Bosch logic xx7/4washer dryer door locked shut used emergency release clicked as if open door looks like it has come slightly loose just on the handle you use to open it
SOURCE: Door locked open
Tool: We cut a piece a wire about 10 inches long from a wire clothes hanger. On one end we bent 1/2 inch of the wire in a 90 degree angle with needle nose pliers. On the other end of wire we put another bend at least three inches.(this end will be your handle end) Process of using homemade tool to release latch: Make sure washing machine is on a wash cycle. Use flash light to locate latch in the locking catch. Insert the small bend of the tool into the locking catch. Then hook onto the latch and pull out --apply a small amount of pressure -- about three lbs of pressure) Then at the same time you are pulling, press in on the door release button (the little white button above the latch hole where you now have the wire inserted). As your are pulling with little pressure on the latch, hold the little white button in and press the start /stop button. You should hear the door lock. Let machine start working. (about ten seconds) Now push start/stop button again and you should hear door lock release. Your lock catch should give away. This worked for us.
Posted on Feb 19, 2007
the dr
  • 447 Answers
SOURCE: help needed indesit washing machine
well it would help to know brand/model#
Posted on Oct 03, 2007
SOURCE: Door locked
Rather than taking the top off the machine and fiddling around to find the catch as guest suggests, I got it to open with some strong string. I took a fairly long piece and threaded it into the groove where the door joins the metal front of the machine, on the catch side of the door. Then pull both ends of the string very hard to the left (you may want to wear gloves to protect your hands). Pull hard and move the string up and down until the door opens. Worked for me.
Posted on Feb 15, 2008
SOURCE: Broken front door
you need to buy a new 'handle'. to open the door for the time being, disconnect power and then use a coat hangar to pull the latch towards you, ie. outwards
Posted on Jun 09, 2008
  • 92 Answers
SOURCE: Suspect door handle is broken on Indesit Washer Dryer WD12x
yes u can open door from the inside,take the top off (take plug out first)put your arm down to near the door latch and you will feel the mechinism there just gently push down or up until the door opens,if water is still in the washer then take drain pipe out of the waste pipe and place a bucket on the floor then put the pipe in that to manualy drain it,hope this helps you,ps you can buy a new door handle from any washing repair shop and they are easy to replace just see how the old one comes off,rgrds,paul
Posted on Jul 07, 2009
Can open my trunk doesn't work with remote or from inside of glove compartment thanks 2005 ssr chevorlet
Rear Compartment Lid
The rear compartment lid can be opened by operating the rear compartment lid release switch, located on the instrument panel, or by using the manual release located on the rear compartment lid. Battery voltage is supplied to the rear compartment lid release relay through the Main Power fuse. The roof and door module (RDM) receives the rear compartment lid release request via the rear compartment lid release switch signal circuit. The RDM grounds the rear compartment lid release relay coil when a release input is received through the instrument panel (I/P) switch. Grounding the coil causes the rear compartment lid release relay to energize, providing power to the rear compartment lid latch assembly through the rear compartment lid release actuator supply voltage circuit.
As an alternate method of operating the rear compartment, an emergency release handle is accessible from within the rear compartment. When the handle is slightly pulled, it will provide a ground for the bed cover release relay which will cause the actuator to operate and open the rear compartment lid. If the handle is pulled further, it will mechanically open the lid, so even if the battery is discharged or there is an electrical concern, the emergency release handle will mechanically open the lid.
Jan 01, 2017 | Cars & Trucks
My washer door will not open its a wd645 model i cant find the lever when i took lid off
Hi.
The door latch is probably broken. Emergency opening can be done accessing the door latch from the inside of the washer assembly.
Before attempting an emergency opening, disconnect power cord and empty water inside the machine through the filter located at the bottom front side of the machine.
After removing water connect back the machine and try opening again.
If that does not work, then the machine must be disassembled. Most models have an emergency cable located on the inside of the door latch. Pulling the cable will release the latch.
The inside of the door latch is reached either from filter housing or from top of the machine. Either the filter (usually held by screws) or the top panel must be removed to access the inside of the lock mechanism.
Power must be kept off while doing maintenance. Due to the safety issues involved the door latch emergency opening and repair must be done by a trained technician.
Regards.
Ginko
Dec 15, 2011 | Hotpoint -Ariston Aquarius WD645 Front...
Door will not open. Have tried emergency lock release on p. 29. Still does not open. Have unplugged for 1 hr. Does not open.
emergency lock as in the release mechanism inside the access door on the lower right corner of the face of the washer? try pushing in on the door with force will doing this
Jan 20, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
We have a full load in the machine and the door handle catch has gone limp and seems to have broken and just swings loose backwards and forwards inside the housing. The emergency pull release chord at the...
The door will open only after the cycle is completed. If so you must try to see if there is any way by which the door link which had broken off could be wrenched with a screw driver to trip the lock.
If not look from the bottom of the washer, use a long handle screw driver to push into the lock where the door lever has broken out.
You must get a good flash light or head light to watch well to see this trap.
If the access is not good enough then remove the obstruction to move off the drum and push into the lock.
you can weld up the broken handle with the link.
Sep 16, 2010 | Washing Machines
Volvo xc90 rear hatch door closed and won't open
Hold the hatch hard closed into its frame whilst pulling on the release handle. The mechanism on most cars consists a grab/release on the door and a simple metal hop at the bottom of the frame. Over time the hoop can become loose and move slightly inwards each time the door is shut. The door seal rubbers push back on the door surround putting a lot of tension against the grab/release mechanism preventing it from releasing. By pressing on the door and compressing the rubber surround you will take the pressure off the release mechanism and allow it to open when you pull on the handle. Once the door hatch is open, loosen the mounting bolts to the metal hoop and move it out about 10mm. Tighten the mounting bolts. Shut the door gently as a trial close and check for security of fit. If very slack, ease the hoop inwards a couple of millimetres. When happy, tighten the mounting bolts securely. draw around the hoop mount with indelible ink so if it moves in future you have early visual warning and can remount it easily
Jul 13, 2010 | 2004 Volvo XC90
Door stuck shut hot point wd420
It happened on our machine. The soloution to this for me was to take the lid off (two screws). Unplugged from mains. I found the connector to the door had vibrated off and was just hanging loose. Plugged it back in and it worked straight away.Door opens as normal.
Don't forget to look in the manual for how to get the door open in an emergency
Apr 04, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
How do you remove the inside paneling to fix a broken door handle?
4-Cylinder Engines
  1. Remove the screw in the door handle trim, slide the handle assembly forward, and out to access the lock rod clip. Release the clip, disconnect the door lock switch and remove the door opener handle assembly.
  2. Carefully pry off the cap(s) in the armrest pocket, then remove the screw(s).
  3. Carefully pry off the cap under the armrest and remove the screw.
  4. Using a suitable trim panel removal tool, unsnap the door panel from the door frame.
  5. Unplug the electrical connectors for the power windows, power mirror and courtesy light.
  6. Carefully lift the door panel up and away from the door frame.
  7. Installation is the reverse of the removal procedure.
V6 Engine
  2. Carefully unsnap the rear of the speaker grill, lift and pull back to release it and remove the grille.
  3. Remove the panel mounting screws located around the perimeter of the speaker.
  4. Remove the cap and screw in the pull pocket of the armrest.
  5. Slide the pocket back slightly to release the front hook, then lift up, detach the electrical connectors and remove the pocket assembly.
  6. Using a suitable trim panel removal tool, unsnap the door panel from the door frame.
  7. Carefully lift the door panel up and away from the door frame slightly and disconnect the speaker connector.
  8. Installation is the reverse of the removal procedure.
Oct 13, 2009 | 1999 Honda Odyssey
Door locked open
Feb 11, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
