Question about Acer Aspire 3000 Notebook
Tuochpad gone! hai, my touchpad on the aspire 6935 is lost, gone... There is no way to make it function again, tried everything.... help please?
  • ries64 May 09, 2009
    Thank you very much, but i did try this several times....! I'm using a Vista 32bit version... reinstalled the drivers, but nothing worked so far.... I send it on monday to Acer Germany with Ups. Tnx for the quick reply!!!
    Sincerly, RH
I hope you got your problem fixed, but if anyone else has this problem, i had this problem, my touchpad was frozen with the mute button and volume lit up. try shutting down your computer, unplug the power cord, and hold down the power button for a full 60 seconds. then put your battery back in and turn it on... this solved my problem. i'm not sure how it solves the problem, but something about clearing the stored static electricity... hope it helps! also, i read from a lot of other people have touchpad problems that they simply had their touchpad disabled, which can be solved by pressing FN and F7
Posted on Sep 29, 2009
  • courtney410 Sep 29, 2009
    *unplug power and remove battery, then hold down power button for 60 seconds
    Guru:
  • 829 Answers
I suppose the drive has corrupted and reinstallation . I am not sure which Operating system you are using . Kindly click the below link for driver download . once downloaded double click and reinstall the driver and restart your Pc . This tip should work if you have not had any phsical damage. Kindly click the below link to download.
http://laptop-driver.blogspot.com/2009/01/acer-aspire-6935-vista-drivers.html
Posted on May 09, 2009
I turned off my touch pad to my acer aspire 5733z and it wont turn bk on
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Sep 16, 2012 | Acer Aspire 5733z-4851
The touchpad doesnt work
Hi integrity078...
Try this solution to your problem
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Please take time to rate me thumbs up
Sep 18, 2011 | Acer Aspire 5100 Notebook
Hi, I have an acer aspire 4810tzg laptop and since i installed a new hard drive the scrolling function on the touchpad doesn't work. Help please
Please check the connection of the touchpad. Re-open your laptop again and double chech the connection. Re-insert the flat cable of the touchpad again for checking.
Oct 15, 2010 | Acer Aspire 6930-6771 Laptop
I'm installing win7 on my old p30 laptop, and everything has worked except the wireless card. It can't install the driver. I found the winXP one from the samsung website, but when I try and install this...
Unfortunately, when upgrading to Windows 7 from XP or older operating systems, sometimes some functionality is lost that was there with the old operating system.
In my case, with an Acer Aspire from the year 2006, I lost the touchpad scrolling buttons. I couldn't get it to work for the life of me. I downloaded the latest drivers from Acer and from the touchpad manufacturer to no avail.
I wish you luck in finding the right driver for your laptop and Windows 7, but something tells me that it will be futile seeing that you already used one from the Samsung site, which is where I would have gone.
Aug 27, 2010 | Samsung P30 Notebook
My screen has gone completely white and yet still
hello,
the screen has gone completely white because there is a problem from the connection linking the screen to the board.
try to adjust the screen to the end and see what will happen.
if it does the same, that means you have to fix the flex of the laptop.
the flex is the part that links the board to the screen.
take care
Jun 07, 2010 | Computers & Internet
Touchpad won't work
Your Aspire has a Fn key down between the ALT and CTRL keys on the left. Push that and the F7 key (pretty sure that is the one). It turns the touchpad on and off.
Hope this helps.
Apr 19, 2009 | Computers & Internet
Touchpad doesn't respond
MY SOLUTION - Hello, I have Compaq Presario V2000 Laptop and at once my touchpad stopped working.
So i rebooted it several times but it still didn't work.
Then i detached the battery from the laptop and let it like that for 5 min. I attached the battery again and the touchpad was working again.
So, try the simplest solutions first before you start messing with complicating solutions.
Good luck !
Nov 11, 2007 | Acer Aspire 5610-4648 Notebook
Trouble with touchpad & dvd functions
you probably need to reinstall the drivers.
Acer Aspire 3000 Notebook Logo
281 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
