Question about Vehicle Parts & Accessories
Autopage alarm My truck has been not starting and i believe it has something to do electronically with the alarm system. It is doing several things that are not rigt nor have I experienced before. Truck powers on and lets me turn it over but will not achieve ignition. Then my running lights stay on with the light switch in the off position and the key out of the ignition. The only way I get the lights to shut off is by disconnecting batteries. I have checked fuses and relays and all seem well. Any ideas?
  • 27 Answers
SOURCE: security light flash no security system on truck
sometimes turning the ignition on 3 times quickly without starting will reset the computer. If the van has power locks and keyless entry then try using only the keyless entry. Sometimes your car wont have a alarm but an anti theft device which will not allow it to start if it goes off or something triggers it.
Posted on Jul 26, 2009
SOURCE: 92 GMC pickup truck can not remove key from
if you are parked against a curb or anything like that, try turning the steering wheel either was and then try pulling the key out
Posted on Jan 01, 2010
  • 11 Answers
SOURCE: The prestige alarm system i have will not let me
WHEN U UNPLUG THE ALARM BRAIN THE TRUCK SHOULD START.CHECK THE STARTER WIRE IN VEHICLE.IF CUT MAYBE NOT A GOOD CONNECTION
Posted on Jul 26, 2010
MNfisherman
  • 11896 Answers
SOURCE: I had my vehicle battery
Do you have an anti-theft system on this vehicle? If so, place key in the ignition, turn it to the ON position for exactly 10 minutes. As soon as the anti-theft light turns off, then immediately try and start the suv with the key.
Posted on Oct 12, 2010
SOURCE: 2000 ford excursion 4x4 7.3l
First thing to do is enter the default code that is listed in your owners manual. This will turn off the anti theft system. If you have turned it off and are still experiencing this problem then you will need to pull the error codes and see what is keeping your theft system activated. It will either be a PATS module or the Powertrain Control Module (PCM) A scan tool should be able to pull the trouble codes from both modules. Usually the dealer scan tool is more updated and able to read all modules. Click on the link below to view the 2000 Ford Excursion owners manual:
http://www.scribd.com/doc/29182853/2000-Ford-Excursion-Owners-Manual
http://www.supermotors.net/clubs/fordexcursions/forums/thid-2436-excursion-keeps-dying.--please-help
Posted on Oct 13, 2010
My youkon alarm goes off every time i unlock the door with the autopage key fob.
Aftermarket alarms have to be configured to bypass the factory alarm system when using it.
I don't mean you have to permanently delete your factory alarm. What I am saying is, when you use your autopage key fob to unlock your doors, it must also send a signal to the disarm wire of your factory system simultaneously. If not, your alarm will go off just like you are experiencing.
May 16, 2017 | GMC Yukon Cars & Trucks
Xt 33 autopage (crank) but no start
could be your car requires a bypass module... or the safety inputs preventing the alarm from starting car are in place... without knowing your make/model that's the best I can do...
If you need further help, reach me via phone at https://www.6ya.com/expert/jonathan_4cd718ed254374ee
Jul 18, 2016 | Autopage Vehicle Parts & Accessories
How do I reserve battery life on my autopage alarm key pad model XT-73LCD
If you put remote in your pocket or your purse make sure it doesn't push on any buttons!
Mar 30, 2014 | C3RS915 SST Remote Car Start Vehicle...
Autopage alarm rf 220
IT IS POSSIBLE THAT THE ALARM HAS FAILED. WHAT YEAR IT THE TRUCK. THE WIRING WILL BE AT THE KNEE BOLSTER. YOU WILL SEE A YELLOW HEAVIER GAGE WIRE THAT IS THE IGNITION WIRE.THE WIRE WILL BE CUT AND SPLICED INTO THE ALARM WIRING . JUST CUT AND SPLICE THE WIRE TOGETHER AND SEE IF IT STARTS. DEPENDING ON THE DETAILS OF THE TRUCK YEAR AND SUCH. WIRE CAN CHANGE COLOUR, POST TRUCK DETAILS AND I CAN POST WIRING DIAGRAM.
Jan 22, 2014 | Vehicle Parts & Accessories
Alarm system wont let start car
What did u do to fix it mine is doing the same thing
Sep 08, 2013 | Autopage Vehicle Parts & Accessories
Autopage xt74 alarm in silent mode
The only reason that your alarm would not chirp when locking and unlocking the doors is that the system is in valet. A visual notification that the alarm is in valet mode is the LED light is on solid. If the LED is on solid and you wish to make the alarm active again, turn the ignition on then, press and hold the valet/programming switch for two seconds. The LED light will turn off.
If the LED light is not on solid then, the issue may be with siren itself.
Sep 25, 2012 | Megatronix - TW71 - 5 Button 2 Way LCD...
My autopage remote wont start
RF425 is an alarm only, it does not start the vehicle.
Aug 23, 2011 | AutoPage RF425 LCD (RF425LCD RF425 LCD)...
My autopage rs 727 lcd is not starting in remote start, it is only cranking
what kind of vehicle? it is most likely a transponder or theft system bypass problem, since it is trying to crank.
Feb 12, 2011 | C3RS727LCD 4Channel Alarm with Remote Car...
I have the normal alarm Autopage AutoPage C3RS603
Nothing is hard to hookup just time consuming andf it all depends on how good you R with wiring how good R you..?
Jul 16, 2010 | C3RS603 2Channel Remote Start Module with...
Vehicle Parts & Accessories Logo
73 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
