Question about American Standard Colony 2388.012.222 Linen Two-Piece Round Front Toilet
Standard toilet will not flush
I have a two story colonial that has 2 1/2 baths. On the main floor is the powder room and almost directly above the powder room is the master bath. Both of these toilets are the same as the problem toilet and they both flush properly.
In the second bathroom which is located approximately 15 feet from the master bath is the problem toilet. When I flush the toilet the water in the bowl will rise to the rim approaching over flow and then slowly retreat.
I have replaced the flapper and this has not helped. There is not enough power to syphon a piece of tissue that i placed in the bowl as a test. I welcome your suggestions and greatly appreciate the time you take to answer my questions. Thanks in advance.
The water line of the toilet in question is too high. In otherwords the pipe from which the toilet is getting its fresh water is UPHILL. I am experiencing the same problem and quite by accident saw a house programme with plumbers attending to toilets and saw the problem solved. skirish
Posted on Sep 16, 2009
    President:
  • 1,865 Answers
If this is a new development, then you have a partially clogged drain or maybe a crack in the bowl assembly. If the toilet always did this, then perhaps the drain pipe was not installed correctly.
I would remove the toilet and run a snake through to the main stack. If you find that is clear, check the bowl for cracks and check the tank water level to be sure that the tank is filling to the water line on the tank
Posted on May 09, 2009
What is causing air in my cold water line and how do I fix it?
try running all the water in the whole house at once. all toilets. outside faucets, washing machine, ect...
assuming you have no leaks.
Aug 25, 2014 | Home
What number wax ring do I need?
Most wax rings are standard size. You should pull your toilet off again and scrape off all the old wax. If your toilet flange is below floor level, you may have to use two wax rings, one on top of the other. You can buy rings of different thicknesses, but standard rings should work. When you've placed the rings, place the toilet back on the flange bolts and push down HARD wiggling side to side. When you've got it down as far as you can go, sit on the bowl and wiggle side to side. Repeat this process until the toilet is sitting flush with the floor. NO PENNIES!
or
http://www.homedepot.com/Bath-Toilets-Toilet-Parts-Repair-Wax-Rings/h_d1/N-5yc1vZbl71/R-100139961/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Mar 20, 2011 | Home
American Standard Toilet does not flush except on rare occasions. Most of the time the water just swirls around but doesn't flush out. Waste is left in the toilet but the water does not back up in the bowl...
I would suspect some sort of air lock in the pipe, or just a partial blockage which is slowing the water flow.
You may be able to clear it using a rubber plunger. You need a plunger that has a metal or hard plastic disk fitted above the rubber cup (to prevent the cup turning inside out).
If you have an ordinary plunger without the disk you could probably make one to fit it - perhaps the bottom cut out of a plastic drinks bottle and a hose clip to hold it in place.
You will need to work the plunger quite vigorously up and down in the toilet bowl to force a pulse of water through the system.
Pouring a large bucket full of water down the toilet after plunging may have more impact than just normal flushing. It will also refill the trap.
Feb 25, 2011 | American Standard Colony 2388.012.222...
When adding a new upstairs bath can I connect into stack vent or do I have to add from first floor main
You can connect to the main stack coming from the main floor. You must however install a vent to connect about 42" up inside the wall.
Sep 26, 2010 | American Standard Home
Flush valve closes before toilet flushes completely?
lift off cover and adjust =shorten length= between flapper and handle lever
Apr 26, 2010 | American Standard Colony 2388.012.222...
The toilet will flush but will out not take everything down, then plug up.we have change all the parts in the tank.it like no sucken.
have you tried snaking you lines sounds like theres a problem after the toilet. Toilets dont use suction it all work off gravity
Feb 24, 2010 | American Standard Colony 2388.012.222...
Problem: when I flush my toilet most often the water swirls around and doesn't flush. I've tried bending a coat hanger and snaking it through the exit hole to see if there was an obstruction. Any...
This is a job for a plumber unless you have a ladder. The vent pipe may be plugged or the trap in the toilet may be plugged up but this requires removing the toilet from the floor which is not that hard. two floor bolts and and turn off the water valve and disconnect the water hose then lift the toilet up and see if there is blockage by poring a gallon of water into the drain pipe. if it backs up you need to snake out the main line. You can rent a electric 25 foot snake for 35 bucks but then you have to reinstall everything plus buy a new wax ring which is about 5 bucks. if the pipe is clean and drains fine then you need to run water into the toilet outside to clear the throat of the toilet if there is no blockage then the vent pipe may be plugged and that you have to get from the roof. Best bet is call a plumber.
Jan 05, 2010 | American Standard Colony 2388.012.222...
Leak at base
Replace the wax ring between the toilet and flange in the floor drain. Clean out the wax of the old ring very well.
Oct 11, 2009 | Toto CST414M-11 Aquia Dual Flush Elongated...
American Standard toilet settings screws not adjusted right
sounds like an old tiolet (3.5 gpf) my best answer is to replace with new fluidmaster! (lowes or homedepot) easy fix!
Mar 10, 2009 | American Standard Colony 2388.012.222...
Our Saniflo - Saniplus works fine and efficiently when we flush the toilet, if we use the shower or bath,when emptying the water the flow is not as strong/as much pressure like a toilet flush & the...
Sounds like a restriction in the outlet pipe, the 2 galls from a flush are OK but the bath or shower is more, especiallly if you have flushed before you shower, try drain unblocking chemicals or flushing the outlet pipe with mains water from a hose
Mar 09, 2009 | Saniflo & Saniplus& Macerator Pump
American Standard Colony 2388.012.222 Linen Two-Piece Round Front Toilet Logo
381 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
