Question about Refrigerators
Fan making noise but stops when door opens
I have a samsung srs621dp side by side and the fan inside the fride side is making a bad noise but stops when I open the door. What should I do to fix it?
  • 158 Answers
Try defrosting, it might be touching ice build up. you can check by pressing the knob switch in front after defrosting one day
Posted on May 09, 2009
My samsung, fridge freezer is making a noise which stops when we open the fridge door.
a lot of refrigerators stop the fan when the door is opened, check that fan blade isnt hitting something.
Oct 06, 2011 | Samsung RS2630SH Side by Side Refrigerator
What happened to my Samsung RS255BASB is a loud noise coming from the back of the fridge, one third the way up. sounds like a bad fan/ grinding fan. from the inside it's behind the area where there are...
The sound is of the fan touching the liner. They only way out is to change the bearing. And temporarily you can tap the area where the noise is coming from. When the fan straightens out the noise will stop. But this is not the remedy.
May 14, 2011 | Samsung RS265LABP Side by Side...
It is making a buzzing noise on freezer side that stops when u open the door but starts again when u close it
On some models of refrigerators, the evaporator fan (behind an access panel at the top of the freezer) shuts off when the door is opened. This fan may be making the buzzing sound.
You should be able to check by pushing in the door switch while holding the door open. The fan should come on; and, if the buzzing resumes, you know what is making the noise. The fan may be developing a problem. If it stops running, the cold air will not be distributed properly between the freezer and refrigerator.
Oct 19, 2009 | Samsung RS2630SH Side by Side Refrigerator
Noise on the ice maker
I think you are having the same issue that I am having. My noise is being caused due to ice build up around the fan inside the freezer. There is a switch when you open the door that causes the fan to shut off, hence the reason the noise stops when you open the door.
I pulled the cover (just below the ice maker) and removed the ice that had built up. Only problem is that after three days the noise is back. I think there may be a bigger problem that is causing the ice to build up around the fan.
Jan 05, 2009 | Samsung RS2630WW Side by Side Refrigerator
Fridge fan noise
Du musst den Abtausensor erneuern, ((Gelbes Kabel ))
Jun 03, 2008 | Samsung RS2534 Side by Side Refrigerator
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Feb 12, 2008 | Refrigerators
Refrigerators Logo
775 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
