Question about Kitchen Ranges
Adjust oven temp Tappan TGF 357 - Kitchen Ranges
4 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Posted on Aug 15, 2007
yalmer
  • 552 Answers
SOURCE: oven temp off
You either have a plug up in your flame from dirt etc.
or your valve needs to be replaced.
Try turning off the gas and getting to the burner and clean it first.
Posted on Mar 22, 2008
freetek
  • 5568 Answers
SOURCE: tappan gas range 50 deg. too hot
I was unable to find a photo large enough to see if this range has stove-front knobs or electronic controls. If it is equipped with a knob for oven control, pull the knob off and peer into the shaft to see if a slotted adjustement is visible. If so, you will need a small-bladed, long shaft screwdriver to reach and adjust it.
Posted on Jan 12, 2009
Tappan oven model #TGF336AUD oven does not heat
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | Tappan Ovens
My gas oven overheats and burns my baking. With one temperature test it was set at 300 and within thirty minutes the temperature was reaching 400 and leveling off. However, the next test with the oven at...
bad thermostat.....buy new at lowes .....its inside the oven.....usually at the top of oven..looks like copper rod with copper wire ....easy to change...buy at lowes or homedepot
Nov 16, 2009 | Tappan TGF320 Gas Kitchen Range
Just moved to a house that has a old tappan convectionaire oven never worked one of these before how do i adjust the temperture so things dont just brown but cook throughout do i adjust it lower than the...
Sometimes, a good old fashion 'oven thermometer' work great to find the true oven temp. Then if it's off a few degrees, you can turn it up or down to get the right cooking temp you want.
Sep 24, 2009 | Ovens
My tappan oven, model tgf 334wfsa won't turn off, what part needs to be replaced?
Go to the switchbox and turn it off. Leave it off for about 15 minutes. Flip the switch to turn it on and see if that works. That is what we did.
Sep 06, 2009 | Ovens
Tappan gas range 50 deg. too hot
Jan 08, 2009 | Tappan TGF320 Gas Kitchen Range
Need owners manual for Tappan TGF334BCWb oven
Looking for Owner manual for a Tappan Gas Self Cleaning Oven Range - Model No. TGF 365BEWB
Nov 14, 2008 | Tappan TEF242 Electric Kitchen Range
Oven temp off
Mar 22, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan Oven overheats!!
If you have electronic controls, you'll need either the temperature probe (about $60.00) or the clock (about $150.00). You can test the temperature probe from behind the machine. It should read about 1080 ohms at room temperature. if the probe is good, replace the clock.
If you have mechanical oven controls, you need a new thermostat. Is the too high temp consistent? (i.e. runs at 375F +/- 25F?) If so, you can usually adjust the thermostat **** to read closer to the actual temperature.
Feb 08, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan Gas stove
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan TGF336ASD stove Calibration of the oven
does it have a knob in front or is it a panel to operate bake broil ? if it has a oven knob take it off and look in the back of the knob you adjust it there if it is electric if it is gas you need to use a small screw driver in the stem where the knob goes on and turn a little screw in there to ajust temperture turn clockwize to adjust temp up
Aug 13, 2007 | Tappan TGFS_63 Gas Kitchen Range
Kitchen Ranges Logo
21 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
