Question about Cobra 29 LTD CB Radio
Which wire is live on cobra 19x
I have a red wire and a red-black which is earth please
  • 40 Answers
The solid red wire is the battery plus or the hot wire. the red and black is earth or ground wire if the radio has been hooked up backward it may have blown the protection diode.
Posted on May 10, 2009
I have wired a new light fitting into our downstairs toilet however when I came to test it the light worked but half the other downstairs lights are now switched off when the toilet light is swithced off....
Hi
Probably put your family at risk of electricution . By connecting the live cables to earth you have effectivly made all the metal light fittings live. It is amazing that the fuse has not blown, This in itself is dangerous and you should have an electrician look at the wiring.
The correct wiring should be as follows.
Identify cables there should be 2 twin and earth (red black & copper earth) cables and 1 twin red and copper earth. (or 2 single red wires)
connect all copper earth wires suitably sheathed in green/yellow sleeving to earth lug.
Connect 2 black cables to neutral block.
Connect either single red (0r 1 of 2 reds) into live block.
connect remaining 3 reds into loop block.
HTH
Nov 11, 2009 | Kitchen Appliances - Others
I just picked up a Cobra 18 ultra CB Rig at a Farmers Market, and would like to know how to install it in my 2007 GMC Denali?
all you need to do is find a continuous live 12v feed, usually the cigar lighter, join the red wire from the cb, to this feed, and the black wire from the cb is the earth, and fit a mag-mount cb arial
Jul 31, 2009 | Radio Communications
Heath-zenith sl-6107 wiring diagram
hi there the wirings colour codes for nz are as follows
OLD WIRING CODE
Green = Earth
Black = Neutral
Red = Phase Or Live
NEW WIRING CODE
Green/Yellow = Earth
Blue = Neutral
Brown = Phase or Live
============DANGER 230VOLT ===============
Electricity can kill.
You should use an Electrical contractor for this repair job,
Caution always turn off power first before touching any wiring,
The Live wires always carry power,from one point to another,
the black neutral is your return path from the live phase wire
the green wire is always the ground ,
In this example
the sensor will have four wires as follows
Green = Earth Wire
Black = Neutral
Brown = Phase (incoming supply) 24 hrs
Red = Phase Load (outgoing supply) from sensor to lights triggered
Notice there are to phases in the circuit.Brown and Red
Always treat them as LIVE or Active Power.
Brown will normally be the Live incoming power and
Red will be the load side of the sensor,
Check the brochure supplied by manufactuers or their website to confirm the wiring order is correct before commencing any installs or repairs,
Always Safety first.
Safe a live today and you'll remembered forever.
Jul 06, 2009 | Heath Zenith Occupancy Motion Sensor Wall...
Wiring/connecting wire from fan to home ceiling
this depends on where you live UK/USA et,c or other.
It is best to search the manufacturers site, to find installation codes/colours.
i.e USA use a lot Of Black and white. UK uses Red/Black Green/yellow.
And on houses that are rewired to 17th edition electrics ( UK ) the colours have now changed on mains twin and earth household Wiring. What Used to Be Red ( Live ) Is Now Brown. Black ( Nuetral ) Is now Blue. green/yellow is earth.
*** Important Note:- you should have several reds in a ceiling junction box or light fitting, these are circuit wires. ( Live From Light to next light ) The same as with Black ( Nuetral )
There will usually be 1 switch wire/Cable. this feeds a live from the switch, to the live power up to the light. many homes use a twin core and earth, from the light switch to the fitting. this may be black ( if a black/red ) has been used. *** Do not connect a black Switch wire with the remaining neutrals***
This will blow a fuse or trip a breaker.
Your solution:- connect the black neutral To the Black neutral cables ( more Than 1 at the ceiling Rose/fitting ) if there is a green/yellow or green ( this will be earth ) You may have 2 remaining Colours Possibly red and Blue or other. The Red Should be the switched Live. ( the single cable Red/Black with red tape around It ) This will be the switched Live. The remaining cable would probably be connected to the Bunch of Reds ( Constant Live ) As ceiling fans require a constant and switched live ( if the fan has lighting )
If in any doubt, consult a qualified or competant Electrician. *****And always remove or isolate the mains supply before attempting any installation*****. After the wiring is complete replace the fuse or switch on the breaker, to test your installation.
This information, is supplied by a fully competant electrician.
Thankyou for using fixya.
Mike @ Compurepair.
Jun 15, 2009 | Hampton Bay 24002 Ceiling Fan
How to wire in a honeywell 9400c timer clock 4 ch
One of these wires is contains permanent live, neutral and earth. The other wil be heating on and hot water on, the earth on this wire will probably not be used.
you will have to trace the wiring back or test it!! Be carefull!!
Dec 11, 2008 | Heating & Cooling
NG Pajero radio cassette wiring
the green/white wire is the earth - the earth to the chassis gave no resistance when tested with the multimeter to the car chassis. So it was a pretty good bet that the green/white wire was the earth as suspected. The radio cassette works a treat. Yipee!
Apr 18, 2008 | Car Audio & Video
Cobra 29 LTD CB Radio Logo
109 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
