Question about Nokia 2626 Mobile Phone
Mobile gets switch off while pressing go to key
My nokia 2626 mobile gets hanged off when i press the go to key
  • 42 Answers
Flash with latest flash file it min's software fault
Posted on Mar 06, 2010
My nokia 2626 mobile phone is hanged . so please tell me how to install software , so that i can use it properly.
You can use memory up full edition. It can be found in mobiles24.com. It helps your phone boost its RAM memory to prevent hanging. If it doesn't work, it means that your phone has a threat. I hope it can help you.
Jul 17, 2011 | Nokia 2626 Mobile Phone
My phone get hang frequently
this is a genral problem in nokia n series phone.the only solution exist now a days to overcome this problem is to format the phone
How to Format Nokia N72, N73, N81, N95, NSeries Mobile Phones. Method 1: Three Finger Reset for Nokia Phone
1. Switch off your Nokia phone.
2. Hold down the following three keys, Green (call answer button) * Key, and Number '3? key.
3. While holding these buttons, press the power button and switch on the phone.
4. Wait for message 'Formatting' to appear on the screen and release all keys once you see that message.
Method 2: Hard Format of Nokia Mobile Phone
2. Now Press following key sequence *#7370#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message 'Formatting' to appear on the screen and release all keys once you see that message.
Method 3: Soft Reset of Nokia Mobile Phone
2. Now Press following key sequence *#7780#
Please Note: The Above Nokia Phone Formatting method will erase all your Phone data. So do backup before proceeding for Formatting
Jan 24, 2011 | Nokia N73 Cellular Phone
Pa jumper pin no of nokia2626
Nokia 2626 Signal No Network repairing solution.Nokia 2626 Signal No Network Mobile Repair diagram pictures Service Tips and Tricks.Make Jumpers as shown in diagram or replace the shown components .
How to short Nokia 2626 PA.jumper Pa nokia 2626. here is a diagram that is showing how to jumper and short P.A of nokia 2626. it is used to check that mobile is getting signals or not. if signals are to low with jumper change the P.A
Jan 21, 2011 | Nokia 2626 Mobile Phone
How to format and renew my nokia 2626 mobile
Just follow the steps
Make a backup of contacts in your another sim.
Try to Restore factory settings
On Sybmian phones:
*#7780# - Restore factory settings
*#7370# - Reformat your phone (back up your personal data with PC Suite or to the memory card first!)
Hard reset
Back up your personal data with PC Suite or to the memory card first!
Switch-off your phone.
1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3"
"green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you dont understand, again follow the step.
You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory
stetting.
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Jan 17, 2011 | Nokia 2626 Mobile Phone
How to reset the security code for nokia 2626?
Turn off the phone, press and hold *, 3 and dial button, (green button), then press the power button. Press all these buttons at the same time.
Make sure phone is full charged.
Good luck.
Jan 12, 2011 | Nokia 2626 Mobile Phone
How to format nokia 2626?
the code is 12345 or 00000
OR:
for soft format dial *#7780# or *#7370# which restores the factory settinngs
but if you format the whole phone memory then follow the procedure below ( remember one things this will deletes all your mesages, all contacts, photos, notes etc in the phone memory.. your phone is like a new phone
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
thank you
Thanks
Dec 29, 2010 | Nokia 2626 Mobile Phone
Hi friend my nokia N70 is hang problem wat i say make a one phone call just hanging and then no response wat can i do plz help me
Try to reset:
*#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed.
It will only reset the phone settings, such as profiles, themes and shortcuts.
The default lock code is 12345.(Read Method 3)
or try this(But it will fully format your phone)
Method 1:
1. Switch off your Phone.
2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key.
3. While holding The Three buttons, press the power button for switch on the phone.
4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 2:
2. Now Press following key-*#7370#
4. While holding All of the buttons, press the power button for switch on the phone.
5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 3:
Please Note:
The formatting method will erase all of your Phone data.
Please take a backup before you Format.
Dec 21, 2010 | Nokia N70 Cellular Phone
Forgot Nokia 2626 security code
hi friends, i forgot my nokia 2626 security code and cont able to open key gaurd my IMEI No is356395/02/339374/1 please help me to overcome this problem. need it
Oct 05, 2010 | Nokia 2626 Mobile Phone
How to restart nokia 2626
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what happens.nokia 2626 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 - Phone Memory Full - nokia 2626 mobile phone has got 9MB of internal memory.
Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent nokia 2626 from restarting.
Cause 2 - Changing Themes - Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling nokia 2626 phone memory.
Cause 3 - Memory Cards - Some people have reported that nokia 2626 restarts due to some issues with the memory card.
Solution - Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their nokia 2626 mobile phone restarts when updating the music library.
Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your nokia 2626 phone.
Cause 5 - MP3 files
Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this
Good luck
Jul 09, 2010 | Nokia 2626 Mobile Phone
Nokia 2626 Mobile Phone Logo
87 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
