Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Need to know the color code for kenmore range 74232D 5 burner using conversion kit 316542418
I have the conversion kit 3165842418
brnspncr
  • 67 Answers
SOURCE: Nervous about over tightening ... how tight before causing damage
You should contact the supplier of your oven as there may be a gas pressure reduction valve for the oven that requires adjusting. It needs to be done with a gas momoneter so not really any thing you should attempt your self.
Posted on Jun 11, 2009
SOURCE: LP gas conversion oven flame to big
I did all this and the flames are still huge inside the oven...
Posted on Nov 27, 2009
TheMobilian
  • 8220 Answers
SOURCE: I just bought a newer
Remember this: Crank down and flip. You must tighten down all the top and the oven valve orifices and open all the hutters and flip the nut on the regulator. crank down and flip.
Posted on Jan 14, 2010
heatman101
  • 43501 Answers
SOURCE: Kenmore elite dual fuel range - all burners'
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Sep 07, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore range code f1 e2
F1-E2 - UL A/D Error(s) - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Conversion of Kenmore Elite Gas Range 790.7523 from Natural gas to propane.
each burner has a natural gas jet or (orifice) as you pull them out, one atb a time. You should be able to color coordinate them at that point. the jets will be at the end of each gas line right before the burner. and each burner gets one. I haven't seen the model you are referring to. but the ones i have changed out in the past, usually the hole is the same size for all the burners no matter the size of the burners. I hope this helps. good luck with it!
Jun 17, 2015 | Kenmore Kitchen Ranges
I got a GE gas range (model JGBS22) from a co-worker. She had converted it from gas to propane. I just had a plumber hook it up to natural gas but, even with the conversion manual, he couldn't change the...
There should be a set of orifices for each burner as well as the oven and broiler. When the unit was converted to propane, these orifices should have been replaced and the ones for gas put in with the conversion kit installation information. The kit should have been reattached near the pressure regulator.
If the kit was missing the orifices, then, yes, you are missing pieces. Check with your coworker if the conversion kit was missing. If you have the kit, it can be easily done by any appliance installer (or repair person) licensed for handling NG. (At least on our range, the conversion kit installation was straight forward. Every orifice was clearly labeled with the labels different for each burner and for the gas/LP kits (ABCD (NG) vs MNOP (LP)) .) The regulator is the only part that switched for LP or NG without the kit.
As I recall, the only tools we needed for the top burners were a small wrench (10 mm) and a small flat blade screwdriver. Remove one orifice and put in the appropriate replacement. Then adjust the burners so that they didn't blow out when the oven was opened or quickly turned from high to low (for the simmer burner). The oven and broiler took a bit longer. Several screws had to be removed to get at the orifices. Then the air flow had to be adjusted for the incoming gas.
I hope this helps.
(the conversion installation manual was on the counter during installation; I read it while it was open.)
Jan 14, 2011 | GE JGBS22 Gas Kitchen Range
My brand new GE Profile gas range produces a black soothe. All my pots are covered with in black. How do I fix this problem
Hi. Usually when this occurs on a brand new unit the user is using a natural gas configured range on LPG. You may have to get a NG to LPG conversion kit to reconfigure the regulator. On most newer regulators it is a matter of unswcreing the plastic side cap and flipping the inner plunger over. The conversion process is in the installation instructions. Additionally the Bake and Broil burners for the oven will also need adjusted per instructions. There are usually orifices in a package in a NEW range for the conversion of the cook top burner control valves. Then the air gap on the side of each burner gas tube will need to be adjusted by losening the screw on the side of the burner gas tube and adjusting the airflow until you get a nice 2 color blue flame. Tighten the screws after you make the air adjustment.
If you do NOT have the manual please respond with a model number so I can try and find you one.
Thanks for choosing FixYa,
Kelly
Sep 16, 2010 | Kitchen Ranges
I need to find a conversion kit for my kenmore 790 range to switch from propane to natural gas. Where do i find it?
Most Kenmore ranges ship with the NG to LP conversion kit attached to the range. The conversion kit and instructions are in a bag and should be tied to the back near the regulator or behind the storage drawer. The installer who did the conversion was supposed to put the kit back with the original orifices in the bag.
If you do not have the kit, try looking for the manual at http://www.managemyhome.com/mmh/owner_manuals?intcmpMMHxG_HomexServices_Menu and ordering the conversion kit from http://www.searspartsdirect.com/ .
I hope this helps.
Aug 26, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Changing from natural gas to lp.
By getting a gas license! LOL
Remember to tip your waitress! I'll be here all week - Goodnight!
Alright...got it out of my system...here we go:
1. Find out if a conversion kit exists. Answer: Yes it does...in fact it came with it originally. If it had me doing the install, I would have taped the kit to the back of the range.
http://www.fixya.com/support/p106248-kitchenaid_kgsa906pss_gas_kitchen_range/manual-13680/page-7
....and I quote, "IMPORTANT: Your cooktop is factory-set for use with natural gas. If you wish to use L.P. Gas, an L.P. Gas Conversion Kit is included with your new range. Models with the TripleTier Flame Burner will include a TripleTier L.P. Gas Conversion Kit and a kit for standard ranges. See “Installation Instructions” for details on making this conversion.
2. Obtain the kit. This is more difficult than actually doing the conversion. Unless you have a dealer nearby, I'd simply call Kitchenaid directly: (1.800.461.5681) They will either send it to you directly (quite possibly for FREE) or point you in the right direction.
3. The kit will come with instructions, but briefly, here's what you're getting into: The kit will consist of 1-3 orifices. These will reduce the amount of flow going to the burner(s).
Why? Two reasons: a) Propane burns hotter and b) Propane moves quicker than N.G.
You might need: Allan Keys, Screwdrivers, Channel Locks, Adjustable Wrench.
You'll just disassemble the manifold, install the orifice(s), and GO!
Good Luck.
Sep 08, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Kitchen Aid KGCS105GSS08 conversion kit color code propane, I purchased the kit there are seven orifices four with different colors it does not indicate which color is for which BTU
the conversion kit is also a number,check the no.from lowest no to the highest no.the small no is for small burner and the bigger no is for big burner...the other is for other burner.
Jul 04, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
The smoke
It is normal for this to happen the first time. Its just the oils from peoples hands who installed the element. It will go away.
Nov 25, 2007 | Hotpoint RGB790SEHSA Gas Kitchen Range
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
57 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
