Question about Apple iPod nano
Screen froze saying now playing and saying charging when it isn't
My ipod was on charge on an ipod speaker base, i switched it on and it has froxe on now playing and still shows the charging battery sign but nothing is happening with it and i can't switch it off or do anything with it i've tried pluging it into my lap and trying it abck on the base nothing seems to work please help!!
  • 413 Answers
Do a reset.
Move lock slider to the left.
Hold down the center button down.
Press and hold the ring at MENU.
When the apple logo appears, let both buttons go.
The player should then work properly...
Look Here for help>
http://ipod-reset.com/
Posted on May 09, 2009
When I plug in my Ipod to the inMotion im310 portable speaker the Ipod screen says it is not supported, and it worked this morning.
Check the pins on the speaker and on the plugin on the iPod, that's the problem usually. Also, check if the iPod is truly compatible, even if it worked before it may not be. I have seen car chargers for say a 2G iPhone work for a bit then say incompatible, it happens. Here are the compatible iPods for the iM310:
Plays and charges
iPod mini;
iPod nano 1G, 2G, 3G, 4G;
iPod classic 3G, 4G, 5G, 5.5G, 6G;
iPod touch 1G, 2G
EJ
Apr 10, 2010 | Altec Lansing inMotion iM310 Portable...
My 16gb touch just froxe at the apple sign after i tried restoring it. can someone help me out? i tried holin the buttons but nothing wrks.
Hi,What you need to do is wait for your ipod to die completely, then you need charge it, and it should be back to normal once. let it charge for about 10-15 minutes, then try turning it on, and seeing if it works. Hope this helps, Joe
Feb 18, 2010 | Apple iPod touch
Directions say it charges and syncs. When I
Look at:
http://www.speakerstation.co.uk/ipod-speaker-docks-ct-87.html
Important Note: iPods released since Sept 2008 (e.g. Touch 2nd Gen, 4th Gen iPod Nano and iPod Classic 120 Gigabyte, iPhone 3g and onwards) have an updated dock connector that means older revisions of speaker dock may not be able to charge these newer models of iPod/iPhone. Older docks should play music from these newer models with no problem.
The problem with charging is due to Apple removing support for 12v (firewire) charging on these new models of iPod/iPhone. Only 5v (USB) charging is supported on these new models.
Oct 09, 2009 | Altec Lansing inMotion® iM500 Docking...
Nano 8gb does not charge battery(3th generation)
the ipod of the 4th generation does only charge in USB mode and the Harman & kardon speaker only supports I link charge mode(fire wire 1394) so i bought an awsome sounding machine wich does not charge my ipod nano.
however i must say that i have a solution, when you put the USB cable in the back of the H&K, you can charge the nano with a charging device of an ipod.
greetz leon
May 27, 2009 | Harman Kardon Go + Play Portable Speaker...
Ipod 5th Generation Video froze and is now dead
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Mar 26, 2009 | Apple iPod nano 3rd Generation
Screen says charging but it isn t on the charge
1. press menu and center select button until apple screen comes up.
2. save your music (expod for mac os, not sure about windows, use cnet downloads to find ipod-2-computer)
3. reformat and update firmware/software. you will loose everything on it.
4. start over... =( try putting music on and try again.
Feb 01, 2009 | Apple iPod nano
IPod is not charging when docked.
my 6 generation nano will not play on my i-f2 sonic impact portable docking station, can any one help?
Jan 07, 2009 | Sonic Impact Technologies IF22 Docking...
Itouch charging
Some speaker systems which are only compatible for charging the ipod nanos and classics do not work with the iPod Touch and the iPhone, the internals are slighly different from one another which will not allow that speaker system to charge your iTouch.
To play & Charge your touch, i suggest getting a speaker system that supports the iPod touch platform.
Hope this helps ?!
Oct 28, 2008 | Apple iPod touch
My IPOD is froze up!!!
this procedure normally works for me::
1. Before manually placing the iPod into Disk Mode you should verify
that it has a charge, if not you need to either charge iPod before
continuing or connect it to power. You can either connect it to a
high-powered USB port, or plug the iPod Power Adapter into an
electrical outlet and connect iPod to the power adapter.
2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
3. Press and hold the Menu and Select buttons for at least 6 seconds
until the Apple logo appears.
4. When the Apple logo appears, release the Menu and Select buttons
and immediately press and hold the Select and the Play/Pause buttons
until the Disk Mode screen appears.
5. Disconnect iPod from the power adapter and connect it to your
computer; the screen on the iPod will change and say "Do not
disconnect"
If you are having difficulty putting an iPod model with a Click Wheel
into Disk Mode, set the iPod on a flat surface. Make sure that the
finger pressing the Select button is not touching the Click Wheel.
Also make sure that you are pressing the Play/Pause button toward the
outside of the Click Wheel and not near the center.
Jan 19, 2008 | Apple iPod nano
MY IPOD NANO FROZE!!!!!!!!!
Last night I was trying to play my Ipod but it didnt play. It wouldnt play any song and the timebar didnt move so that also didnt help it to work.
Dec 03, 2007 | Apple iPod mini M9160LL/A MP3 Player
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
