Question about LG WM-2277HW Front Load Washer
Mildew smell My machine is only a year old and for 3 months now it has a strong,nasty mildew smell. What do I do to get rid of this problem??? Please help as it is making us sick!!!
  • Donnie Gilbert
    Donnie Gilbert Feb 11, 2012
    If you do all your laundry once a week leave door open to allow it to dry between uses. If you wash loads all during the week you will probably have to keep it open all the time to allow it to dry.
    Problem Solver:
Try doing just a hot bleach water "load".  Also check underneath and around the machine to make sure it's not leaking.  If it did or is and you can see the mildew just spray it with bleach.
Posted on Oct 11, 2007
SOURCE:
Clothes smell after washing cycle
Nice, or not nice?
To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
How to Get Rid of Mold Smell in Front Loader Washing ...
www.wikihow.com > ... > Housekeeping > Cleaning > Laundry Jump to Preventing Smells in Your Front Loading Washing Machine - Part 2 of 2: Preventing Smells in Your Front Loading Washing Machine.
how to get rid of a bad smelling high efficiency washer ...
wholelifestylenutrition.com/.../learn-this-tip-say-goodbye-to-bad-smellin... Learn this tip and say goodbye to bad smelling HE washer machines forever! ... Not only did it smell moldy and musty but my clothes were starting to smell this ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Your Washing Machine Smells, and How to Clean It
laundry.reviewed.com/.../why-your-washing-machine-smells-and-how-t... Add this solution to your machine's detergent container, pour two cups of white vinegar into the drum, and run a normal load at high heat. The baking soda and vinegar should break up any residue stuck to your drum and kill any mold that might be present.
Washing Machine Smell on Pinterest ' Smelly Washing ...
https://www.pinterest.com/explore/washing-machine-smell/ Great tutorial on how to clean your front load washing machine, get rid of mold and mildew and prevent it from returning. I clean mine after every wash (a little ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Does My Washing Machine Smell Like Mildew? - Real ...
www.realsimple.com/home.../cleaning/.../mildew-smell-washing-machine To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
Jan 09, 2016 | Washing Machines
Washing machine smells like mould
The odor may come from several sources. Mildew may be around the door's gasket. That might be cleaned with a rag and a half bleach/half water concoction. The soap dispenser tray may have had stagnant water present. Other hose areas may be growing mildew.
Here are some things you can try:
1) Run dishwasher powder detergent once a month through the washer. Or...
2) Run 3 quarters cup of bleach through an empty hot wash cycle once a month.
3) Yes, baking soda, ye olde oder absorber, can also be tried.
3) Clean the trap (where coins, etc. may be captured). Clean the filter.
Some High Efficiency machines have "high efficiency, HE detergents recommended for them. Does the drum have a soapy coating? If so, it will likely require at least an empty hot water cycle to get rid of the excess soap which may be responsible for the smell.
Naturally, if you are using bleach to clean the the washer door, you want to clean the bleach off too before you ruin some clothes by contact.
Hope this helps.
Aug 04, 2015 | Washing Machines
Mildew odor in the machine....can't get rid of it and makes clothes STINK!
If you have a smelly front loading clothes washing machine, toss in a Finish Geltabs (the ones that are all liquid) and run the machine on a hot wash cycle, medium to heavy load (to get more water in the tub) with no clothes in the machine. You don't need to use much of a spin cycle so set it on low. The washing machine will come clean and even the moldy spots on the rubber gaskets will disappear. A second treatment may be needed if the smell is not completely gone. We tried everything from vineger to bleach to baking soda to borax to commercially available odor removers from Whirlpool and Tide. Nothing worked until I hit on this idea. It's cheap, easy and can be done anytime your machine needs a refreshing. I used the orange Geltabs but any fragrance would be fine. Keep the door on your washer open a bit when possible to air out to help preclude those nasty smells.
Oct 21, 2012 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
I have the smeel of old grass coming from my washer, probably from my yard work jeans. How can I get rid of this smell? Is there a filter I can change?
All you can do is clean the rubber door boot inside and out and in all the folds with a strong bleach solution and then run an empty load with a a few cups of bleach in it, then always leave the door open after your finished the laundry, there is probably mold and mildew inside the tub between the spin basket and tub and you cant get to it. various products for mold and mildew may help
Aug 25, 2011 | Whirlpool WFW9050X Washer
My washing mchine has a mildew odour all the time for last month, its a year old WHY? please
this smell is caused by mold and mildew that has formed on the upper part of the outer drum -- the main cause of this is the suds in the wash tend to rise above the normal water line and never get rinsed away properly. so to get rid of the smell --- run a empty load of hot water ( hot/hot ) and when the cycle starts - add to the water 1/2 cup of white vineger and 1/2 cup of bleach, also add ( using a small container ) some more hot water to the machine to bring the water level up to a higher then normal height,,, let the machine complete the full wash cycle. now if the smell is still kinda there -- repeat the whole cleaning thing one more time,,, this should remove all traces of mold and mildew that has built up and you should notice a huge difference. to keep this from happening again,, try not to use so much detergent in the wash and after you wash your clothes - leave the lid wedged open slightly to let air into the unit so moisture can escape,, this will prevent mold from growing because the machine will dry out fully.
now at least once a month do this cleaning with the vinegar and bleach and you will never have this problem again.
c...
Feb 04, 2011 | Washing Machines
How do I get rid of mildew smell in Siemens UltraSense front-load
Siemens
WFXD8400UC Front Load Washer
This video will show you how to change the door seal gasket on your washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 17, 2010 | Siemens WFXD8400UC Front Load Washer
Strong mildew smell in washer is making cloths & towels smell bad, how do you get rid of the problem?
if you look inside washer there is a rubber rim on the inside around the openning. Look inside and you will find where the stink is coming from. Keep door open when not in use and wipe inside of rubber trim to keep the mildew out.
I use tilex sometimes and do a rinse spin.
Nov 16, 2009 | Kenmore Elite 45986 Front Load Washer
Strong plastic smell and taste on a new Keurig Platnum coffee mak
I had the same problem and I discovered that after running 3 resevoirs full of water through the machine at 192 degrees , it got rid of the plastic smell. Set the cup size at the largest size mug and then just open the lid and close it , hit brew and let it fill the cup. Dump the water in the sink and repeat until you go through at least 3 resevoirs. The smell should be gone by then.
Sep 13, 2009 | Keurig B70 Coffee Maker
Strong mildew smell coming from washer
Try running a cup of white vinegar thru a wash cycle w/o clothes.
Jan 28, 2009 | Maytag LAT2301AAE
Strong meldew smell from washer
Please take a look at the following link and see if you are following all the steps. Front Loaders are notorious for smelling this way , but there are things you can do to minimize the problem. I have owned a front loader for 8 years now and have never had a problem by following this advice.
http://www.fixya.com/support/r513372-front_loader_mildew_odor
May 16, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM-2277HW Front Load Washer Logo
311 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
