Question about Pool & Spa
Spa Quip Err8
We have a spa quip heater which has just been fixed and when we have just connected it back up to the spa we are getting an err8 come up on the touch pad. How do we reset it as we have tried to do this but did not work
An error code will come up if the sensors in the unit detect no water flow, or over temperature. Now this might be the actual problem or the sensors or circuit board may be faulty. First check the pump is circulating the water, if it still errors then the fault is in the electronics.
David. Goulburn Pumps
Posted on Nov 08, 2009
I have spa quip sp1200 hot tub I have no display at contoller I have 240 volt any ideas
check inline fuses then check transformerfor voltage follow schematic to where voltage dies
Apr 18, 2014 | Pool & Spa
Heat pump does not work
can some one help me i have a spa quip sq1500 and my heater light will stay on for say 5 or 10 min but soon as i put jets on again the heater will go off and stay off untill i turn off jets again ????
thanks
Jun 08, 2013 | Pool & Spa
Spa quip hot tub error code 07 stuck relay
Bad relay on the circuit board will require a new circuit board.
Rod
US Parts Center
Apr 17, 2013 | Pool & Spa
Spa has not been on for a year and now heater will not stay on. What's wrong?
Make sure there is water flow thru the heater when it is turned on. If there is low water flow, the heater will shut down.
If there is adequate water flow, then check your pressure sensor and insure it is engaging when there is water flow. If not, replace it.
If these do not resolve your problem, then check your thermostat.
Hope this helps,
Osko Pool n Spa
http://www.oskopoolnspa.com
Apr 10, 2013 | Hydro Quip Inc HEATER ASSEMBLY FOR VERSA...
Older spa spa quip sq1500 need replacemnet control box model 2095bb5 and heater element
thanks
Jan 19, 2013 | Pool & Spa
How do I unlock the control panel on my spa?
Here's a link to a list of ways to unlock the control: http://spapartsshop.blogspot.com/2012/02/spa-control-panel-unlock-codes.html
Those guys should be able to help.
Nov 25, 2012 | Hydro Quip Inc Pool & Spa
Hydroquip heater will not come on & heater indicator light is also out
I would start by checking/replacing the Hi Limit.
When that switch goes bad, it usually shuts down any spa or heater.
Nov 27, 2011 | Hydro Quip Inc HEATER ASSEMBLY FOR VERSA...
Hydro-Quip pack in my Hydro-Spa hot tub no heat.
3 Flashing dots (display) - Water flow problem check for closed valves, dirty filters, water level, pump/wet end operation/defective pressure switch.
If your spa has been off for a while its likely something is blocking the lines.
Flashing dots & Lit light on display - Hi-limit trip, reset power to clear.
Nov 16, 2011 | Hydro Quip Inc Pool & Spa
Hi, my Hydroquip powered spa is running continuously but not heating up to the proper temp. All 3 small lights are blinking continuously. I havn't been able to find any trouble shooting info. Thanks for...
Check for power at the wire terminals. If you have power then you probably have a bad element and will need to replace it. If not your temp sensor has probably gone bad.
Nov 27, 2010 | Hydro Quip Inc HEATER ASSEMBLY FOR VERSA...
Maxi flow spa booster pump, buzzing...then cuts out
hi the capacitor needs replacing in the pump connection box, this needs to be exactly the same uF value as the one you are taking out.
Jun 23, 2009 | Pool & Spa
Pool & Spa Logo
320 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
