Question about Dewalt DC925 Cordless Drill
Shake the drill to make it work
Sometimes my drill dewalt 18v dont work until i shake it quite hard my drill doesnt work unless i shake it,i have replaced the brushes,but no change
  • jon perry May 09, 2009
    thank you charlie. i tried your suggestions and they worked a treat,what a result!!!!!!
    President:
  • 1,489 Answers
Sounds like the battery is not making a good connection inside the drill handle. Clean the contacts inside the handle where the battery plugs. Clean the contacts on the battery. If there are any springy tabs in either of these places, pry them up slightly to increase the pressure between the contacts.
Clean with wire brush, sandpaper, electrical contact cleaner.
If this doesn't work, get back to me and we'll go to the next step.
Charlie
Posted on May 09, 2009
  • Samuel Charles Spriggs May 09, 2009
    Great!! Glad it worked.
    Pardon my asking, but you rated this as a helpful response -- wouldn't it deserve a "problem solved" response? It did solve your problem, I think.
Cant seem to get 1 st gear on my dewalt dcd960
Other then it being something simple such as the actual shifter itself, the gearbox on those is somewhat complicated. Quite a few parts and you really have to disassemble and inspect everything. Not easy to do so you may not want to try and repair it yourself. Here is the parts diagram so you can see what's in there.
DeWalt DCD960
Jul 31, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
How to remove a chuck from a DeWalt hand drill
Open chuck all the way (like for a large drill bit). There should be a set screw at the bottom (where you would put a drill bit). Don't turn too hard - it may be a left handed screw (I don't remember if it is a lefty for sure but try gently each way then with a bit more force each way until it moves).
Good luck.
Mar 19, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
Dewalt 18v drill dc988 type requires switch
Here is a link for a parts diagram for your model. It has the proper part number that you will need.
Hope this helps.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/dewalt/DC988KA_TYPE_1
Sep 07, 2009 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
Dewalt 18V XRP Hammer drill, stops on torque in drillpositio
The brushes might need to be replaced. You can find them on Ebay and are easily to replace.
Aug 01, 2009 | Dewalt DC927KL Heavy Duty 18 Volt Cordless...
Why does my drill run hot
Maybe ur drill is not heavy duty type.You need to rewind the motor,but if i were you buy a new one.YOu may use the old one but its good for few minutes after using it.
May 19, 2009 | Dewalt 18v 1/2" Compact Drill/driver Kit...
Drill doesnt work unless shaken
It sounds like a bad cord, or a loose electrical connection inside the handle, or the switch.
Instead of shaking the drill, try wiggling the cord where it goes into the drill handle, then wiggle it where if plugs into the wall.
If this doesn't cause the drill to run, try pressing the switch repeatedly to see if that causes it to run. If that doesn't work, it's probably a connection inside the handle.
Try these procedures and please let me know the results. We'll take it from there.
thanks...
Charlie
May 09, 2009 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
Drill
Hi hope to help
sounds like you have a problem with your brushes they may just need replacing but do not strip the drill down to do this just take out the batery then take the 4 screws from the rear off the drill and take off the cover see if the brushes are worn it doesnt take a lot of wear to be worn.
You can take off the wire from each brush unit then use a small flat screwdriver to pop out the brush unit then replace you should be able to get the brushes from any dewalt stockest.
Hope that helps. Sean
Jan 12, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I just replaced the switch assembly for the same problem
Dewalt 18v. cordless drill
Hope to help.
hope your wife is ok!!
you need to get all the hair out firstly but DO NOT touch the exposed switch as it is a static switch and can fail by the tatic in you!
the problem may be that the brushes were damaged try replacing them see how that goes.
hope this helps. Sean
Jan 06, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt DC925 Cordless Drill Logo
343 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
