Cd rom does not read CDs.
Dear sir(s), My system configuration-intel motherboard 2.4 ghz bandwidth, 80 gb hard disk, samsung cd rom 52 x, Currently installed windows xp sp2 2006, Cd rom repaired after this event but quickly Up/down before than . Cd rom does not read CDs. Your's Beloved Human
  • platinum2008 May 12, 2009
    Thanks for answering dear tech sir, This solution does not solve properly and belong to my problem exactly. And further see to solving the problem itself. But some knowledge i got through this letter.
    Thanks,
    Your's believer.
    Thanks,
    Your's believer.
    Guru:
  • 829 Answers
Hi
The fasted and easiest way to eliminate Windows being the cause of a read problem is to remove the IDE cable from the drive and insert a CD into the drive once the system is powered on again. You should notice some change in the LED of the CD-ROM, at least it should blink for a few seconds. Usually if the LED goes out or turns red it would point towards a faulty drive - which you have already seem to establish.
One last shot to try before dumping the CD-ROM for good is to update the Firmware of the ROM drive - altough a long shot I have seen this work a number of times.
As Insomniac says CD-ROM's are very cheap to purchase these days
Insomniac I am remember when these ROM drives were very expensive - do you remember when the first Burners came out? As slow as a tractor and expensive as a Ferrari
Posted on May 09, 2009
Where is the sound card located in a dell dimension 1100?
The sound is integrated onto the motherboard in this model, it isn't a separate card.
Jan 01, 2011 | Dell Dimension 1100 PC Desktop
I am using Intel845 motherboard and intel 2.4 p4 processor and 1gb ram. Can i install windows vista or windows 7 or microsoft server 2008 , is they supported to my Configuration. Any updates need to meet...
For Windows Vista to work : It requires minimum 2.0 ghz processor, 1 gb RAM and 60-80GB hard disk.
For Windows 7 : It requires minimum processor 3.0 ghz, 1 gb RAM and 60-80 GB hard disk.
Otherwise, your operating system or hardware problem will occur.
Dec 29, 2010 | Microsoft Computers & Internet
I cannot hear sound system play cds and videos
Every CD/DVD-ROM drive has an audio port opened. An audio cable connects to the back side of the CD/DVD-ROM and connects to the motherboard. Most MB's have two four pin audio ports, one slot white in color and a second black in color. As far as the CD/DVD-ROM not reading the disk. Make sure the disk is free from scratches; oils from you're fingers or just plain dust. Open the drawl and blow out the CD-ROM drive or buy a CD cleaner which will clean the internal laser. These days it’s hard to find a CD/DVD ROM drive with a warranty longer than 1 year. Most ppl buy a new one when it fails to read CD's.
Cheers'
Mike
Jun 19, 2010 | Intel Motherboard
Trying to install XP when disk selection comes up it reads, "Unkown disk. There is not disk in this drive". NOt sure what that means.
your drive is not being read,
have you set BIOS to boot from CD ROM,
is your CD ROM working,
is your XP CD working
Do the following
1 go to BIOS and re-set to BOOT from CD ROM
2 use another copy of XP/Win98/Vista etc to verify if CR ROM is reading the CDs else...
if you doubt CD ROM drive has a problem....
3 use a USB external CD ROM, and to do that u need to re-set the BIOS to boot from USB CD ROM
Dec 07, 2009 | IO Magic Corporation GigaBank (I250HD35)...
My system is hanged after few minutes
Well the issue could either be with the bas sectors on hard disk or faulty RAM or a burned capacitor on the motherboard.
The very first thing I would suggest you is to reinstall windows operating system.If the issue persists then run the system with another RAM and observe the performance.
if the issue persists then it could be with the motherboard or the power supply. Manually check the capacitors on the board for any leaking or faulty capcitors.
Let me know if you need any further assistance
Aug 08, 2009 | Intel Motherboard
Motherboard Replacement
I would check Ebay you may be able to find a replacement one for cheap.
Jan 07, 2009 | Gateway MX3560 Notebook
Unable to install RHEL5 in D101GGC
http://www.linux.iastate.edu/rhel5/...READ THIS IT WILL SOLVE THE PROBLEM.RICHARDM69
Nov 07, 2008 | Intel D101GGC Motherboard
Hp invent p dvd940i does not see dvd disk
1. check your system meets the requirements for your device:
• Minimum system requirements: 800 MHz Intel® Pentium® III
processor or equivalent, 1.6 GHz Intel® Pentium® IV processor or
equivalent recommended (Actual drive performance depends on PC
configuration)
• 128 MB RAM (256 MB RAM recommended for video editing)
• 1024 x 768 video resolution with a minimum of 16-bit color required
for DVD authoring and editing
• Video capture: IEEE 1394 interface or analog video capture device
required
• Minimum hard disk space requirements: 1 GB free for included
software installation, 10 GB free for DVD video disc creation (18 GB
free for double layer). Internet connectivity recommended for software
updates
• Operating system compatibility: Microsoft Windows XP/2000
Professional SP4, Windows XP Professional x64 edition, and
Windows Server 2003
2. Have you install the sowftware that came with your device?
3. is your system recognizing the hard drive (go to start>run>type devmgmt.msc and press enter> and look under cd/dvd rom drives... is your device listed? is it showing with a ? unknown device or a ! next to it's name?
a. if the device is not listed chances are you didn't set up the jumper correcly when installing the device or the device may not be powered or there's an issue with the data cable connectd to the device and the motherboard, check your physical setup.
4. check the removable media is in fact compatible with your drive: this is the compatibility list
• Device write media compatibility: CD-R, CD-RW, DVD+R, DVD+R DL,
DVD+RW, DVD-R, DVD-R DL, DVD-RW, LightScribe CD-R,
LightScribe DVD+R, LightScribe DVD-R, 4.7 GB single-sided/9.4 GB
double-sided DVD-RAM (2.6 GB single-sided/5.2 GB double-sided
media not supported)
• Device read media compatibility: DVD-ROM, DVD+R, DVD+R DL,
DVD+RW, DVD-R, DVD-R DL, DVD-RW, DVD-Video, 4.7 GB
single-sided/9.4 GB double-sided DVD-RAM (2.6 GB
single-sided/5.2 GB double-sided media not supported), CD-R,
CD-RW, CD-DA, CD Extra, CD-ROM (Mode 1 - Yellow Book),
CD-ROM/XA & CD-I Ready (Mode 2/Form 2 – Green Book),
Photo-CD (single and multi-session), VCD, CD-Text
data taken from http://h20426.www2.hp.com/product/opticaldevices/sg/en/pdf/dvd940i_dataSheet.pdf
Sep 28, 2008 | HP Computers & Internet
LG DVD WRITER NOT WRITING, ONLY READING.
you currently have a CD writable drive and a DVD readable drive which means you can burn CDs and play DVDs but not burn DVDs
Jul 30, 2008 | Samsung ( TS-H492A/WBEH)...
System is no boot neither with cd-rom nor hard disk
Hi, Based of your post/description and assuming not hardware problem, you may have to set up the priority boot device in the BIOS to CD. This will tell your mb to look for a boot medium from the cd first. This is normally in the Advance Setup/1st Boot Device. Of course soon as installed, you have to boot from the HD next time. Good luck and kind regards.
Aug 14, 2007 | Intel Motherboard
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
