Question about Thermador SC272T Electric Double Oven
What does f24 mean? - Thermador SC272T Electric Double Oven
    Champion:
  • Thermador Expert
  • 323 Answers
Clean the control panel of all residue. Make sure the door closes properly. If it continues, chances are you will need to replace the touch pad and relay board.
Posted on Feb 05, 2015
I'm getting a f24 code on my lower wall oven...what to do?
Hi. Error code F24 indicates that the controller has failed to communicate with the lower convection fan and oven lights control board. If the error code persists, I would recommend connecting with an expert repair tech to assist further and the display board may need replacing.
Sep 26, 2014 | Electrolux ICON 30 in. Double Wall Oven
F24 code
In some cases I have had to replace both the touch pad and power relay board. Expensive! HOWEVER, I have, on occasion, found the wide ribbon from the touch pad to the relay board to be at fault. I have not found replacements for these as of yet. I have been able to "open" the ribbon to clean the contacts within and reassemble it to find everything working. Needless to say, my clients have been extremely happy with my ability to do so, saving them thousands if having to replace the entire unit.
I found the bad connection when the lighting was dim and I saw a "flash" at the point ribbon it inserted in the end piece. Hope this helps.
Jan 23, 2014 | Thermador Ovens
Code f24
shorted keypad. replace touch pad and relay board. Expensive!
Feb 06, 2013 | Thermador SEC302 Electric Double Oven
F24 shows on readout and oven shuts off
The F24 fault code is caused by a closed/stuck/shorted contact on the control panel for more than 60 seconds, such has someone leaning against the controls or objects hanging in front of the controls.
Solution: Touch OVEN OFF, or turn power OFF at the circuit breakers, wait 3 minutes and then turn it back on. If the condition persists the touchpad/control panel will likely need to be replaced. Turn the power off in order to stop the beeping.
Jan 23, 2011 | Thermador SEC272BPSS Electric Double Oven
What does the "F24" message mean when it flashes on the oven readout?
hello,
simple ,The "F 24 " error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature or liquid substance
what you need to do to fix up your oven is to check on the wiring connection from the power supply to the panel indicator (control button ).
thank you and thanks for using fixya.
Aug 28, 2010 | Thermador Ovens
I have a c302zs with f24 code i changed glass touch problem came back ???????? now what if you can also tell me the part #i have 3 ongoing just like this.my cust. not happy thanx ALL MAKE APPLIANCE
Hi
Thanks for using FixYa.
F24 error is caused when it is a bad touchpad. Heat will cause these buttons to stick sometimes. F24 means a key has been stuck for longer than 120 seconds. The random beeps means a button is opening and closing. When you warm your oven up it expands the buttons and makes it so a button is being held down so you can't push any more to turn it back on. The touchpad is the glass assembly on the front, and I think you’ll have to carry out the repair again and replace it with a new one as the old one might have been faulty. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 07, 2010 | Ovens
I have a Thermadore double wall oven, M# C302ZS. The oven is reading F24. I put in a new whole front touch pad, and it's still reading F24. What can be my problem??
I've copy and pasted an exert from this ovens service manual. try this and let me know of the results.
Good Luck
F-24 or F-25 This is caused by close contact to the control panel for more than 60 seconds,
appears in display window such as someone leaning against the controls or objects hanging in front of
controls.
F followed by 2 digits appears Touch OFF or turn power off at the circuit breaker, wait 3 minutes and turn
in the display window it back on.
Oct 29, 2009 | Toastmaster Ovens
I have a Thermador Model C302ZS
I did too!! My appliance guy told be to but it on the curb - it wasnt worth fixing and we only had it 3 years!!!
Aug 17, 2009 | Thermador C302U Electric Double Oven
F-24 error, beeping after use - Thermador C302US
error code f24 oven shuts down while baking if i open the door and beeps continuously
Jan 24, 2009 | Thermador C302U Electric Double Oven
Thermador SC272T Electric Double Oven Logo
74 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
