Question about Husqvarna Husky 145
I need to adjust the sewing speed is going really slow
  • Husqvarna Master
  • 646 Answers
1. Loosen your hand pulley by removing a small screw that is on the outside edge and take your pulley off. The pulley also has to be rotated to unscrew it. Check the belt to insure the belt is aligned and push down to see if it is too tight. The motor can be loosened to adjust for tightness and alignment. If the belt is cracked it should be replaced. Try to also oil all moving parts including the needle bar while you're at it. Also, oil the race that is under the bobbin with one drop of oil. If that doesn't correct the problem you should try another foot control.
Posted on Jun 22, 2014
Brand new singer quantum stylist 9960 speed adjustment doesn't work. Only slow speed. What am I doing wrong?
Make sure there is not a 2-speed selector on your machine. A lot of machines have 2 speeds with the first selection a half speed.
Aug 06, 2017 | Singer Sewing Machines
How do I adjust the speed on my Singer 31K20
ROFLOL in auto mobiles we call it lead footed . not familiar with the term CLAPPERS .perhaps a trip to a repair shop could answer the problem
Sep 14, 2015 | Singer Sewing Machines
My pfaff 1222e is running slow
1. Remove any stuck material from the feed dog, bobbin area including the hook (pointed object under bobbin). Lubricate as you go.
2. Remove top and end of sewing machine to look at the motor and belt. Place pressure on the foot pedal. Still slow?
3. With bolt attached to motor release the pressure on the belt. Now, place pressure on the foot pedal. Did you notice any increase in speed?
4. Apply pressure on the foot pedal and simultaneously adjust the motor. Adjusting means tightening of the belt and making it move in a straight line. (If it doesn't move straight it puts pressure on the motor so it will move slow.) When you have adjusted the motor to the right position the motor will be at it's highest speed.
5. If the pressure foot is the problem it will require a pro to take care of it.
Apr 16, 2015 | PfaFF Sewing Machines
My Janome memory craft model 9000 sewing machine is now sewing at one slow speed. The quality of the stitch is good but too slow what should I look for?
Your speed slide sensor is bad. Your local repair shop can fix it. There is a chance it's the foot pedal. If it's still slow when you sew without your pedal, then it's the sensor.
Feb 25, 2015 | Janome Sewing Machines
How to take govenor off elna sewing machine
There is no governor. Some machines have a slide speed adjust control on the front of the machine. But there is a chance that your machine is just slow. Look up the stats on it. For home machines 1100 stitches per minute is really fast.
Jan 25, 2014 | Elna Sewing Machines
Singer 258
There is no speed adjust, but 1st you must know the source of the slow down. Remove the belt from the motor pulley and run it, if it goes fast try turning the hand wheel if it is stiff the machine needs clean and oil. If it turns freely you motor may be dirty or just slow. If dirty, sometimes you can without the blet attached run it at full speed for 10 to 15 minutes. It should get faster as you run it. If not motor is weak or slow needs replace. Just replacement motor as genuine probably no longer available.
Jan 15, 2010 | Euro-Pro 9105 Computerized Sewing Machine
Can not start at a slow speed with foot pedal need to now how to adjust start speed
THE FOOT PEDLE IS NOTHING BUT A REASTAT. A REASTAT IS A WIRE WRAPPED AROUND A CONDUCTOR THE WINDINGS START OUT FAR APART AND GET CLOSER TOGETHER THE FARTHER YOU PUSH THE PEDLE DOWN . THE FAR APART WIRES ARE THE SLOW SPEED THE CLOSER ONES ARE FASTER SPEED
THESE WIRES WILL WEAR OUT OVER TIME OR CORRODE OVER TIME AND CAUSE THIS PROBLEM. TRY SOME ELECTRICAL CONTACT CLEANER AND SPRAY THE FOOT PEDLE INSIDE ANY WHERE YOU CAN AND LET DRY. MOST CONTACT CLEANERS ARE NONE CONDUCTIVE AND DRY IN MINUTES
Aug 15, 2009 | Consew 206RB
Motor is sluggish, Necchi Model#4795
Set machine to wind the bobbin to check for how fast the machine will run. I believe it will run fast or slow according to how hard you depress the foot control. If it runs fast and slow you have a problem in the machine. Most likely the machine, if turned by hand, is hard to turn and it needs to be professionally serviced. before it is ruined.
sewman7
Dec 29, 2008 | Sewing Machines
Machine running slow then just stopped
Grand Lake Sew and Vac does not repair sewing machines. They send them to a repair place in Alameda. Someone comes to pick up the broken machines every Tuesday. Repairs are not timely and can be pricey,
Jun 22, 2008 | Euro-Pro Shark 80 - 7133
Sews too fast
Have actually solved the problem now. there is an on line page which describes pulling the foot switch apart and adjusting the speed control slider for a BabyLock Evolve machine and this solution worked perfectly for the Imagine despite dire warnings from the importer not to do this. Babylocker
Nov 06, 2006 | Baby Lock Imagine
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
