Question about Epson Office Equipment & Supplies
No power for my Workforce 545/645 series printer
Turned power off to remove jammed paper. After removing paper unable to turn power back by pushing on/off button.
frcs68
  • 1605 Answers
SOURCE: Paper Jam error
try to open the cover and reseat the ink.
the machine is trying tell you there is something stuck inside where the switch or the senser is located. usually right before the heater path. after the paper pickup roller.
Posted on Oct 15, 2008
the kowalski
  • 86 Answers
SOURCE: message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Posted on Jun 02, 2009
pineworks
  • 4041 Answers
SOURCE: I am getting a error 36 code
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 28, 2010
jas247
  • 844 Answers
SOURCE: my epson workforce 610 had paper jam and I had to
Welcome to FixYa.
Open the Automatic Document feeder and look for any paper left inside. If you forcefully removed the paper without opening the feeder, a mechanism could possibly occur in which case, servicing the printer is the best option.
Press OK, YES then OK to clear the jam message.
Note: For Legal Size paper, load up to 10 sheets only. For Letter Size paper, you can load up to 30 sheets. This is to prevent paper jams.
Thank you for using Fixya.
Posted on Jun 25, 2011
michellearak
SOURCE: Epson RX595 says "Error-paper jam" but no paper in printer!!!
I got my printer to work (finally! #$^%$%) by moving the ink carriage back and forth a bit gently and then I sprayed a small amount of WD40 on a lint free small cloth and wiped the silver bar inside with it. I slid the carriage slowly from one side to the left and it seemed to stick less. I thought my printer was broken so I figured it couldn't do any more harm and lo and behold it worked! My printer went back to the normal screen after turning it back on and I am finishing the print job that I never thought would happen. YAY!
Posted on Apr 18, 2012
How to remove paper jammed in epson workforce 500 printer. i dont see the paper in scanner, back feeder and ink cartridge. what shall i do?
Unplug it and open it up until you see the paper. Don't be rough, but use the rollers to help you roll it back out carefully, If any piece is broken off, fish it out... you can't leave any bits in there.
Apr 10, 2015 | Epson WorkForce 500 Series
Paper jam error message
On mine you have to take the duplexer out of the back of the machine to convince it there's no jam. On the 4350 you press 2 buttons on the sides of the duplexer and it slides out. Look at it, scratch your head and then push it back in. Magically the paper jam is cleared.
Apr 05, 2014 | Epson WorkForce WF-3540 All-in-One InkJet...
Workforce 630 paper jam
Epson Workforce 630 has two paper loading areas. One at the bottom and one at the top, back of printer. Make sure you set the printer to correct paper source, or just make sure paper is loaded in both trays to see if it starts taking paper in either one.
Jun 17, 2017 | Office Equipment & Supplies
Message reads:-Paper is jammed in the product. Turn off the product, open the scanner unit, and remove the paper. See documentation.' I have checked for any paper jammed, but finds none. I have even u
Did you try unplugging the power cord and waiting a couple of minutes, then plug back in and see if the printer resets itself. Also try checking all the paths that the paper travels through the machine for any scraps of paper that may have torn off during the jam up. Sometimes a very small scrap will prevent printers from resetting themselves. Also disconnect the printer from the computer before unplugging so the printer doesn't receive any signal from the computer. It may not mean anything.
Dec 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
PAPER JAMS ON EPSON 615
Hi, Disconnect the printer completely from the PC and from power.Reboot the PC.Check through the paper paths for any obstructions and remove any stuck papers manually.Connect printer to power and PC and turn it off and on.Avoid filling feeding tray to capacity.Try printing now. Hope this helps.Thanks!
Dec 26, 2011 | Epson Workforce 615 AllInOne Printer
Epson Workforce 610 had a paper jam. Removed the paper and now it says a printer error has occurred and to power off the unit. After power off and even removal of the power cord. When turning on it...
I had a similar issue. After ordering a new printer and being told by the epson tech that I need to buy a new printer, I attempted once more to fix the printer before giving up on it.
I noticed when starting the printer up, the container that holds the ink cartridges would move all the way to the right, stop, and then the error would occur.
Eventually, I held the cartridge housing up and forward a little when starting the printer. This fixed the problem, as the cartridge housing was able to get past its stuck point and continue on its journey.
Hopefully this helps someone
Oct 13, 2011 | Epson Workforce 610 All-In-One InkJet...
Printer says paper is jammed but cant find any paper to remove
Open all possible doors and panels and look for any kind of debres, even a small piece of paper will register. Verify that all the doors and panels are secure. If this still registers a paper jam, push and hold the power button for several seconds to attempt a reset, unplug the printer and leave it for a few minutes. Remove all paper from the paper tray before starting it up again. This will hopefully reset the printer and stop the paper jam message. After starting the printer, put the paper back in the tray, make sure the ink cartridges are fully seated and try to print a test page.
Let me know if this solved the problem. If not, I will assist you further.
Brian
Jan 30, 2011 | Epson WorkForce 600 All-In-One InkJet...
Clear paper jam
does the printer have a cancel botton if it does push it
Feb 14, 2008 | Lexmark X5150 All-In-One InkJet Printer
43 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
