Question about Hotpoint Aquarius WF000 Front Load Washer
The machine when it is on a cycle sticks on the rinse spin
I have a problem with my washer Hotpint WF440, when on a cycle it sticks on the rinse spin
    Sergeant:
  • 175 Answers
Hi..most likely the timer switch which might have got
into trouble,this controls all the different cycles.
check it out..
thank u..
kindly rate my response..
Posted on May 09, 2009
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Brand new Bravos. Why doesn't it do the final spin?
NO ITS NOT UR DOOR SWITCH IF IT WAS IT WOULDNT SPIN ON ANY CYCLE. I SUSPECT U HAVE A TIMER THAT IS STICKING AND THE POINTS HAVE BURNED OR SEIZED
May 26, 2015 | Maytag Washing Machines
Why is the machine Not rinsing and spinning?
something is blocking it from draining so it wont spin and it wont rinse because it wont spin
Jun 10, 2014 | Brandt WFH1176 Front Load Washer
Washer won t fill water
pipes maybe clear but is your area wher you live prone to limescaling? where the water pipe/pipes go into the machine there is a switch to shut on/off the flow of water during whatever cycle you want.this might be blocked or sticking. first try to select different cycles and see if any of those fills the machine with water. if no water comes its one of two things. that switch is faulty or communication between the switch and the front consule is at fault.
contact your supplier after trying to go thru a few different cycles.
Dec 04, 2013 | Frigidaire Washing Machines
Washing machine not rinsing and spinning wf440
I would suggest that you check and clean the pump filter.
This is to be found by removing the lower panel of washer, then remove the large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 26, 2010 | Hotpoint WF430 Front Load Washer
Wash machine stays on wash cycle and doesnt go to rinse or spin
If the water is not getting hot, this will probably stop the programme advancing .Check heater.
Plz rate solution to prob.
Dec 10, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Lg washing machine wft855a top loader
Following up my comment from yesterday, I took the machine apart and discovered that the black rubber cover on the valve that releases the cold water had perished and cracked, and wasn't opening properly.
I tested the hot and cold solenoids and everything checked out ok. Was just the cold valve sticking.
The wash cycle was working because I was using hot/warm water. As the rinse cycle needs cold water to get started, it was not working and the rinse and spin cycles wouldn't complete.
I have swapped the valves over for now (put the working hot one on the cold side and am using cold water only). It's working while I order a replacement...
Sep 07, 2007 | LG WFT1071TP Top Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
234 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
