Question about DeLonghi EC155 Espresso Machine
Coffee weak with no crema
Just bought this machine and used both ground illy and illy pods but the coffee comes out weak and with no crema - anything I'm doing wrong?
5 Suggested Answers
SOURCE: failing delonghi espresso machine ed140
check the filter holes. They might need to be cleaned with a needle.
Posted on Aug 31, 2007
  • 11 Answers
SOURCE: grinds too long coffee still weak
You can adjust the grind, finer will give you stronger coffee. Think water through sand vs. pebbles. There are also settings you can find in your owners manual for adjusting the length and strength of your "pull".
Try Julius Meinl espresso roast, it's dark, rich and sweet. Definitely my favortie.
Posted on Jan 18, 2010
mnwarfield10
  • 452 Answers
SOURCE: spills half of the coffee into the machine .when
you need a part replaced and serviced 07779933829 uk
Posted on Jan 25, 2011
espressonist
  • 1711 Answers
SOURCE: ECAM 23.450: I was accidently
From what we can understand the gound coffee have move in the grinder plates. If this is the case you need to udjust the grinder to more gross coffee. try to vacuum again so you get out some more grounded coffee. Then use some beensand try to make some coffees. The coffee will run fast but this will help to remove all the grounded remains from grinder. After a few coffees you should turn the grinder udjustment back to it original place. Take care tha you turn only one to two step at a time perform a coffee and then you can turn again the grinder to more fine.
You can also remove the whole brew group and wash it well so everything will be as before.
Posted on Jul 26, 2011
I cant get my Gaggia Classic to work with pods
You need to use the single-serving size one-hole basket, not the double, with the diffuser valve seated beneath the basket. Then the Illy ese pod should be inserted with the decal facing up. Finally, and most importantly, when you lock the filter assembly into the machine, you need to close it firmly. Brown water can mean that the basket assembly is not sealed in tight enough.
Sep 07, 2014 | Gaggia Classic Espresso Machine
I have a Gaggia classic and want to use pods. I've got Illy ese pods and the right (one hole pressurised basket) but still get just brown water. Can anyone help please?
I HAVE BEEN USING THE GAGGIA CLASSIC FOR 34 YEARS AND I ALWAYS BELIEVED THIS MACHINE IS BEING DESIGNED FOR SPECIFIC COFFEE QUALITY. THE ILLY ESE PODS ARE NOT FOR THIS MACHINE, TRY LAVAZZA PODS INSTEAD THAT IS SHAPED PERFECTLY WITH GAGGIA FILTER HOLDER FOR PODS.
Weak coffee/water flows too fast
you need to take it to a service center as it is still under warranty they should be able to get it fixed for you
Jan 25, 2014 | Gaggia Baby Espresso Machine
I am using my new silvia with the ese pod adapter with illy pods. When I press the coffee dispense button with a pod in place, coffee begins to come out of the right orifice, then after a few seconds it...
"leaks noisily from what appears to be the contact between the grouphead and portafilter"
* Leaks from top of portafilter and group head are caused by poor sealing at head gasket.
* wipe top lip of portafilter before inserting into group.
* check if group is clear of coffee grounds, paper bits, tissue, dry crud. Use a head cleaning brush (tooth brush works) and wipe group clean (do not use screwdriver to scrape!)
* Make sure when inserting portafilter it is seated properly. (check your manual for procedure) Note the position of the portafilter handle if it's in the right position AFTER you tighten it. Is it far to the left? or stuck and barely hangs on to group?
* Barely hanging on to group? Check if pod is too big. Note; you can't double shot or use 2 pods in a single pod basket! Make two separate shots for a double.
* Handle tightens but slips off group or still leaks when pulling shot? Worn out or missing gasket. Gaskets are made of rubber and can crack, drop out, or pit. You will need to have the gasket replaced. Check with vendor or MFR for service/parts.
* Make sure you have the correct portafilter. Many look the same and may even fit but when making fine adjustments or critical shots they don't work right. Check manual or vendor for confirmation.
* Make sure you have the correct basket. The portafilters may have different baskets or cups that can be inserted. Many have special uses that can affect the pull of a shot. Fewer holes causes slower flow and longer brew time. Many holes gives a weaker shot but smoother less bitter taste. There is a blank basket that has no holes which is used for backflushing and cleaning of the group. Check your manual or vendor for which basket you should be using. Odds are that you have a standard basket ment for ground coffee and not pods. (you can remove the coffee from the pod but it will be messy.) Ask for the optional 'POD' basket insert.
* Finally if everything checks out and your still having leaks then your machine needs service as the group head or valve needs replacement. Call your vendor or MFR direct.
Aloha! ukeboy57 (youtube)
P.S. Looking back at my service with pod conversions, I've found that most if not all pro-machines don't really like the pod adapters. Sure it will work but shots are weak and poor. Pods really like a very tight fit with a very small portafilter basket(chamber) I mean like the size of a soup spoon! They like very slow and very hot water pumped with a vibration type pump to extract all the essence from the paper filtered coffee. Illy is an excellent coffee pod with a very rich aroma and good creme. The best for them (pods) are the dedicated pod machines (won't do ground coffee, only pods). If you must use a pro semi-automatic machine then I would suggest adding a port constrictor to the portafilter output. There may be a third party supplier that has a compatible adapter for your brand. I've come across some of these very extreme tools for the elites coffee affectionato. It restricts the flow at the output thus causing the hot water to brew longer and at a higher pressure to force the hot water and steam into each coffee grain. (think pressure cooker) Some of the better ones are adjustable. But note that these will need daily or cleaning after each use as these restrictors have very tiny holes which clog unless flushed after each use. Good luck 9on your pursuit of the perfect cup!)
Jan 17, 2018 | Rancilio Silvia Espresso Machine
SAECO fully auto Traditional Very little crema
The crema is created by reducing the grinding to more fine so the coffee will run slower around 20 sec. Inside the coffee bean container their is un adjust control and with special tool you can turn it to grind the coffee to more fine.
Jan 03, 2010 | Saeco Royal Professional Espresso Machine
Briel Chamonix es35 New..
Pods are expensive. I buy espresso grind from my favorite local espresso shack and I take regular drip coffee filters and cut small discs from them to put in the bottom of the cup that holds the grounds (moisten first). It works great and keeps the finer grounds from clogging it up.
Feb 21, 2009 | Briel Chamonix ES-35 Espresso Machine
Weak coffee
The simple fact with any espresso making is that to get good coffee you MUST:
  1. Grind your own freshly ground beans - grind matters alot. With a good grinder (a burr grinder, not a spice mill). This probably makes the most difference.
  2. Pack the coffee properly using a solid heavy tamper (not the flimsy things you get with the machines)
  3. Buy good coffee - shop coffee is old and stale. If you have to buy shop coffee get something like Illy - its much better than the others.
  4. Ensure the machine is hot, and also that the portafilter is hot (leave it in there when not in use). Cold machine == sour coffee
  5. Dose the coffee properly.
  6. Adjust the above until the time taken to pull a shot is approx 23 seconds - you may need to 'sacrifice' some coffee to get to this point.
  7. And in my opinion only use a double basket - single baskets are hard to use, don't pack well are weak, and inconsistent. A double basket uses more coffee but you get a way better result, more often.
Sounds like a lot of work, but the difference is huge. I used to use pre-ground coffee from a shop and it was prety bad. As soon as i took it more seriously and invested in the right gear and the right coffee - well i can make coffee at home that is significantly bettter than anything i get in coffee shops and restaraunts.
Sep 20, 2008 | Rancilio Silvia Espresso Machine
Are you tamping the coffee at all?
The ground coffee needs to be compressed, using a tamper, to form a hard puck that the water will then get squeezed through.
This has already happened to the ese pods so needs to be replicated in the portafilter when you place freshly ground coffee into it.
The plastic tampers provided with your machine are not fit for purpose and a metal tamper is highly recommended. The base of the tamper should be 58mm
Mar 30, 2008 | Gaggia Classic Espresso Machine
UNABLE TO GET GOOD CREMA ON TOP OF COFFEE:
It could be. Your grind should determine the amount of time that it takes the shot to pour. Standard is 18 - 30 seconds. I prefer 25. If it only takes 10 sec, your crema will be weak.
Are your beans fresh? Older beans produce less crema. By old, I mean more than a month if properly stored.
What is the temperature of you shots? The water coming out of the head should be about 195 F which makes the shots roughly 170-185. If it's too cold, you'll get worse crema. It's also possible to have mostly steam in contact with the grounds which will give the same results. Both indicate other problems.
Make sure your group head screen isn't clogged. And make sure everything is very clean, especially inside the handle (under the grounds basket - just pop it out with a screwdriver). Good luck!
Dec 16, 2007 | Rancilio Silvia Espresso Machine
Breville 800esxl
A card included in the operating manual indicates that this is normal. The Breville "Dual Wall Crema System" will do this. Visit www.breville.com for more information.
Nov 22, 2007 | Breville Die Cast 800ESXL Espresso Machine
DeLonghi EC155 Espresso Machine Logo
15 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
