Question about Minolta DI-2010F Copier
Error c 0210 minolta di 450
I was cleaning the Transfer sep unit and when I put it back in, then  it started giving me this code C 0210 on the 2nd copy. which shows as the HVT I switched it with a similar transfer unit that I know was working ( I have 2 Di 450) but gave me the same error, when I put the transfer unit back in the one that was working, it gave me the same code as the other copier C 0210 always on the 2nd copy. But, I know for a fact that it WAS WORKING. I did not do anything to the 2nd transfer unit but try it in the other machine, and on that one all I did was clean it. I find it hard to beleive both HVT units have gone bad " all of a sudden".
  • Minolta Master
  • 6,850 Answers
Sir,
You mite have a problem with XFER/SEP HV Connection in the first Di450. Also the Housing's on both end of the XFER/SEP assy may need replace ment that would be the two white assy at each end of the XFER/SEP assy. There breaking down due to HV. Also have you replaced the two corna wires in each unit their very fine gold plated wires very thin. They mite have broke or have toner over them clean with alcohol be careful they are very fine wires.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Mar 14, 2010
  • Minolta Master
  • 1,316 Answers
Change T/S corona holders.
Posted on Jul 30, 2009
    Problem Solver:
  • 11 Answers
  1. Transfer sep corona wire
Posted on May 07, 2008
  • 69 Answers
Hi im jules_09.if you think that at hvt you installed is ok try to reset it in the program
Posted on Oct 12, 2007
SOURCE:
When my konica minolta c280 gives me an error codes c2151 please help"
Code
C2151
Description
Secondary transfer roller pressure welding alienation
• The pressure welding alienation sensor doesn't turn OFF (retracting) even after the lapse of a given period of time after the 2nd image transfer pressure retraction motor has started rotating during the 2nd image transfer roller is retracting. • The pressure welding alienation sensor doesn't turn ON (pressuring) even after the lapse of a given period of time after the 2nd image transfer pressure retraction motor has started rotating during the 2nd image transfer roller is pressuring
Sep 23, 2016 | Konica Minolta Bizhub C280 Color Copier /...
My konica monilta di 450 is giving error code c-13fa please help and give me its solvation?
The problem is the print head that is were the LASER is located open close the front door to reset if it comes back replace the print head
Feb 01, 2014 | Minolta DI-2010F Copier
Hw do i fix error code c0210 on my minolta dialta di 552
Directly below the drum section is assemble called the transfer/separation assy. the purpose of this unit is two fold. (It houses to very thin gold plated wires) One wire is what helps the transfer of the image from the drum to the paper. Since the paper goes between this wire and the drum, the second wire prevent the paper from sticking to the drum during the transfer process. The code you have been getting means either wire mite be broke, has to cleaned (because of all the toner on it from the drum assy. which need to removed and cleaned. Or The end blocks that hold the wires are getting old and allowing the High Voltage that is applied to the wire during the copy/print process are breaking down allowing the high voltage to ground. Open close the front door to clear. if it comes back have qualified tech look at it.
Mar 09, 2013 | Minolta Office Equipment & Supplies
Di 450 error code c-0210
Right below the drum section is an assemble that has two very fine wires in it. The assemble comes out by pulling it out. have the machine off. When you pull it out you will see to blocks one at each end well those blocks (White Looking) house the connectors for those very thin wires. Several thousand volts travel thru those connectors to the wires to do two things one wire helps transfer the image on to the paper because during the copy/print process the paper goes between both wire and the drum, the second wire prevent the paper from sticking to the drum. After a while with those high voltages going thru those blocks they breakdown and the voltages goes to ground vise the wires causing the machine to issue that code. Might find the those blocks or the whole assy at. the web site below. Open close front door to reset code. Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Mar 01, 2013 | Minolta DI-2010F Copier
I have an error C0094 what does it mean
You have Minolta dialta CF 3102
The C0094 code -2nd transfer roller separation.Clean using vacuum cleaner the transfer unit and the electrical contacts.
Feb 11, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
PRINT HEAD failure that is the unit the LASER is in. try open close front door, check connection between print head and image control board if not need a new print head.
Dec 28, 2011 | Minolta DI-2010F Copier
What is c0120 error
error code C-0120 in konika minolta model no C-450
Feb 03, 2011 | Konica Minolta Minolta DI1610P Printer,...
Minolta dialta Di 470 donne code c 0210 puis
C210,transfer/separation corona malfunction.Change or clean the corona wire and the corona holders(white Assembly).
Jan 10, 2010 | Minolta Office Equipment & Supplies
MInolta Di 183
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Thanks.
Mar 25, 2009 | Minolta DiALTA Di183 Copier
DI 450 KONICA MINOLTA ERROR CODE C0070 AND C0F24
if it;s not the bottle home position it may be you toner happer motor...clean it and try to take the bottle our and close the door and than put bottle back in
hope that help
Feb 25, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta DI-2010F Copier Logo
1,761 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
