Question about Pitco Frialator 35C Deep Fryer
Pitco Frialator the pilot lite ignites and when I turn on the gas and set the temperature the burner comes on but sometimes it goes out and i have to relight the pilot and do the same process again. I can do this many times and then it will stay on and work normally but I have to lite the pilot every morning as it goes out over night
TheMobilian
  • 8220 Answers
SOURCE: pitco gas frialator reaches temperature
Replace the thermophile
Posted on Dec 15, 2008
97F350diesel
  • 1326 Answers
SOURCE: I have a Pitco 35C+S
With the thermostat on the burners are still getting gas. that's normal. If it lights with the thermostat off you do have a severe problem. (bad gas valve/Tstat). The pilot does occasionaly go out on all no electronic ignition items is normal. Follow the remommended steps for relighting and if it lights fine your ok.
Posted on Aug 15, 2009
kebah
  • 684 Answers
SOURCE: Hi, i am having a problem with a deep fryer. Pitco
Make sure that the gas pressure is standard (as rated on nameplate), thermopile must be clean (no dirt or soot) and the thermostat is good.
Posted on Jun 06, 2011
kebah
  • 684 Answers
SOURCE: 13 year old pitco frialator fryer pilot wont stay
Hi there.
Check and tighten all wiring connections.
Check the hi limit for continuity across the terminals using an ohm meter, if it has no continuity, you have to replace the hi limit.
Regards.
Posted on Aug 28, 2011
miles229
  • 4 Answers
SOURCE: pitco frialator excessive pilot flame
If you didn't figure it out already you lost the orifice on the pilot light. It's a little metal cup with a tiny hole in it that slips over the end of the gas tube in the pilot assembly. The orifice controls the size of the pilot light. Need to get a new one or find the lost part.
Posted on Oct 21, 2012
Burner problem
Hi there!
Check the incoming gas pressure.
Insufficient gas pressure will greatly affect the unit's efficiency.
Regards.
Apr 03, 2012 | Pitco Frialator 35CS Deep Fryer
I light the pilot everything is fine then when i go to turn thermostat on pilot light goes small and burners dont light and when i turn back to pilot the gas ignites and goes out
Sometimes certain models turn off if you touch the thermostat before it lites...
We've seen this happen many times, so you would need to light the fryer first, wait until it's stable before turning your thermostat to desired temperature.
Sep 02, 2011 | Pitco Frialator 35CS Deep Fryer
Lighting pilot light
Pilot assembly is located inside the bottom compartment, between the the two middle burners while the gas valve is located under the burner manifold. Make sure that the gas line where the unit is connected is open. You need to turn the gas valve knob to "Pilot" position and depress it (to allow the gas to flow on pilot) then light the pilot assembly using a lighter with extended nozzle ( burner igniter). Once the flame is present at the pilot assembly, wait for about 15 seconds (allowing thermopile to heat up) the gradually release the gas valve knob. If the pilot flame is stable, turn the gas valve knob to "ON" position and set the thermostat to desired temperature setting. This will ignite the burners and heat up the oil to set temperature. Just remember, do not do this if there is no oil on fry tank.
Feb 18, 2011 | Pitco Frialator 35CS Deep Fryer
I have a 40c+ss pitco fryer.the pilot will go out at random times.Could be 1hr or 24 hrs after it is lit. The gas valve has been change, and the thermalpile has been replaced.
Check if your pilot flame sufficiently heats thermopile during operation and make sure also that it is free of soot or any form of dirt, thermopile generates small amount of electricity to energize pilot and main valve of the gas valve for pilot and main burner operation. This electricity passes through hi limit mechanical contacts. Hi limit on fryers act as safety device which will shut down pilot and burner flame when oil temperature reaches 450F.
If your fryer is set at 350F and over shoots up to 450F (which will trip hi limit and shut down pilot and burner flame), the thermostat is not good, but, if hi limit trips on temperature much lower than 450F, hi limit is bad.
Nov 12, 2010 | Pitco Frialator 40CNG Deep Fryer
I am converting a pitco model 14c fryer from nat gas to propane, and am wondering where does the pilot oriface install at. It looks like a small cap with a hole in the end. Thanks Jim
The pilot light is attached directly to the front of the pot near one of the burners. You will see one small gas line and a set of wires. Loosen the nut where the gas line goes into the pilot light. You will have to hold the pilot light as well as turning the nut on the line. Pull the line from the pilot light assembly. Sometimes the pilot orifice comes out with the line and other times it stays stuck in the pilot light. If it is stuck take a small blade like a pocket knife and pry it out. put the new one in and tight it all back up
Oct 02, 2010 | Pitco Frialator SG14 Deep Fryer
Pitco frialator (propane)
Better check the incoming gas pressure first, it should match the requirement as stated on the nameplate. Low gas pressure will make the pilot flame small until it could not heat up the thermopile which will shut both main burner and pilot flame.
Apr 11, 2010 | Pitco Frialator SG18S Deep Fryer
Hello I have a Pitco Frialator 35CD Deep Fryer and as of one day ago, when I turn the wheel to turn the fire on (the wheel with the various temperatures) nothing happens? How do I fix it?
Assuming that the pilot is lit, when you turn the thermostat from off to the operating temperature, you should hear a click at some point. If you do not, the thermostat is defective. You can also double check this by detaching one of the two wires going to the thermostat and measuring for continuity between the two terminals. At off it should show no continuity. At 200F or above it should show continuity. This is the most common problem.
If the pilot will not stay lit or if it goes out when you increase the thermostat setting, it is usually a defective or weak thermopile (or thermocouple), or a defective gas valve. If replacing the gas valve, I recommend replacing the thermocouple or thermopile at the same time.
Restate your problem if the pilot won't stay lit or if it goes out when you turn the thermostat up.
Feb 11, 2010 | Pitco Frialator 35CD Deep Fryer
Hi, i am having a problem with a deep fryer. Pitco Frialator 35CS. The pilot is liting, but the burner will not lite. Solve this for me. thanks
Jan 19, 2010 | Pitco Frialator 35CS Deep Fryer
Kitchen Appliances - Others Logo
22 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Dan Webster
Dan Webster
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
