Question about Nikon SB-400 Flash
Bulb will not fire - Nikon SB-400 Flash
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Nikon Expert
  • 305 Answers
Maybe a burned out buld
Posted on Aug 21, 2014
What kind of a light bulb is needed for the febo flame electric fireplace?
Flickering flame fires generally use a fairly ordinary tungsten filament incandescent bulb, except the Fireglow bulbs are coated with an amber coloured lacquer. The heat from the bulb causes an upward current of air causing a small "windmill" to turn and cause the light to flicker.
That is the traditional method but ultra modern fires might use a higher-tech solution.
Oct 22, 2016 | Heating & Cooling
Dimplex dakota heater is working but flame effect is not its led I think not bulbs.
Says you can turn it on and off? Did you knock the switch?
Can I operate the flame effect on the fire without the heat?
All our Optiflame and Opti-myst fires can be operated on a flame-effect only setting, as can the flickering flame effect on our freestanding bar fires.
Is the flame effect expensive to run?
No, to run the flame effect involves powering light bulbs and a small electric motor and in most cases costs no more than a couple of pence an hour. Some of our fires have LED lamps fitted which are even more energy efficient.
Some have bulbs, some have LED.
Example calculations:
Using UK standard average price of electricity of 14p/kWh (source: Energy Saving Trust Feb 2015)
Optiflame LED flame effect only (eg Danesbury) = 0.1p every hour
Optiflame conventional bulb, effect only (eg Cheriton) = 2p every hour
Opti-myst, flame effect only (eg Oakhurst) = 3p every hour
Opti-V single screen = 0.5p every hour
2kW fan heater, on constantly (no thermostat) = 28p every hour
Optiflame lightbulbs for sale. Remove the coals and check for bulbs.
https://store.gdcgroup.co.uk/dimplex/products/index.htm?product_code=FP03022
Dec 23, 2015 | Dimplex Heating & Cooling
I changed my bulb to weeks ago and now it wont fire have sound and no picture i have a wd 73c-10
Did you use a generic bulb or a "Neolux" lamp--Mits does NOT like those. Use a Phillips bulb or an original NON neoloux one.
Apr 01, 2014 | Mitsubishi Televison & Video
New lamp worked for 2 weeks, last night would not turn in so removed lamp thinking it was burnt to send back under warranty. Lamp appeared fine so reinserted and tv surprisinly turned on. this morning...
Edwin, sounds like you might be having a problem with your Ballast. The Ballast is what fires up lamp. Typically if this is an older unit, when you replace the bulb, you will have to replace your ballast as well. It is harder to fire up a new bulb, then it is to fire up an old bulb. That's why you wouldn't notice the problem until you changed your bulb.
Mar 01, 2014 | Panasonic Televison & Video
I just bought the Fire Sprinkler Head, Viking Upright, Brass, Glass Bulb 12986. What wrench do I use to install it?
Install the Fire Sprinkler Head, Viking Upright, Brass, Glass Bulb 12986 using Viking 10896W/B standard wrench or wrench 13577W/B for waxed or recessed applications.
May 07, 2013 | Home
Replace bulb in hyundai curved glass fire
Two people required for this
Remove fire from wall
Lay fire on its back
Gently slide glass panel towards top of fire and remove. Store glass safely
At the bottom of the fire there is a lamp cover fixed by 8 Philips head screws.
Remove screws and lift off the lamp cover
Slide the flexible rotisserie to one side ensuring you don't lose the rubber grommet
Remove bulb by pulling it out of the holder (force may be required)
Replace with 40 watt G9 halogen bulb. Take care not to touch the bulb with your bare hands
Push the bulb fully home
Refit the rotisserie making sure the rubber grommet is carefully pushed into the slotted hole in the axial bracket
Refit the lamp cover
Lift the fire back onto the wall and replace glass front by lifting onto the lugs either side of the fire.
Oct 22, 2011 | Hyundai Heating & Cooling
We have a Dimplex Danesbury Dan 20 fire and need to change a bulb! How?
1.Remove the coals .
2.Remove the two screws in the front of the brass grate second bar down.
3.pull the grate assembly away from the fire.
4. The bulbs are now exposed.
Replace with 60 Watt SES clear candle bulbs. Reassemble in reverse order.
Oct 25, 2010 | Heating & Cooling
Infocus LP130, Bulb fires then goes out
there is a problem with the power to the front fan from the main board. there are 3 wires going to the fans: one power, one return, and one signal. if the main board reads no signal from the fan's speed, it'll shut down. check the power going to the fans and the signal. you may need to replace the main board.
Mar 03, 2010 | InFocus Office Equipment & Supplies
How to replace fire bulb for Dimplex HTN20
I wanted an answer to this too. It was hard to find, but here we go.
Get hold of a torch, and look closely at the decorative surround at the bottom of the fire. There are two screws hidden in there, on each side! See below:
Unscrew these, and you can take the front off, and get at the bulbs.
For information, the fire takes two screw in bulbs, described as 240V – 60W E14 SES Clear Candle Lamps.
Hope this helps.
Feb 07, 2009 | Dimplex DS5598 Mid-Size Heater
SP4805 bulb does not fire up; led stays green; fan turned on
I had the same problem after purchasing a new bulb. My husband pulled it out after it would not fire up and the new bulb plug in conecter (white with 4 holes with two wires) was different. Take your old bulb and compair the two conecters and see if they match, then check if the wires are in the same slots as in first and last. Mine on the new one were in the first and second to last slot. So we took the wire out of the second to last and put it in the last slot and installed it and it fixed the problem. We also had to unplug and replug it in and do a master reset by pressing the Power and Channel buttons and the same time for 15sec. Hope this helps.
Jan 23, 2009 | InFocus ScreenPlay 4805 Multimedia...
Nikon SB-400 Flash Logo
112 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
