Question about Hobart Champion 10,000 All-in-One 10,000-Watt AC Generator and DC Welder with Robin Engine #500433
Help me find power to my hobart 10,000
I have a Hobart 10,000 welder generator when first started it has currant looses it almost immediately shut it off and restart it currant comes back but leaves again does not trip breakers or resisters
5 Suggested Answers
  • 54 Answers
SOURCE: welder will not power auxillary outlets
sounds like either something is shorted out or the governor is stuck. Check the governor linkage to start with and make sure it is free. Then check the push in breakers for the outlets to see if they are popped. If not the brushes or the armature could be stuck or corroded.
Posted on Jun 15, 2009
  • 225 Answers
SOURCE: Welding breaker keeps popping on my Hobart Champion 10,000.
look for short inside unit,start at breaker and work your way back.
Posted on Jul 05, 2009
stunt driver
  • 5 Answers
SOURCE: I have a Hobart Champion 10,000 welder generator.
measure ouput on ALL available sockets - anything?
Take cover off electric motor-generator, visually inspect windings.
Measure continuity of all stator windings (2 or 3 points usually)
Measure continuity of stator thru brushset.
If all measures ok - has to be AVR module.
There is no mistery in generator - just stator to induce and rotor to obtain voltage.
Posted on Jan 13, 2010
cautionflag1
  • 116 Answers
SOURCE: I have welder Hobart Champion 10,000. I need an
It looks like Hobart made 3 different versions of the 10,000. If you go to their website and enter the model # (and serial #), you can download the exact owners manual with complete parts listing (according to their site). The website is: http://www.hobartwelders.com/service/owners-manuals
The part should be available from them..or with the part number, you can google it and see what is out there in the secondary market.
Hope this helps
Posted on Jul 24, 2010
I have welder Hobart Champion 10,000. I need an electronic board. The welder doesn't send electricity
Hope this helps
Jul 24, 2010 | Hobart Welders 500433 Champion? 10,000...
I have a Hobart Champion 10,000 welder generator. It runs but I am getting no juice out of it. Won't weld or put out power to run anything.
Jan 01, 2010 | Hobart Champion 10,000 All-in-One...
Generator rus fine but does not produce power
check the brushes at the armature,armature should be shiney,if not take emory cloth and clean the armature,see if that helps.
Jul 06, 2009 | Hobart Welders Champion 500433A Factory...
Arc start board
At your nearest Miller distributor (almost all gaz reseller)
Jun 03, 2009 | Hobart Welders Champion 500433A Factory...
Not generating power
The engine is not running the welding transformer. It may be a fuse, drive belt or gear wheel. Or the transformer is shorting out. Check these points in this order if the last one maybe you will have to replace the transformer. The transformer is 2 coils to stop them shorting out where normal electric wire is cover in plastic or rubber the coils are coated with enamel as are sum cooking pans. If this is damaged in any way it will short.
Apr 08, 2009 | Hobart Welders 500433 Champion? 10,000...
Welder will not power auxillary outlets
Mar 28, 2009 | Hobart Welders 500433 Champion? 10,000...
Won't idle down between welding
have you went to your local welding store? Praxair or airgas can call Hobart for the part you request,or they will call their Hobart salesman for you.
Mar 08, 2009 | Hobart Welders Champion 500433A Factory...
Hobart Champion 10,000 All-in-One 10,000-Watt AC Generator and DC Welder with Robin Engine #500433 Logo
26 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Troy
Troy
Level 1 Expert
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
