Question about Air Con 9,000 Btu Split ditioner Wall Mounted Handler
I have an Air-con air conditioner and heating system
The heating system is not working and the outside unit is building ice around its bottom.
    New Friend:
  • 3 Answers
Check your filter, if it's clean check the condensate drain to be sure it's draining if ok your system has a leak and will need an ac tech to repair and recharge the system
Posted on Jul 13, 2014
I have an Air-con
there is not enough refrigerant on your a/c
Nov 28, 2013 | Carrier 52PQ307 Wall/Window Air...
Outside compressor turned it self on and pipes are covered in ice, without the Inside air con coming on. I have not had the air con running for two days. to turn off the compressor I had to turn it off at...
Hey mate,
Have you cleaned the filters on the indoor unit. Check the evaporator(in door unit) coils for build up and debris. Check the out door unit coil for leaves and debris. IF they all are clear. Could be low on refrigerant, faulty metering device or a blockage in the refrigeration system.
Jan 06, 2013 | Heating & Cooling
My outside toshiba split system is leaking a lot of water
If the unit is on heat mode, the outside unit is the "cold" end... Sometimes if the ambient air temperature is very cold ( Under 5 degrees C), the outdoor unit can start to ice up. If it ices up too much, the air con will automatically go on to a defrost cycle where the outdoor unit will heat up and melt the ice. Water is then drained out the bottom.. its the opposite of what happens in the summer when the indoor unit has water running out of the drain hose. Especially on humid days..
Jul 16, 2011 | Fujitsu Heating & Cooling
It has lots of ice build up around outside unite i would say about 5 inches high around it. Is this normal in winter
Depends on the outside temperature as if the temperature is lower there will not be heat exchange and so frosting can happen.
Feb 08, 2011 | Heating & Cooling
The fan is not turning on my outside air unit but it is still blowing hot air through the vents. There is also ice build up at the bottom of the unit. It is making a humming sound.
You will need to replace the outside fan,or condenser fan motor.
Shut unit down,before the compressor gets damaged.
Without the condensor fan the heat will not be blown to the outside air and the unit will not cool.
You may be low on freon too,have it checked.
Jan 19, 2010 | Samsung AW0603B Air Conditioner
Outside unit iced up how do de-ice
As with the simplest way to thaw ice is with heat.
If you are running this unit in cooling and have ice outside, then you most likely have a freeze up inside as well. If this is a heat pump unit, then frost is normal during operation, however, ice build-up is an indication of a problem.
There are 2 effective ways to remove the ice build-up. The first is the simplest. Get your water hose and hose it down. Be sure to turn off the breakers to the unit and avoid spraying the electrical compartment. If you have the ability to hook the hose into a hot water line, then this process with be extremely fast. Let the unit sit for about 20 minutes to dry out and turn it back on.
The second can be a little more complicated if your not tech savoy. You can turn the system on in the cooling mode. This will make the outdoor coil the condenser section. Then, either block the airflow through the coils with an object, put an object over the fan to increase pressure, or if you can, disconnect the fan so it does not run. This method is essentially the same as a defrost cycle.
As with any failure, you can fix the problem at hand, but it will return. After you get past this, your real challenge will be determining what caused the freeze-up.
If you were running your system in cooling already, then you will need to ensure the system has de-iced on the inside as well.
Jan 12, 2010 | Heating & Cooling
It is about 36 degrees outside and my fan out side has ice around the fan and coils but the heat still works fine . what is causing the ice to form
Ice is forming as the humidity (moisture) in the outside air condenses and freezes on the colder parts of your unit.
Dec 19, 2009 | Ruud UBHC Air Conditioner
Heat pump outside unit not running
It sounds like your defrost board failed. You will need a tech to replace it. With that model it may have a parts warranty but you pay labor(?)
Jan 18, 2009 | Amana PTH123B25AJ Heat Pump Air...
Ice build up out side hitting fan
pop out drain plug heat up pan with heat gun to melt ice
Nov 24, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Air Con 9,000 Btu Split ditioner Wall Mounted Handler Logo
1,280 people viewed this question
Top Air Con Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Air Con Health and Beauty Expert? Answer questions, earn points and help others
