Question about Midland 1001Z 40-Channels Base CB Radio
Laptop charger pluged in laptop works fine ,
Plug mains charger in laptop works fine , after unpluged it lasts about two minutes and then switches of
Screen only lights up on battery power but no ac adapter/charger tried three ac chargers all do the same thing so its not screen or charger
Hi David
It sounds like a fault to its power transition section circuit. Actually, this circuit is built inside the mother board to your laptop.
Please contact the authorized service center, and describe and show them the problem you do experience now, with your laptop. It can be rectified. Gopakumar Gopalan Google
Feb 28, 2014 | Acer Aspire 7720 Notebook
Booting up issue
Does it do this with the mains charger connected or only on battery power?
The plugging in the mains charger if not already, wait a couple of minutes and then try switching it on.
If the boots up fine you more than likely have a battery problem.
If it still doesn't start then you either have a power supply problem on the laptop itself or your main charger is faulty and not charging the battery.
You can also remove the battery and try booting it with only the mains charger connect.
Please provide the results of these queries
Mar 19, 2012 | Acer eMachines 520-2890 Notebook
The net book does not start at all even with charger pluged in. Even the LED won't light. I replaced the charger but still the same problrm. Thanks, Jamal
unplug the charger, remove the battery, press the power button for at least 1 minute.
plug in the charger, try starting the computer as normal, if nothing happens and it's under guarantee then contact asus (good luck). if not under guarantee, try removing and reinserting the memory. if that doesnt work expect the worst. you might want to take it to your local repair shop.
Apr 02, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
Targus COMPACT laptop charger isn't working
Your battery sounds like its buggered. I would suggest buying a new battery
May 20, 2010 | Lenovo 3000 G530 Notebook
Laptop mouse pad doesnt work if being used on flat surface
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 27, 2009 | HP Compaq nc6320 Notebook
Acer 1690 freezes when plugged into wall adapter
Battery has gone bad. Replace the battery.
Feb 26, 2009 | Acer Aspire 1690 Notebook
Amilo pro v7010 laptop wont switch on
If so, unplug it from the wall charger, remove the battery and wait 5 minutes. Then plug the unit back in, leaving the battery out. Attempt to power up. You may lose what work you hadn't saved from the previous use, but nothing else.
If that doesn't work, it's possible that
A) power socket isn't completely connected to the motherboard anymore, so
B) battery isn't charging properly, or
C) the wall charger has gone bad.
I'd say you're in hibernation tho.
Good luck
Nov 25, 2007 | Fujitsu Siemens AMILO Pro V7010 Notebook
My PC won't run with ac /dc power!
Hello. There is a hardware failure with the laptop not the AC charger. AC chargers have some range of protections of their own. If the power requirements of the laptop are bigger then what the charger can handle, the charger will turn off. Also other parameters can bring the charger offline. In your case, you have a problem with a small chip, the battery charge controller unit, witch regulates the amount of current required to propperly charge the battery. When this thing fails, the charging requirements for the battery are reported rong and the AC charger is forced to give more power then necesary. This results in disconnection of the AC charger ( an internal fail safe of the AC charger) and the laptop to swich back to battery power. When the laptop is turned off, it can charge the battery because the power requirements are low, having all processor, main board, hard disk etc turned off. Therefore the AC charger can handle the load. However you will need to have it checked by a service center as it is a hardware fault. Both AC charger and laptop needs that check. The charge controll circuit needs to be replaced probably. It will be a somewhat expensive repair. Don't buy any other battery untill you have the laptop checked. For more aditional info please post back. PS. Sorry for my bad english, I am from Romania, it is pretty hard for me to explain tehnical stuff in english.
Feb 12, 2007 | Sony VAIO FRV28 Notebook
Midland 1001Z 40-Channels Base CB Radio Logo
23 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
