Question about Blitzz Technology BWA711 (B3WL000900) Wireless Router
Accessing through a new computer
I have used this router for a number of years.  I just got a new laptop, and it can see the access, but wants additional logon info.  If I type in "admin" for both user name and password, it doesn't connect because "windows could not automatically detect the correct security setting for this network".  How do I find the correct security settings? Also, there is a field in the logon screen for "logon domain:". Do I need to put something there?  What?
  • kackybird Oct 15, 2007
    When I talked to HP, they said vista has a problem identifying security enabled routers.  Once I reset my router, the pc could access it fine.  Thanks, though!
  • 49 Answers
Is the new laptop xp? or vista?
for these two pc, you can use the built in utility of windows dor wireless conenction. There you will only be asked one information. The wep key/ security key/ passcode/ (they both mean the same anyway) this is available in the User interface of the router . This is sometimes called the set up page, that if you access this page...it will give you all the wireless settings. the best person to contact is your router manufacturer. That is this is still under warranty for free tech support.
Posted on Oct 13, 2007
SOURCE:
I los mi cod to get mi wireless conection
Plug into the router directly using a cable between your computer and the router. Then you can go into the router settings and set a new wireless key. If you need help accessing the router settings read your manual. If you've lost it you can download one from Netgear's site. Use a cable to access the router and turn off the wireless on your computer.
Mar 13, 2011 | NetGear WNR2000 Wireless Router
How can I configure my router so all of my laptops can connect to the internet? Also, do I need to make any changes to my laptops configuration?
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
3676-001.png 3676-002.png Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Linksys Wireless-G Broadband Router
Can't access my linksys on my laptops although I can on my desktop.
Hi ottawakids,
I see that you are having issues accessing your Linksys using your Laptops.
> First Check if the router is detected on the Laptops.
>If the Router is detected and un accessible you ill need to check if there are security settings in the Linksys Router.
>Check if the Linksys has a Network key, or check if the Router MAC address Filtering is turned ON the Router this can also prevent your laptops from accessing the Router.
>If all elsa fails try resetting the Router to defaults and start from scratch maybe some settings are incorrect, setting it to default will fix the issue of the Router not being detected.
I hope this helps.
Have a nice day.
mvincentc
Oct 20, 2010 | Linksys Wireless-G Broadband Router
Cant go to setup for my router 192.168.2.1
you can't access your router IP address? are there any errors? have you connected your computer to your router using ethernet while accessing the router? cause if try accessing your router wireless it will not work this should be done hard wired using an ethernet cable ^_^ also have you tried resetting the router to default by pressing the pinhole on it press it for 5-10 seconds then let go try accessing the router again ^_^
Jun 06, 2010 | Belkin (F5D5231-4) Router
My router is 2 years old and yesterday, i started to get the message saying i am not connected to the network. Does that mean the router is no longer working ?
What is giving you thisw message? If it is on a laptop, accessing router wirelessly, then (on the laptop) go into Network Settings and verify that your computer is set up to use a Private network, as Public networks may not let you see other computers on the network. If it is set to Private, then your router may have stopped working. Try resetting the router by sticking a paper clip into the Reset hole, which resets the router to Factory Settings. Go ahead and connect to the router with a CAT-5 cable and use IE to go go to http://192.168.1.1 and complete setting (simplified) as follows:
In Wireless Section, Choose your SSID (Network Name), set security in the section below that by choosing security method and passcode. This passcode MUST be used by all users to access thev wireless signal. Let me know ( [email protected] ) if this does not help.
Dec 17, 2009 | NetGear RP614 Router
How do i set security on the router and limit the number of computers access to the router.. i think the neighbors are accessing the internet trough it.
Setup the router to use a password. Once you have the security setup on the router it will not be necessary to limit the number of connections though you could limit the number of DHCP addresses it assigns.
Please see page 51 of the users manual for instructions on setting up WEP.
http://cache-www.belkin.com/support/dl/p75555ea_f5d8633-4_man.pdf
Sep 15, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Router installation
THis can be a problem with the wireless settings of your router, I believe your laptop is trying to connect wirelessly to your router, This can be solve by accessing the router setup page and do some changes on its wireless settings settings like the SSID and the most important one the wireless security..If you're not familiar on how to do that I will advcie you to call LInksys tech support so one of their tech can walk your through with that process, they are open 24/7 this is the number 800-3267114.......
Hope that helps.........
Sep 16, 2008 | Linksys Wireless-N WRT150N Router
Netgear wireless router WGT 624v4 not accessing some websites
if the router was the problem, then no site would be accessible from either of the problem pc's.
unless the webkinz site is being blocked because it contains active scripts. check the configuration page for the router (usually 192.168.1.1) and switch off any active firewall / security applications running on the router.
May 30, 2008 | NetGear WGR614 Wireless Router
I have wireless router and my laptop will no longer connect to the internet. The computer says wireless networks are available, but when I try to connect it asks me for my security key or passphrase. It's...
Maybe provide the brand of router.. Anyway, I have lost my details as well, several times over the last couple of years.. It's just a case of accessing the router (via web browser, using the correct IP address for your brand of router).. Then you can delete the existing network & add a complete new one. You get to use a new key & passphrase. If you need further help, please provide your router brand & model. Rgds, dave
May 02, 2008 | Computers & Internet
2 computers, 1 router
Hi britini,
Make sure there is wireless or wifi on your laptop.
Dec 26, 2007 | Belkin (F5D7230-4) Router (587009)
Blitzz Technology BWA711 (B3WL000900) Wireless Router Logo
98 people viewed this question
Top Blitzz Technology Computers & Internet Experts
Hollyecho Montgomery
didi2005
GFXTech
Are you a Blitzz Technology Computer and Internet Expert? Answer questions, earn points and help others
