Question about RCA TruFlat 27F520T 27" TV
RCA 27F520T no picture problem
I was moving this tv in the kids room to install a cable box and it washed pushed a bit too far out to get to the back and fell about 2 feet on its front... the glass didn't break... but my ankle my have. Anyways, When I got it back up I went to turn it on, I could hear the "click on" sound and the power button lit up red, but no picture or sound. As soon as I hit the channel button on the tv itself the power clicked off and the light goes out. It's basically a new set.. any ideas?
  • dizzum Oct 11, 2007
    I opened the back panel and everything is clean and the PCB doesn't seem to be cracked/harmed physically. I was looking for maybe a fuse blown...but I guess they don't have those anymore! ;)
    Genius:
  • 1,694 Answers
 Examine PCB closely,probable cracked board.Depending on
how severe,it may be fixable.Ask repairman what the bench labor
charge will be to repair,if repairable at all.
Posted on Oct 11, 2007
  • Vista Electronics Oct 11, 2007
    Check the condition of each tactil switch on cabinet front.
    Make sure none are pushed in or damaged.Re check PCB
    with magnifier.
SOURCE:
Picture is cutting off parts of images
Very few adjustments except in tech menu which I cannot tell you how to access--danger of killing set if wrong button pushed.
If picture just expanded top/bottom or left/right you may have a circuit problem
Mar 17, 2012 | RCA TruFlat 27F520T 27" TV
I have a TruFlat RCA model # 27F520T have lost original remote and FPA lock is on how do I unlock without original remote? Dish universal remote not working to unlock tv, it will pull up menu but cannot...
Try this -
  1. Press menu for main menu.
  2. Press CH + or CH - to highlight preferences.
  3. Press "OK" to enter preferences submenu.
  4. Press CH + or CH - to high light "FPA"
  5. Press VOL + or VOL - to turn the FPA on or off.
  6. Press MENU repeatedly to exit.
  7. Back to normal
  • FPA stands for Front Panel Lock. It makes it so kids don't push all the buttons on the front of your TV. The power button on the TV will still work and the remote will still function as normal.
Regards, Tony
Apr 30, 2011 | RCA TruFlat 27F520T 27" TV
I moved the tv from one room to the other, and the screen is now mostly green and purple. What happened? How do I fix it?
If you have anything plugged into the t.v. via a scart lead such as a freeview box then check the ends are pushed in properly as this can sometimes cause similar problems.
Jun 03, 2010 | RCA TruFlat 27F520T 27" TV
I need to program my cox cable box remote to my rca tv
the power just wen out and now the cable and tv are back on but the tv says no signa. I have tried the code but nothing. Any advice?
Aug 30, 2009 | RCA TruFlat 27F520T 27" TV
Can't get channels.
You need a converter box on that unit.
Jun 22, 2009 | RCA TruFlat 27F520T 27" TV
The female cable connector on the back of the tv broke off
yes,you could also use RCA cords from the cable box to the tv and bypass that by selecting the video channel that you hook the rca's to
Jun 02, 2009 | RCA TruFlat 27F520T 27" TV
RCA Home Theatre - Tuner problem
you may coldsolder the tuner first before replacing the new one,maybe it can works.
Apr 30, 2008 | RCA TruFlat 27F520T 27" TV
RCA TruFlat 27F520T 27" TV Reset
Buy a new remote.
Look around the tv and find the menu button.
Generally there is a separate power button.
You can also download the manual:
http://tv.manualsonline.com/manuals/mfg/rca/27f520t.html
Dec 02, 2017 | RCA TruFlat 27F520T 27" TV
Unusable signal
Usually need a second receiver. Cannot just split signal. With some cable providers you can split the cable before it hits the cable box for basic cable channels.
Suggest contacting Cable Company if does not work.
Thanks!
Mar 23, 2008 | RCA TruFlat 27F520T 27" TV
RCA color tv,model 27F520T,Chassis M134C
On the tv panel push and hold volume down until volume is all the way down and keep holding, then push the info button on the remote.
Dec 21, 2007 | RCA TruFlat 27F520T 27" TV
RCA TruFlat  27F520T 27" TV Logo
73 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
