Question about Sterling Heating & Cooling
Sterling qv2 gas heater main flame will not come on.
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: I have blue rhino patio heater, the pilot will
If the pilot gets the least bit of dust in the safety will mimmick a low oxygen situation and cause the heater to shut down. The fix is easy. You must blow out the pilot safety device. More HERE
Bonus video demo of ODS safety system
Posted on Dec 31, 2009
SOURCE: Sterling 200,000btu gas heater cycles on and off
Do you have an external Thermostat mounted
nearby? It could be that it is to close to the heater and the thermostat is causing it to short cycle
Posted on Jan 06, 2010
Natural gas shop heater blinks twice. sparks 3x's start full flame and shut off. replaced flame sensor already
These are the check / repair items listed for a 2 flash trouble code: 1. Gas supply off or gas supply
pressure too low.
2. Flame sense rod contaminated
or loose wire.
3. Gas valve switch is off or wires
are not connected.
4. Broken or cracked porcelain on
flame probe or spark ignitor.
Feb 25, 2014 | Sterling RF45 Propane Gas Heater (45,000...
Polit lite burning but furance wont ingite theromsat ok
flame sensor (ex. thermocouple) is not sensing pilot flame so it will not allow main gas valve to open
Nov 24, 2013 | Sterling Heating & Cooling
Sterling RF-45 Pilot light comes on and the burner won't fire. The pilot goes out and fan keeps running.
clean pilot check flame sencor is clean , jump high leval limit first see if it lights , if not try low limit , check thermocouple is tight if fitted ,
Sep 24, 2011 | Sterling RF45 Propane Gas Heater (45,000...
Have Sterling model RF-45-NG, with Honeywell gas regulator SV9500 that will not start. Getting 6 flashes as code. Fans start, ignitor starts.
Clean flame senser first , try jumping out pressure switch , or try jumping out hi leval cut off or low leval cut off , could be air in gas line .
Sep 02, 2011 | Sterling RF45 Propane Gas Heater (45,000...
I have an older sterling gas furnace hung from the garage ceiling that cuts out intermittently . It does not trip the breaker but often if I reset the breaker at the fuse panel box it will start up.
The heater is going into "lockout"... it should be flashing a code on the ignition control that will tell you why it went into the lockout condition...
My guess would be that the high limit switch is bad or going bad and it is cutting out when it shouldn't be... or the flame sensor is loosing contact and cutting the burner off...
You could try to clean off the flame rod with a soft cloth...
heatman101
Jan 18, 2011 | Sterling RF30 Natural Gas Garage Heater
We have yellow flame is that a problem
haven't had much to do with this type of heater but a yello9w falme is usually reducing the oxygen from the gas by the the air mixer on some flame effect fires they cover air holes on burner to get the flames yellow the only problem is they can carbon up from this in a heater you don't look into flames this may be ok but i would check the burner air mixture hole if has one but that smost likely the reason for yellow flame not blue so its probably no problem carbon in heat exchanger will make heat transfer a bit slower so probably best to try and fix
Nov 20, 2010 | Sterling RF45 Propane Gas Heater (45,000...
Jan 05, 2010 | Sterling RF45 Propane Gas Heater (45,000...
Fans and igniter light but not main burner green
Hi clean the flame senser , check out the pressure switch jump it out see if it lights . check you have power to the gas valve
Oct 10, 2009 | Sterling RF75 Natural Gas Heater (75,000...
Sterling rf30 unit heater fan motro cycles on but unit wont fire.
Hi check out the pressure switch jump this out seeif itn lights check flame senser blow heatout with air line hope this helps
Mar 28, 2009 | Sterling RF30 Natural Gas Garage Heater
Heating & Cooling Logo
73 people viewed this question
Top Sterling Heating & Cooling Experts
paulcarew
bobalix
deton8 von Splosion
Are you a Sterling Heating and Cooling Expert? Answer questions, earn points and help others
