Question about Goodman Heating & Cooling
Heater won't work
I have a Goodman capf3636c6aa, The heater stopped working and when I look at the window in the bottom door, the red indicator light blinks three times.
Therinnaiguy
  • 1420 Answers
SOURCE: GMP075-3 heater no igniter voltage
Check the venting for a restriction, check the condensate hose for blockage, check the pressure switch and hoses going to it. And make sure the small exhaust fan spins freely.
Posted on Nov 21, 2008
meBNme
  • 334 Answers
SOURCE: i have goodman heater my
What exactly, word for word does the code say?
Posted on Dec 04, 2008
  • 22 Answers
SOURCE: i have a Pentair MiniMax NT 250,000 btu pool heater that fails to
Two reasons.
1. There is air in the gas line. Power down the heater and allow it to try igniting until lockout. If it locks out, repeat the process. Most lines will clear within 4-5 attempts to ignite.
2. A plugged burner orifice. Run a small pipe cleaner in the brass fittings on the burner tray. They may have small webs in them restricting gas flow.
If the unit is a Standard (STD on the plate inside) it has a flame sensor that may also be bad. That sensor is on the end of the single wire that is cloase to the ignitor wire near the burners. Also check for a losse ground wire on the heater.
Posted on Dec 21, 2008
  • 10 Answers
SOURCE: garage door indicator light blinks 5 times
this probably means you have a bad photo eye if you happen to have to doors side by side may be picking up on other sides photo eye just switch sides from left to right, however if the lights are coming on but does not mean that photo eye is not bad it has a small circuit board inside of it...
Posted on Apr 05, 2009
welcomejee
  • 10594 Answers
SOURCE: red blinking light three times pause then three
Make sure that lamp door is fixed securely and pressing lamp door switch as 3 times blinks shows lamp door switch is not On.
Posted on May 13, 2009
Goodman heater red light blinks 5 times is a blower heater, it says is the sennsor flame, i keep changing it but it keeps burning it over and over doesnt work
Interpret five LED flashes to mean your furnace senses a flame without a call for heat. This could be from a gas valve closing slowly or a burner flame lingering
Nov 05, 2011 | Goodman GMS90703BXA Heater
I am working on a Goodman Furnace an I cannot get power to bring on the induction fan. I have a solid red indicator light.
Hello, if you have power to the furnace but no power to the inducer motor terminals, most likey the control board is malfunctioning. However make sure that you have 24 volts at the w and c terminals on the control board to verify that you have a call for heat from the thermostat.
Oct 05, 2011 | Goodman GMS90703BXA Heater
Goodaman furnace MODel #GMP075-3 work well yesterday and today won`t start, what should I do?
look in the little window for flashing light.count the flashes.take front covers off .on cover is a list of what codes mean.
Dec 24, 2010 | Goodman GMS90703BXA Heater
Goodman heater "twinning" problem
Hi inhave been looking for solution for this cannot find one all i can find is web address for goodman www.goodmanfg.com see if this helps , all i can find is reversed polarity but cannot see this as the problem hope this helps
Feb 21, 2010 | Goodman GMS90703BXA Heater
Indication light "RED" on continuously during operation. Unit fires up, heats up and blows hot air. Why is LED "RED" on when unit shuts down?
not knowing wich one is on, this red light could be your power indicator light..
it stays on during any operation,
you should be able to see it through the sight glass
if it were flashing,,,, there would be a problem
Oct 13, 2009 | Goodman GMS90703BXA Heater
Goodman ez 1425 blower works but no heat
It has electronic ignition. no pilot light.. it uses a hot surface ignitor to light the burners. this device gets red hot (just like looking down into your electric toaster). this hot cherry red device lights your burners
Feb 21, 2009 | Goodman GMS90703BXA Heater
Goodman furnace won't ignite. No glow from ignitor.
yes if the ignitor has a very small crack on it it will not work replace it and see if it works but do not touch the end that glows when you put it in as the grease from your finger s will stop it working
Jan 07, 2009 | Goodman GMS90703BXA Heater
Goodman gmp050-03 heater
Either yourself or a Heating specialist will have to replace the gas valve.. Once installed you will plug unit back in which will reset power board and should work fine
Dec 23, 2008 | Goodman GDS80904BNA Open Flame Heater
Goodman heater..no heat
If you look thru a small viewing window, you will notice a small LED light blinking. Count the blinks and then remove the front access panel. On the reverse side you should find a diagnostic chart indicating what could be the issue based on the number of blinks.
Nov 25, 2008 | Goodman GMS90703BXA Heater
AIR or Heat wont come on/ goodman GMP075-3
If there is no blinking light, then the unit is not seeing a call for heat or cool. My guess is a lose or broken wire in the thermostat circuit. Try and putting a jumper across the red and white heat terminals inside the furnace and manually closing the door switch. If you get heat, it's telling you there is a wiring issue. If you get nothing, it's a bad circuit board.
Jun 08, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
12 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
