Question about Car Audio & Video
Flat cable needed
Hallo! i need to replace a flat-cable connecting the fall-down rack (for the detachable front panel) to the base connector in my vdo-dayton MR4000. can you please help me with the info where to purchase it?? thank you, uros.
  • 104 Answers
There seems to be a loose connection between base and bottom of kettle . At first I could press down on the pot and it would start heating . Now I can
If it uses a detachable base to the kettle tank with electrical contacts, sometimes the base or kettle connector must be replaced. You will need the proper tools and wire connectors to be able to replace these parts.
Technically speaking... These are not worth servicing.
Jerry G.
Jun 21, 2012 | Philips HD4651 Electric Kettle
Hp printer 1312 fadad print how to fix
Check any refilled cartridges?.. No.Go to main menu select default setting.. check for the quality..No..
Need to clean reflecting mirrors in scanner assembly..Only professionals can perform this activity..
Remove right, left & back doors..
Detach the cable which came from flat bed assembly, remove two screws back side just below of flat bed, gently push flat bed assm back to front, lift & take out the flat bad unit.. remove upper cover, you can observe the scanner assm ( see the snap shot) "Note: to take out scanner assm cartridge & cartridge bank must be present in to the printer to prevent the damage to transfer kit, other wise scanner will fall down on transfer belt" Unlock & remove scanner secure pins(4nos), detach scanner flat cable connected to DC controller, take out scanner assm, open the bonnet of scanner assm, clean surface of the mirrors very very gently with ear buds.Don't disturb any factory settings, once its cleaned refix every thing back.. "Note: scanner flat cable which is connected to DC controller is not that much lengthy, before powering on check once cable connected in properly or not, if any thing goes wrong in this area printer wont power on & it may damages the DC controller or scanner assm .." But I am sure that only professional can perform this activity, if you are not qualified pl don't try it..5_25_2012_8_24_06_pm.jpg
May 25, 2012 | HP LaserJet CM1312 All-In-One Printer
How do you replace a laptop screen l555d serial number...its a toshiba.
1. Turn off the computer and remove the battery.
2. Loosen the plastic frame bordering the Toshiba Satellite L555D-S7005 Screen. This frame is attached to the notebook's back shell and holds the screen in place. Pry open two to six small rubber seals from the frame and undo concealed screws.
3. Detach the frame after removing all screws. Hold the bezel from either side of the screen and gently pull it away from the screen and toward you. If the bezel seems to be stuck, find any points of attachment, such as clips or hooks, and undo to detach it from the outer shell. Work with your fingers and go all around the frame to release and completely detach it.
4. Free the LCD panel from its position in the notebook's lid. When you remove the bezel, you will notice that the screen is held in place, enclosed in hinges. Undo screws from either side of the screen to release its attachment to the lid. Place a finger at the top center of the screen to keep it from falling down as you remove the screws. With all screws undone, tilt the panel and lower it face down onto the keyboard.
5. Disconnect the power cable and video cable from the screen. The power cable connects the screen's power source of the lcd inverter to the backlight lamp attached to a side of the panel. Unplug cables from either end of the inverter board and unscrew the board from the base of the screen. Next, find and unplug the video cable a broad, ribbon like arrangement taped to the back of the panel. Pull at the plastic head of the cable to detach it.
6. Remove the screen. With the screen's cables unplugged and inverter board removed, it is completely detached from the notebook's display assembly and may be safely removed. Pick up the panel from the keyboard and keep it to a side.
7. Orient the replacement screen by bringing it to the work area and aligning it to the laptop's shell. Gently rest the screen on the keyboard and attach the power cable and the video cable. Raise the screen and attach the inverter board to its base. Plug in the inverter board's cable to the screen's backlight lamp. Screw the screen in place and reorganize the display assembly.
May 04, 2011 | Toshiba Computers & Internet
I just read you post on replacing the heat controls on my 1998 Ford Contour. Thanks for the good reply. A few more questions on that, Can I replace only the selector switch DEFROST/AC/FLOOR/PANEL? Do I...
SECTION 412-04: Control Components 1998 Contour/Mystique Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 09/14/2001 Climate Control Assembly Removal
  1. Remove the radio chassis. For additional information, refer to Section 415-01.
Audio Unit
Special Tool(s) st1445a.jpg Remover, Radio
415-001 (T87P-19061-A)
Removal
  1. NOTE: Make sure the audio unit key code is available before disconnecting the audio unit electrical connectors and note the audio unit station presets.
    Using the special tool, detach the audio unit.
    • Insert the Radio removal tool into the locating holes until they click into place.
    1. Pull the tools gently to the left and right of the audio unit to release the locking tangs.
    1. Pull the audio unit out of the instrument panel.
  1. Remove the audio unit.
    1. Disconnect the power electrical connector.
    1. Disconnect the audioline/speaker electrical connector.
    1. Disconnect the antenna cable.
Installation
  1. NOTE: When installing the audio unit make sure the rear support engages on the carrier.
    To install, reverse the removal procedure.
    • Enter the audio unit keycode and re-program the pre-set audio unit stations
  1. Remove the floor console. For additional information, refer to Section 501-12.
Floor Console - Vehicles with Automatic Transaxle Removal
  1. ani_caut.gif WARNING: Wait at least one minute after disconnecting the battery cables before removing the floor console. Failure to follow this instruction may increase the possibility of accidentally deploying the air bag(s) and may cause personal injury.
    Disconnect the battery ground cable.
    • Wait one minute.
  1. NOTE: Contour shown, SVT similar.
    Remove the rear floor console screws.
    • Move seat fully forward.
  1. Fully apply the parking brake.
  1. Detach the shift indicator selector bezel.
  1. Detach the shift bezel from the selector housing.
    1. Remove three bolts.
    1. Detach shift bezel from the console.
  1. NOTE: The rear floor console must be raised to disengage the front retaining clips.
    Raise and remove the rear floor console.
  1. Remove the four front floor console retaining screws.
  1. Detach the front floor console.
    1. Set the gearshift lever into position 1.
      Partially remove the front floor console.
  1. Disconnect the cigar lighter electrical connections and remove the front center console.
  1. Remove the control opening finish panel.
    1. Remove the four screws.
    1. Disconnect the headlamp dimmer switch electrical connector.
    1. Remove the panel.
  1. Remove the climate control assembly screws.
  1. Remove the climate control assembly.
    • Disconnect the electrical connectors
    • Disconnect the vacuum harness connector.
Feb 01, 2011 | 1998 Ford Contour
I need to know how to disassembly the instrument panel of f-150 1997
Disconnect the Ford's negative battery cable. Turn the truck's front wheels straight ahead and then lock the steering column. Remove the A-pillars' trim by removing the screw covers and then unscrewing the mounting fasteners.
Remove the center console if equipped by unfastening the nearby trim panels, prying off the shifter trim panel, disconnecting the shifter cable and unfastening the console. Remove the steering wheel, then unfasten and remove the steering column covers, starting with the lower cover.
Remove the instrument cluster. Unscrew and pry off the knee bolster with the aid of a flat-blade tool, then unscrew and remove the instrument cluster bezel in a similar way. Disconnect the electrical connectors, remove the cluster's mounting bolts and remove the cluster--you'll need to disconnect the gear position indicator on an automatic transmission.
Remove the glove box by opening the door, pressing on the sides of the compartment bin together, pulling the door down and removing the fasteners at the bottom. Remove the center brace cover, center bezel and upper finish panel by removing their fasteners or prying them off their clips.
Detach the end caps to the panel with a trim stick or flat-bladed tool, then detach the hood release by removing its screw. Pry off the scuff plates and kick panels from the door frame. Pry up the defrost grilles with the same flat tool.
Disconnect the steering column shaft. Disconnect the electrical connectors from the column's harness, detach the shift cable and transmission indicator cable if you have automatic transmission, remove the pinch bolt from the intermediate shaft coupler and separate the intermediate shaft from the steering shaft.
Disconnect all remaining electrical connectors to the panel and unbolt all fasteners for the panel around the top, left and right sides and the ends along with the brackets at the center. Lift and pull the panel away from the windshield with an assistant's help, disconnect all remaining connectors and carry the panel out the driver's door.
Good luck.
Nov 07, 2010 | 1997 Ford F150 Regular Cab
How to relace power window motor
Motor
  1. Raise the window glass to the full-up position if possible. If the glass cannot be raised and is in a partially down or full-down position, it must be supported so that it will not fall into the door well when removing the window motor.
  2. Disconnect the negative battery cable.
  3. Remove the door trim panel and watershield.
  4. Detach the window motor harness connector.
WARNING
If the front door power window regulator counterbalance spring must be removed or replaced for any reason, make sure that the front door power window regulator arms are in a fixed position prior to removal to prevent possible injury during c-spring unwind.
WARNING
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 32; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
  1. Remove the three window motor mounting screws.
  2. Remove the window motor.
To install:
  1. Position the window motor to the power window regulator. Install the three screws snugly but do not tighten all the way.
  2. Attach the window regulator electric drive wires at the connector and cycle the door window glass to make sure the motor gear engages. After the gears are engaged, tighten the three window motor retaining screws to 54-88 inch lbs.(6-10 Nm).
  3. Connect the negative battery cable.
  4. Check the power window for proper operation.
  5. Install the door trim panel and watershield.
Sep 13, 2010 | 1998 Ford Taurus
Need to remove dashboard 1992 ford aerostar
Check this procedure...
  1. Disconnect the negative battery cable.
  2. Detach the wiring connector from the instrument panel, located in the engine compartment, by loosening the bolt and separating the connector halves.
  3. Remove the left and right windshield inside mouldings.
  4. Remove the defroster grille.
  5. Remove the glove compartment door finish panel.
  6. Remove the instrument panel steering column cover.
  7. Remove the four bolts attaching the steering column lower reinforcement. Remove the reinforcement.
  8. Remove the right and left cowl side panels.
  9. Remove the two nuts retaining the hood latch control handle and cable assembly to the left cowl side. Remove the control handle and cable assembly, then reinstall the nuts to hold the bracket and relay in place.
  10. Detach the wiring on the left cowl side panel and, if equipped, the vacuum hose harness connector. The number and location of the connectors may vary depending on optional equipment.
  11. Detach the brake light switch wiring connector. Detach the clutch pedal position switch on manual transmission equipped vehicles.
  12. Remove the steering column-to-extension shaft pinch bolt. Compress the extension shaft toward the engine, then separate from the column U-joint.
  13. Detach the transmission control selector indicator from the steering column.
  14. Disconnect the wiring from the windshield wiper intermittent control module and, if equipped, the wiring from the low oil level relay. Both are located to the right of the steering column.
  15. Disconnect the radio antenna lead-in cable at the right cowl side panel.
  16. Disconnect the heater temperature cable. If equipped, detach the vacuum hose harness connector.
  17. Remove the five screws attaching the top of the instrument panel to the cowl side top panel.
  18. Remove the one nut attaching the lower right side of the instrument panel to the cowl side panel.
  19. Remove the two rearward nuts, then loosen the two forward nuts located to the right of the steering column, attaching the instrument panel to the center mounting bracket.
The following removal steps require the help of an assistant.
  1. Support the instrument panel. Remove the three bolts and one nut attaching the instrument panel to the left cowl side panel.
  2. Carefully pull the instrument panel rearward, then disconnect any remaining wires or other components.
  3. Carefully remove the instrument panel through the left front door.
  4. If replacing the instrument panel, transfer all the components to the replacement instrument panel.
continue...
Jun 29, 2010 | 1992 Ford Aerostar Extended
Where can I read, for free, how to remove the drivers door panel and remove and replace the window regulator. I see these questions on this site but there are NO ANSWERS. What's with that? 1998 Cadillac...
GM Cadillac Deville_Fleetwood_ELD_Seville 1990-1998
Door Panels - REMOVAL & INSTALLATION
FRONT DOOR
Fig. Front door panel-1990-91 Deville and Fleetwood
Fig. Front door panel-1992-98 Deville and Fleetwood
Fig. Carefully pry up the power window switchplate and . . .
Fig. . . . gently remove it from the door panel
Fig. Remove the door pull strap retaining screw covers by gently prying them off
Fig. Remove the door pull strap retaining screws
Fig. Gently pull the inside door handle panel down and . . .
Fig. . . . release the rod from the handle
Fig. Carefully lift up the door panel to release the . . .
Fig. . . . retaining pegs on the door panel
Fig. Do not pull the panel too far away from the door, as some components still have wiring harness connected
Fig. Detach any necessary wiring connectors and remove the door panel from the vehicle
  2. Insert a flat-bladed tool between the door panel and the rear edge of the power window switch plate to disengage the retainer from the panel.
  3. Slide the power window switch plate forward, then label and detach the wiring connectors.
  4. Remove the power door lock switch plate retaining screw. Remove the switch plate and detach the wiring connector.
  5. Remove the pull handle retaining screws.
  6. Using a thin-bladed tool, carefully pry the courtesy lamp lenses off. Remove the courtesy lamp bulb.
  7. Pinch the courtesy lamp retainers and pull out the lamp socket holder. Detach the courtesy lamp wiring connector.
  8. Remove the door panel retaining screws.
  9. Using tool J-2459B or equivalent, disengage the door panel fasteners from the holes in the door. Detach any remaining wiring connectors and remove the door panel.
To install:
  1. Position the door panel close to the door and attach the wiring connectors.
  2. Align the door panel fasteners with the holes in the door. Push in on the door panel to install it to the door.
  3. Install the door panel and pull handle retaining screws.
  4. Install the courtesy lamps and switch plates.
  5. Connect the negative battery cable.
I really hope help you with this (remember rated it) Good luck.
Oct 12, 2009 | 2001 Cadillac DeVille
1990 cutlass ceira how do you replace drivers door side mirror
Outside Mirrors REMOVAL & INSTALLATION Standard
  1. Remove the door trim panel and detach the inner panel water deflector. With the glass in the down position, pull out the front portion of the glass run weatherstrip. Fig. 1: Unfasten the attaching nuts from the mirror base studs, then remove the mirror 8c45877.gif
  1. Remove the attaching bolts and screws from the front glass run channel lower retainer to filler, then rotate retainer rearward.
  2. Remove the noise control patch to gain access to the screw at the belt, then remove the screw.
  3. Remove the filler attaching screws at the top front of the window frame, then remove the mirror and filler from the door.
  4. Remove the attaching nuts from the mirror base studs, then remove the mirror. To install:
  5. Be sure that the mirror gasket is aligned.
  6. Replace the mirror and filler on the door. Install the filler attaching screws at the top front of the window frame. Attach the nuts to the mirror studs and tighten.
  7. Install the screw at the belt, then insert the noise control patch.
  8. Insert the retainer, then install the attaching bolts and screws to the front glass run channel lower retainer to filler.
  9. Replace the front portion of the glass run weatherstrip, insert the inner panel water deflector, then reinstall the door trim panel.
Manual Remote
  1. Remove the mirror remote control escutcheons and door trim panel. Detach the inner panel water deflector. NOTE: Right side remote mirror may require detaching part of the instrument panel.
  2. With the glass in the down position, pull out the front portion of the glass run weatherstrip.
  3. Remove the attaching bolts and screws from the front glass run channel lower retainer to filler and rotate retainer rearward.
  4. Remove the noise control patch to gain access to the 0.3 in. (7mm) screw at the belt and remove the screw.
  5. Remove the filler attaching screws at the top front of the window frame.
  6. Remove the mirror base with mirror and cable assembly from the door.
  7. Remove the mirror to filler attaching nuts and remove the mirror and cable from filler. To install:
  8. Be sure cable is routed around front glass run channel retainer and installed to clip.
  9. Install and connect the cable to the filler.
  10. Attach the filler nuts to the mirror, then tighten to 72 inch lbs. (8 Nm).
  11. Install the mirror base with the mirror and cable assembly to the door.
  12. Insert the filler attaching screws to the top of the window frame, then install the screw to the belt.
  13. Secure the noise control patch.
  14. Attach the bolts and screws to the front of the glass run channel lower retainer and filler.
  15. Install the glass run weatherstrip.
  16. Attach the inner panel water deflector, door trim panel and mirror remote control escutcheon.
Electric Remote
  2. Remove the mirror remote control escutcheons and door trim panel. Detach the inner panel water deflector and the electrical connector for the mirror. NOTE: Right side remote mirror may require detaching part of the instrument panel.
  3. With the glass in the down position, pull out the front portion of the glass run weatherstrip.
  4. Remove the attaching bolts and screws from the front glass run channel lower retainer to filler and rotate retainer rearward.
  5. Remove the noise control patch to gain access to the 0.3 in. (7mm) screw at the belt and remove the screw.
  6. Remove the filler attaching screws at the top front of the window frame.
  7. Remove the mirror base with mirror and electric connector from the door.
  8. Remove the mirror to filler attaching nuts and remove the mirror and electric wire from filler.
  9. To install, reverse Steps 1 through 6. Be sure electric wire is routed around front glass run channel retainer and installed to the clip. Tighten the nuts to 72 inch lbs. (8 Nm).
  10. Connect the negative battery cable, then reset the clock, radio and any other accessories if required.
Aug 25, 2009 | 1990 Oldsmobile Cutlass Ciera
We have a hp pavillion dv7-1240us & we need directions on how to replace the screen ???
LCD Panel removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the battery, wireless LAN Minicard, keyboard, switch cover, display panel, display bezel, and inverter.
  1. Remove the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
  2. Remove the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Lift the LCD panel out of the display panel enclosure.
LCD Panel replacement Note: Before replacing the LCD panel, remove the left and right hinges from the old LCD panel and install them on the new LCD panel.
  1. Place the LCD panel into the display panel enclosure.
  2. Replace the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Replace the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
To remove in order to replace LCD, you will have to remove WLAN, keyboardwith the instruction :
Wireless LAN Minicard removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the battery.
  1. Loosen the two captive P1 Phillips-head screws that secure the memory/wireless LAN Minicard cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the edge of the memory/wireless LAN Minicard cover and remove it.
  3. Carefully disconnect the wireless antenna cables from the wireless LAN Minicard with a small needlenose pliers or tweezers.
    Important! Use care when disconnecting the wireless antenna cables from the wireless LAN Minicard. Damaged cables or connectors can degrade notebook performance.
    Note: If three antenna cables are connected to the wireless LAN Minicard, the cable labeled 1 connects to terminal 1, the cable labeled 2 connects to terminal 2, and the cable labeled 3 connects to terminal 3. If two antenna cables are connected to the wireless LAN Minicard, the cable labeled 1 connects to the MAIN terminal and the cable labeled 2 connects to the AUX terminal.
  4. Remove the two 3 mm P1 Phillips-head screws that secure the wireless LAN Minicard to the system board and allow it to release to the spring tension position.
  5. Grasp the wireless LAN Minicard by the edges and pull gently to remove it.
  6. Place the wireless LAN Minicard in a static dissipative bag.
Keyboard removal Caution! Observe all precautions when removing and replacing components.
  3. Remove the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  4. Remove the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  5. Turn the notebook right side up and open the display panel fully.
  6. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and slide the keyboard toward the rear of the notebook.
  7. Using minimal force, push the locking bar toward the rear of the notebook to unlock the keyboard ZIF connector on the system board.
    Important! Use care to prevent damaging the ZIF connector and ribbon cable.
  8. Remove the keyboard ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. Place the keyboard right side up on the top cover and insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
    Important! Use care to prevent damaging the keyboard ribbon cable.
  2. Push the locking bar toward the front of the notebook to lock the keyboard ZIF connector on the system board.
  3. Toe the tabs on the bottom edge of the keyboard into the top cover.
  4. Press the keyboard flat.
  5. Close the display panel and turn the notebook upside down.
  6. Replace the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  7. Replace the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  8. Toe the memory/wireless LAN Minicard cover into the base enclosure.
  9. Tighten the two captive P1 Phillips-head screws.
May 17, 2009 | HP Computers & Internet
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
