Question about Frigidaire FRS26KF5C Side by Side Refrigerator
I too have ice on the bottom of my freezer that is seeping out the door.
I know I have to check the freezer defrost drain hole for blockage.  Where is it located on the unit?
  • E3021 Oct 11, 2007
    Frig is side by side.  Do you mean the bottom back cardboard
    cover?
  • E3021 Oct 12, 2007
    Hey!!! I found it.  Thanks so much!! You just saved me 100's of
    dollars for a repair man.
    The blockage was (how do I say this...) the remains of a mouse who met his demise in the drip tray for the freezer defrost.
    Removed inside back panel, poured hot water in the drain hole to melt the ice. Then moved to back of freezer, disconnected the rubber freezer defost drip tube & used my bunn coffee maker spring cleaner to unblock it!!   You are awesome!
I had the same problem - initially couldn't figure out the the rubber tube at the back as there are may plastic tubing for the icemaker etc and my model is FRS25ZRF. The one coming back form the defroster is the black rubber tube about 1/2 inch thick connect to the drain tray below the fan.
Posted on Jun 14, 2008
  • 291 Answers
Take back panel off freezer and will be at the bottom of freezer
Posted on Oct 11, 2007
SOURCE:
Ice in the bottom of the freezer
Check the door gasket for a leak. Air entering past the gasket will form ice.
Sep 23, 2014 | LG LRBN22514ST Bottom Freezer Refrigerator
Why is my Viking refrigerator/bottom freezer leaking water out bottom of door? There is a layer of ice on bottom of freezer.
The ice on the bottom of the freezer is blocking a drain hole. When the freezer defrosts automatically, water drains out the bottom into a tray, where it evaporates away and you never see it under most conditions.
The solution is to either defrost the freezer manually and let the ice melt, or pour some hot water into the bottom of the freezer to thaw out the ice and clear the blockage.
If the drain is plugged because of some foreign matter, either method will make a mess, so have some towels at the ready to sop everything up if need be. If it is blocked, a can of Air Duster (like for cleaning electronics) might be able to blow the blockage out, if you seal the nozzle tube up as it is stuck into the drain.
Most likely it is just ice blockage.
You can access the drain tray (where the water goes to evaporate) by removing the grille on the front bottom of the fridge and peeking / poking around. You might want to keep an eye on it as you defrost the freezer or pour hot water in the bottom - it can over-fill quickly.
Jul 20, 2014 | Viking Refrigerators
Bottom freezer is leaking water. Water seems to
You have a clogged defrost drain. The problem is fixed by unplugging unit from wall, open both doors, blow fan for 24 hours to SAFELY remove the ice covering the drain hole. If you use ANY other method, you may regret it. Once ice is melted, remove debris that is likely blocking the small drain hole, if no debris in drain pan, direct some high pressure air down the drain to block the debris INSIDE the tubing. Furthermore, its a good idea to make the drain hole in the drain pan larger, as sometimes a bubble of water can freeze in the drain hole, and ice could be the cause of your blockage from that bubble.
Jun 28, 2010 | Amana ARB1905C Bottom Freezer Refrigerator
My frost free freezer is icing up on the bottom of the freezer. Occasionally find water on floor No
If the ice is clear and frozen on the floor of the freezer the defrost drain line may be plugged causing the water to over flow the
drain trough and leak into the bottom frezer compartment.
This will require a service tech. to remove the rear panel inside the freezer and find the reason for the blockage of the drain line.
ie....
Mold or slime in drain line
Debirs covering the drain inlet hole
Out of spec defrost heater.
If the ice is fluffly like snow then the freezer door may not be sealing properaly.
With the freezer door closed check the door gasket all the way around the freezer door.
If a gap is seen on one side the freezer door may be misaligned.
To realign freezer door remove all ice with a hair dryer.
Soak up all moisture on the metal rails and inside the freezer.
Pull freezer door all the way out unitll it stops serveral times.
This may realign the freezer door.
If not the door slide rails,Track or Roller gears may need to be replaced.
Jan 15, 2010 | LG Refrigerators
Water seeps out of freezer side of fridg onto the floor, I have totally remover the water line going to the ice maker and it still has water seeping out. It builds up Ice on the bottom of the freezer and...
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 25, 2009 | Magic Chef Refrigerators
Hotpoint csx22d side by side has leak under freezer side @ door...coming from wiring harness that runs up into bottom of freezer maybe??????
This leak , is coming from the defrost drain , inside the freezer section , at the back . The defrost drain is clogged with ice . Remove the bottom freezer crisper , and use a hairdryer to defrost the ice . You will see a drain hole where the defrost water is supposed to drain thru . Hot water helps defrost this hole . Once defrosted , use a small hose inserted into the drain hole , to blow thru , to remove built up debris , inside the unseen drain line .
Sep 16, 2009 | Hotpoint HSS25GFP Side by Side...
The bottom of my lg french door bottom freezer freezer has a layer of ice
Hi, The defrost drain is plugged. UNPLUG the refrigerator. Remove the rear inside panel in the freezer section and locates the drain hole below the evaporator coils. You will have to melt the ice in the drain hole and flush it out with hot water.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 05, 2009 | LG LFD22860 Stainless Steel Bottom Freezer...
Water is draining into my freezer
This water comes from the defrost cycle. The drain hole is probably plugged with food. The drain usually goes to a small pan under the condenser where it eventually evaporates. Look for a hole or slot in the bottom of the unit.
Apr 18, 2009 | Refrigerators
ICE BUILDUP ON BOTTOM OF FREEZER, DRAIN HOLE FROZEN
There is normally a small filiament of metal which is attached to the defrost element and conducts heat down the drainpipe preventing ice build up. You can pour some boiling water onto this area and even wriggle a piece of plastic tubing down the drain pipe to dislodge any blockage. For future prevention, you can attach a piece of copper wire around the defrost element (in the absence of the original filiament) and extend it down the drainpiple
Mar 05, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Maytag side by side freezer leaking water and icing in bottom
Defrost drain system is plugged and not draining out the back and into the drain collector. There is normally an air trap in this drain line under the back and behind a fiber removable panel. Check this trap and make sure it is clear of any blockage. You will then have to defrost the freezer and clear out the ice. Don't forget to replace the back fiber panel.
May 17, 2008 | Freezers
Frigidaire FRS26KF5C Side by Side Refrigerator Logo
187 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
