Question about Hotpoint Refrigerators
Hotpoint fridge/freezer FF187l, fridge not getting cold
Having left door open while cleaning fridge, fridge doesn't work. have tried 'super cold' and switching off at mains. No good
  • 2920 Answers
SOURCE: fridge left open all night and wont cool but the freezer still works.
time for a new fridge
Posted on Aug 27, 2008
  • 198 Answers
SOURCE: my hotpoint fridge wont get cold the light works
There is probably frost build up in the freezer or the freezer fan motor is not running.
Posted on Feb 28, 2009
SOURCE: Hotpoint fridge problem, warm fride, but freezer working good
Fridge along bottom shelves is much colder than the very top shelf which has milk etc., leading to spoilage. Fridge is at highest setting. In the upper left rear of the fridge compartment, is a cover for what I believe to be a circulatory fan. However, trying to remove this cover is difficult.
It seems that the clip nuts to which the two (2) small capscrews fasten are free wheeling and not allowing me easy access to the motor.
Please advise.
My model no. is HSS221FMD WW
Posted on Aug 09, 2009
  • 24 Answers
SOURCE: icicles in the freezer, fridge not getting cold
YES THAT SOUNDS ABOUT RIGHT THE ICICLES COME FROM THE CONDESATION UNPLUG IT FOR A FEW
Posted on Oct 13, 2009
miket756
  • 2702 Answers
SOURCE: hotpoint ffa90 fridge freezer
this is heat likley to be from the compressor,,,it may have burned it out as it was working its hart out trying to cool your house down all last night? never stood a chance did it?
Posted on Nov 19, 2009
Testimonial: "thanks for your help"
LEFT DOOR OPEN OF FREEZER. CLOSE3D DOOR FOR 24 HRS. nOW LIGHTS FLASHING ON SUPER COOL AND SUPER FREEZE.
You will need to unplug and defrost the fridge for a few hours then replug the power. Leaving the doors open allows moisture to freeze on the evaporator while compressor continues to run confusing the control board
APPLIANCE911
Apr 10, 2016 | Hotpoint Combi FFFL1810G Graphite 297 l...
Hotpoint FZFM171 freezer door left open all night, has defrosted and the 'super freeze' light and alarm light wont stop flashing. How do we fix it?
Turn the power off to the refrigerator and manually defrost the freezer until the freezer bis no longer cold and then replug the power cord
.APPLIANCE 911
Jan 27, 2016 | Hotpoint Refrigerators
Fridge part working freezer not
The fridge is just the end of the freezer evaporator. If the freezer isn't cold inside, check the rear panel. It is probably frozen solid with no air getting through. Switch off, leave doors open for 24 hours and be prepared for lots of water to come out. Clean the condenser and make sure the fan inside is ok. Reset the thermostat to middle of the range and be sure to come back to tell us how you get on.
May 17, 2012 | Hotpoint Refrigerators
My freezer works fine but the fridge does not seem to be working its a hotpoint FF187L
There is a small fan, generally accessed in the freezer. It will be behind a vented panel. Its job is to blow cold air, as needed, to the refrigerator. Usually the problem is the little motor that drives this fan.
If you have a multimeter, you can access the fan and see if it is receiving 115 volts. If it is, and the fan is not spinning, then you need the little motor. If it is not receiving voltage, then you need the thermostat (which is on the fridge side).
Either part is very easy to replace. The panels are generally attached with a couple Phillips screws, and some just have panels that snap on/off. The parts can be found on eBay or many, many online sellers of appliance parts. Also, you probably have local appliance service businesses that sell parts. You will just need the make a model number.
If you don't own a multimeter - I will be so bold as to say you should. Very handy tool. And these days you can get a cheap one (for about $10 or so at Wall-Mart, Lowe's, Home Depot etc). For household needs, you will be checking for AC Voltage. For auto needs, you will check for DC Voltage.
If this has been helpful, please take a sec to rate me. Thanks!
Don
Mar 24, 2012 | Hotpoint Refrigerators
Fridge not cold, freezer working fine
I also a similiar problem with my Hotpoint s/s refrigerator HSS25GFPJWW refrigerator...just called GE said that they don't have a recalled listed on the motherboard for the refrig...but according to people on this site there is!!
May 05, 2010 | Hotpoint HSS25GFP Side by Side...
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Feb 24, 2009 | Hotpoint Freezers
Hotpoint Fridge Freezer FF187e - 3 lights flashing
i have just fixed my fridge freezer by following the instruction from KarenBa and GWoman i have also managed to stop the lights (super cool and super freeze) from flashing by turning the temperature to zero on both fridge and freezer so they turn off then holding both super buttons down for about 15 seconds then turning the temperature back up. hope this helps
Oct 19, 2008 | Hotpoint FFS70 Bottom Freezer Refrigerator
Refrigerators Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
