Question about Dakota Heating & Cooling
Everdure heater not able to be turned on
We have an everdue heater EC2 25 and we are unable to turn on we think the child safety has been turned dbut am unable to work out how to turn off
Everdure heater will not stay on
Posted on Aug 03, 2009
Should the pilot light remain on on an everdure
Pilot lights are supposed to stay on. That is normal.
Jun 22, 2014 | Vulcan Heating & Cooling
Everdure child lock
press and hold the button for several seconds
Jun 09, 2014 | Heating & Cooling
I have a everdure 6 burner gas heater. its pretty old and works sometimes. the problem is that it take a while to turn on and once it started it just turns its self off with in minutes. this happens...
Your flue-less gas heater may simply need a a good interior cleaning and servicing. From what you described it sounds like the Oxygen Depletion Sensor (ODS) may be clogged with dust, lint etc. The ODS is part of the pilot assembly and constantly reads the oxygen level in the room, when the heater is in use.If the oxygen level drops to 25% the ODS shuts the unit OFF by closing the gas valve. This can occur if the ODS is dirty, because it's falsely reading the oxygen level.
One other thing that can mimic this problem is a faulty Thermocouple. With age, they wear out. It's also a safety feature that controls the gas flow to the pilot.
Everything I have mentioned is repairable. But, if you want to make it a DIY project, it will require some dismantling of the heater cabinet to access everything and replace parts. If the heater is as you say "pretty old", you may want to consider buying a new heater. Sometimes, it's just not worth the time and effort to repair an old heater.
Hope this helped you to troubleshoot and solve the problem.
May 27, 2011 | Heating & Cooling
How do you turn off the child lock on a RinnaiRCE229H natural gas Heater?
Basically hold in the child lock button for two seconds. If the child lock was activated and you then turned the unit offt the child lock remains set and will stop you turning the unit on. To deactivate, make sure you have the power lead pluggeed in and turned on. Before you depress the ON/OFFbutton, hold in the child lock button for two seconds. This will deactivate the child lock and allow you to turn the heater on.
Here is a link to a users manual, check out page 11.
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/installations/150.pdf
Aug 15, 2010 | Heating & Cooling
2002 Lincoln LS Rear door latch does not open have tha panel off tried opening manually mechanism moves but unable to open a child was playing with door lock can you help me to get the door open, would it...
I think the child safety lock is engaged. Look in your owner manual how to disengage. It is near the latch on the edge of the door. Look for the yellow label.
rotate counterclockwise to disengage child lock.
Feb 23, 2010 | 2002 Lincoln LS
I need to service an everdure gas heater
if you can smell gas and have not done something about it by now then you should not be thinking about diy
gas is more dangerous that electricity simply because if you can smell it it is already an explosive mixture
get in a gas fitter and get a quote to fix
Jun 02, 2017 | Heating & Cooling
How to disable child lock
Without knowing the brand of heater I can only guess you must hold down the lock button for a few seconds or two buttons at the same time. get back to us with a make and model number.
Jul 16, 2008 | Heating & Cooling
Heating & Cooling Logo
902 people viewed this question
Top Dakota Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Dakota Heating and Cooling Expert? Answer questions, earn points and help others
