Question about Sony FD Trinitron WEGA KV-21CL10 21" TV
Zenith wont tune channels
I have a zenith B09A02X tv. The remote quit working and I got a new universal remote that works fine.  Except, once the tv was unplugged it lost all the channels and now won't go above chanel 13.  Is there a way to manually tune it with out the original remote which had the auto search button on it.  The new remote does not have an auto search button or a menu button.
Re: zenith wont tune channels
How do I reset and get my channel without the box.
Posted on Oct 29, 2009
    Problem Solver:
You must get a proper replacement remote control, once you can access the menu and find you cannot store above 13, place another post and i will help you further.
Posted on Nov 08, 2007
0 characters
3 Points
I have a small Zenith tv...model #19A11D . I just started using it after a long time. I can't get the remote to work well. It's very hard to put in the channel numbers. Often no matter how hard I press,...
Sorry, but no, although you can get a phillips universal remote control. It is awesome, it also comes with a manual and a book of codes and instructions on how to program it to your tv or dvd player. hope this helps
Feb 25, 2010 | Zenith A19A11D 19" TV
Zenith sr2075dt TV won't change from AUX channel
tries this website 1-800-Remotes Factory Original.U get the same axact remote or very close to the original.
Aug 25, 2009 | Zenith C27A24T 27" TV
Zenith B27A11Z 27" TV, can't get into menu, original remote gone
Most universal or multi-brand remotes will control a TV's basic functions, but almost none will support advanced functions like menus. If the TV doesn't have a front panel menu button, the best solution is to buy a universal remote of the same brand as the TV. If you get a Zenith universal remote, it should have a menu button that will work with the TV.
Dec 14, 2008 | Zenith B27A11Z 27" TV
Up and down arrows on channel or menu selections not working.
All the functions of in putting and selections channel are done by one stage of a tv. take your tv to a w/shop, it wll require change of components,
get a diagram from
further help will be provided
Dec 06, 2008 | Zenith B25A02Z TV
Menu keys not working & Chanel 2 & 3 Only
Greetings Eagle7eye,
It sounds like you might have a problem with the cable settings for your TV. There are a few standards for cable broadcasts and you may need to set it to standard or "STD". But since your menu button doesn't seem to be working this would pose a problem.
I would try and access your settings with the universal remote and look for something like antenna (ANT) and change it from air to cable. Depending on how old your TV is too there may be a small switch near your coaxial connection for the cable setting.
Good Hunting.
Go Ahead. Use Us.
May 05, 2008 | Zenith B32A24Z 32" TV
Fried remote control receiver? (Zenith B32A24Z)
Invest in a long poking stick....... Either the Infrared receiver or controller it blew out. The high amount of static electricity formed and must of jumped off by the infrared receiver causing a momentary short in the circuit board. Safety's shut the tv down before frying, but damage looks to be done. It can be fixed, but only cheap if only the infrared receiver was damaged, anything else and it's going to be pricey.
Apr 23, 2008 | Zenith B32A24Z 32" TV
Zenith h32h38dt 32
The "H" model Zenith TVs are hotel/motel sets designed that
a roomer cannot access the menu feature. Your best bet would
be to purchase a name brand universal remote which has the
menu button feature or order an original Zenith master remote
which would not require programming. Once you have a workable
remote which will allow you to access the on-screen menus you
should be able to program the channels.
Hope this helps,
Feb 27, 2008 | Standard (CRT) Televisions
Cant turn sap off missing sound on some channels
Hmmm, you'll need that original, there. See if you can find one, and maybe even just borrow one to get what you're after...accordianman
Feb 09, 2008 | Sharp 27H-S60 TV
I am stuck on channel 2
some tv's default to channel 2 after being unplugged.since it is a older tv ,the buttons on the remote and the tv maybe worn down.on the tv itself try pushing the buttons down a liitle harder. if you have aux or line in/video inputs,scroll down on the channel button to log into a aux channel for the dvd for the remote try buying a cheap universal remote to see if that works.
good luck
Feb 02, 2008 | Zenith A25A23W 25" TV
Remote Sensor on Console Set doesn't seem to work
replace sensor they have know to go from time to time. suggest orginal sensor
Dec 10, 2006 | Zenith B27A74R 27" TV
Sony FD Trinitron WEGA KV-21CL10 21" TV Logo
291 people viewed this question
Top Sony Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Sony Standard (CRT) Television Expert? Answer questions, earn points and help others
