Question about Acer Aspire 5670 Notebook
Intermittent video problem on acer extenza 5620.sometimes video display backlight will work sometimes it fails.
  • Acer Master
  • 32,281 Answers
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 09, 2009
Can i install windows 7 on my acer extenza 5620?
Yes you can, but please note that the laptop has shared video memory so if you will get a low rating index on Windows 7 you will need to upgrade the RAM (it supports up to 4GB) in order to allocate more RAM to the video card.
Dec 07, 2010 | Acer Extensa 5620 Notebook PC
My acer extenza 4420 backlight wont turn on
most likely:
1. backlight is dead (search for replacement displays).
2. backlight power-inverter is dead (check ebay for your model +inverter to see if there is even one in your model)
3. (very unlikely) wires which power the backlight may be worn from bending over time.
for the time-being, connect an external monitor, if possible, so you can access your system. connect it, power-on, and it should work by default -if not, hold the Fn key and press F8 (usually this key) to enable external display output.
and.. good luck!
Aug 31, 2009 | Acer Extensa 710TE Notebook
Acer extenza 5620z mouse not responding as it should keyboard input slow and not responsive cannot input all digits of my password to get computer started
How long since you've run the computer? Might it be processing and update like when it reboots after installing a service pack? That might be making the computer run slow for a few minutes. Give it a little time to get started and see if your mouse and keyboard begin to work.
Jun 01, 2009 | Acer Extensa 5620-4020 Notebook
Need original manufacturer settings
Hi there.
When you turn the laptop on, I believe you get an ACER logo, press Alt and F10. This should start the recovery program.
If you need any more assistance, just ask, I'll be glad to help.
Tim
Apr 20, 2009 | Acer Extensa 5620 Notebook PC
Want computer brought back to manufacturer's settings
Here's a link to the instructions you're looking for.
Click here for Acer
and have a look at the step-by-step guide here.
The monitor is black but the computer functions correctly. Acer Extensa 5620 laptop.
You should replace your "backlight" in your lcd, or if you have the money you need to replace your entire lcd. This problem it is because your inverter couldnot turn on your backlight wich it is burn or broken
Download bluetooth
If i understand it correctly , you need the drivers for the bluetooth card on your acer computer. The same can be downloaded below
http://www.laptops-drivers.com/acer-notebooks/free-download-acer-extensa-5620-driver-for-xp.html
Browse downslowly on the left side of the page it has the link, to download the drivers
BlueTooth Broadcom
Thanks
proton
Jan 06, 2009 | HP Compaq Presario V2000 Notebook
Acer travelmate 2410
This doesn't necessarily rule out the inverter. I've had inverters with intermittent problems that had the same effect, so having the inverter tested is the only way to rule it out. Other possibilities are a bad connection, a corroded/dirty pin or socket in a connector, a bad ribbon/cable, and a failing backlight. If it is a failing backlight, the entire screen will need replaced, as the screen is considered a sealed unit and the backlight isn't available and not considered a replaceable item. Also, it's rare, but it could have a faulty motherboard component or video card. I'm leaning towards a faulty backlight, but keep in mind the inverter and cable possibility. Start by checking and cleaning all connections.
Sep 17, 2008 | Acer TravelMate 2300 Notebook
Acer Aspire 5670 Notebook Logo
106 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
