Question about Olympus OM-2000 35mm SLR Camera
How to KNOW the light is right 4 an Olympus OM20 Manual camera?
The camera is an 80s Olympus OM20. On the view finder, on a manual setting, I have 3 things lit up at any one time...''Manu'' - (Manual), +- (this doesn't change), and Shutter or aperture readings. I do not know when the light is correct to take a photo, as no ''green light'' or ''go'' indicator is seen. My question is..when do I know the light is right in the viewfinder, on manual settings, to take a good photo?
    Brigadier General:
  • 3,006 Answers
OM-20 was basically a upgraded OM-10 with the manual adapter built in and a number of other refinements.
The viewfinder has LED's to show the shutter speed recommended by the camera's lightmeter for the ISO and aperture selected. It also has an exposure compensation indicator (the +/- symbol) and an indicator for flash ready which doubles up as a post-exposure flash confirmation. There is also the indicator lamp to show manual mode has been selected. OM-10 lacks the manual mode lamp and the +/- indicator.
Like the OM-10, the OM-20 is primarily an aperture priority automatic camera. In this mode you set the ISO film speed, choose which aperture you wish to use (with the ability to use the lens depth of field preview button) and then the camera selects the correct shutter speed. The +/- exposure compensation control allows the user to tell the camera to modify the recommended shutter speed by up to two stops either way.
In manual mode, there is no manual metering. The light meter behaves exactly as it does in aperture priority mode and the viewfinder shows the recommended shutter speed and not the manually selected one. Correct metering is therefore a case of adjusting the aperture first, and then choosing the correct shutter speed indicated in the viewfinder. If the user then decides to select a different shutter speed, then the aperture ring must be adjusted to maintain the correct exposure. For example the aperture is set to f8 and the camera recommends 1/60th of a second. The user decides that a faster shutter speed is required and chooses 1/250th, but the viewfinder remains showing 1/60th. In order to keep the same exposure value the user must open the aperture by two full stops to f4. The camera's light meter will detect the new aperture setting and providing the light on the object is unchanged the viewfinder shutter speed display should now show 1/250th as well to confirm the correct adjustment. Alternatively, the user can choose the shutter speed first by looking at what has been set on the control ring (or by turning the ring to the end of its travel and then counting the clicks from there as all experienced OM users do) and then turning the aperture ring until the shutter speed shown in the viewfinder matches what's been manually set.
It all sounds clumsy and complex but is done far more quickly than I've taken to type this and becomes second nature.
Aperture priority metering is selected on the camera by choosing AUTO on the mode selecter. In this mode the shutter speed ring has no effect and the viewfinder always displays the automatically selected shutter speed.
Posted on Jul 06, 2009
  • alanbraceuk Jan 26, 2011
    Thanks so much for this! I'm new to the world of film photography, and picked up an OM 20 very recently. This post has been fantastically useful to me!
Olympus om 30 manual
The OM-30 has focusing system limitations. Most of the time, you can use the LED in the viewfinder to help you focus an image. If the lens you attach has a maximum aperture of F4 or smaller, (F5.6, etc) you set this switch to F4, then focus the lens manually using the prism gridlines visible in the viewfinder.
In short, just set the F4/F2 switch to whichever is the closest to the maximum aperture of the lens you are using. With an F1.8 lens, for example, you would use the F2 setting. For a lens with a maximum aperture of F3.5, you would use the F4 switch setting.
Aug 19, 2014 | Olympus Om Auto Extension Tube 7 For Om-1...
After using our e-520 for about a year we have a problem. After taking a photo. When looking though the view finder all is black, as is the screen when switching to the lcd. Is it possible the shutter is...
digital cameras do have a "shutter", kind of. IT is electronic, just powers on/of the sensor that captrures the image. Some digital cameras have regular swhutter also, that makes it possible to get real fast shutter speeds for flsh. Take off the lens and look inside, It is possible that the mirror is locked in the up position. Read your owners manual and see if there is a reset button for the camera. Remove the battery, tuen camera on/off switch 2-3 times,replace battery and look again. Try reset switch(if available). My Nikon has a mirror locxk up function available throough its menu. Read your owners manual and see if you have the same. If you can reead menu on LCD, and manual says you have mirror lockup, then try changing settings.
Oct 26, 2010 | Olympus E-520 Digital Camera
No picture on view finder
you need to request to replace your lcd unit to the service center.there's no chance to repair LCD.
Jun 03, 2010 | Olympus FE-280 Digital Camera
Lens cycles in & out upon start up and view finder blurry.
Here's the procedure for a manual reset...remove the card and battery...press all the buttons...insert the card and then the battery...turn on the camera.
Sep 10, 2009 | Olympus FE-340 Digital Camera
Olympus FE-340 camera i turn on the power the lens goes in and out 2 or 3 times and the view is blurry in the view finder. The zoom feature has no effect when pushed to the wide setting and will turn off...
your lens may be damaged...your zoom assignments may need to be realligned if there are no broken parts. If there are broken parts in your lens it may be better to get a new lens
Aug 10, 2009 | Olympus FE-340 Digital Camera
Manual
You can download the PDF format of that manual here: OM20
Feb 11, 2008 | Cameras
Olympus OM-2000 35mm SLR Camera Logo
1,982 people viewed this question
Top Olympus Photography Experts
mbutkus
Level 1 Expert
Bart Pulverman
Are you an Olympus Photography Expert? Answer questions, earn points and help others
