain your front speakers to the CLEARLY-MARKED connectors on the sub.
Adjust the sub volume to match the front speakers levels. This will give you local volume control at the Sony.
Jun 04, 2011 | KLH BB-II Subwoofer
I have a 22 year old Luxman receiver. The left speakers periodically turn off, but seem to recover if I really turn up the receiver volume. I did just reconnect the speaker wires in an attempt to fix the...
To be honest it sounds as though your volume control needs a clean, try to find some switch cleaner (servisol or similar) remove the casing and spray into the volume control from behind the face plate as apposed to from the front. Rotate the volume all the way back and forth several times to clean the tracks, I have used deodorant in the past to achieve the same result but as this will leave a residue, probably not recommended as a permanent fix. Obviously do these actions with the amp switched off, otherwise you will at the very least annoy your neighbours with the loud volume.
Hope this is helpful.
May 06, 2011 | Audio Players & Recorders
Klh dvc-2500 How can I lower the volume? Setting "1" is too loud. Is there some aftermarket gizmo I can wire into the speaker wires?
Your problem is VERY common. It's defective, get a replacement.
2.0 out of 5 stars Not bad for price $70+$30 S&H, October 20, 2003 By A Customer
This review is from: KLH DVZ-2500 DVD Home Theater System (Electronics) I read alot of the recent reviews before purchasing this system. I wasn't going to buy it because of the volume problem (too loud) but some people said that this could be lowered in the 'audio properties > dynamics' setting.
Sure enough, there is a setting, but it does NOT lower the volume level at all. So, I rang the toll free 888 number and this audio level problem is a defect. However, the dynamic setting is purely to make some sounds softer, not to lower volume. I was told to get a replacement. The replacement is the exact same way ... defective. Buy this system if you only want to hear _DVDs_ with all speakers, because there are no inputs. And the radio, CD is at best stereo,
if you don't mind the fact that it will be too loud, if at any stage you want a normal listening level. I gave 2 stars because I was able to watch a DVD ok with volume level one.
Feb 26, 2011 | KLH DVZ-2500 System
I have a KLH 700watt home theater reciever that wont stay on!!
Sounds like it is overheating. Try one or all of the following:
Remove anything that may be stored on top of it. Unblock the vents.
Connect speakers with a higher sensitivity rating.
Move it to an area where it has more airflow around it, ie; not in a closet or cabinet.
Disable any bass-boost and equalization, or tone controls.
Set any crossover settings for any subwoofer you may have connected, to a higher frequency.
Decrease your listening volume.
Dec 30, 2009 | KLH R7000 Receiver
KLH Receiver Shorting Out
See if you can spot a pattern to the failures. I suspect that it is heat related. In the time that the unit ran all day, I suspect that the volume level was lower. Am I correct? If so, then either there are poor solder connections which are being effected by heat or there is a part that is defective. Are there any other symptoms or does the unit just shut off? If you attempt to turn it on, will it play for a while? If you can solder, look for solder connections that look grainy or have rings and resolder them.
Keep us posted on your progress,
Feb 23, 2009 | KLH R7000 Receiver
Broken volume knob
I located the remote control for the unit and it works fine. As the unit is not the primary amplifier for the home stereo system, I use the remote to control the volume. Thank you for your quick responce, and I will keep you in mind for any future needs.
George Keeler
Dec 31, 2008 | KLH R5100 Receiver
Volume control
Well here goes a spelling problem for me. You need to replace a component called a podentiomiter. It is the actual volume control behind the knob. I have had to replace a few of these, and pioneer seems to to more prone to these problems.
Jan 30, 2008 | KLH KL2400 Tuner
No Analog output
i need to know were did you take your to i need repair on my thank you tray
Feb 07, 2007 | KLH R5100 Receiver
Teac DRH300DAB Receiver Logo
577 people viewed this question
Top Teac Audio Players & Recorders Experts
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
