Question about Troy-Bilt Blower/Vac 31cc, 200 MPH, 405 CFM
Ran gasoline in 2 cycle engine and it will not start now Put 100% gas (no oil mix) in 2 cycle engine. Ran for 3 minutes and stopped, will not start now. Engine not seized but will not start.
  • 246 Answers
Hello:
Remove the Muffler and Look into the Exhaust Port.
If the Piston has Scratches or Gouges, then the Engine is Trashed and will have to be Replaced.
A New Unit is Usually Cheaper than Buying the Replacement Parts.
You can View a Breakdown of this Unit at the Following Site Addy.
http://www.smallenginepartswarehouse.com/parts.asp
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
Does the model k-100 weeded eater require oil&gas mixed fuel or straight gas?
It is a 2 cycle engine, oil and gas, ratio is 50 parts gasoline to one part two cycle oil (I recommend you use synthetic 2 cycle oil).
Jul 12, 2017 | Garden
Backpack gas blower
Monching, You will have to hope there is not too much damage done already from running straight Gas. Empty all straight gas from blowers tank and refill with proper minimum 50:1 gas oil mix. Start blower and run on 1/2 throttle for a few minutes to be sure its going to be OK. If seized, you will have to try and unseize and if lucky it may run if not too much damage internally. You should run a heavier oil to gas mix 32 or 40:1 in an engine that's been seized. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
this is what happens when someone run straight gas in two cycle engine
Fixing seized up echo weed eater
Stihl FS120 Grass Trimmer RAN WITH NO OIL IN GAS Blown Top End
https://www.askmehelpdesk.com/tools-power-equipment/ran-leaf-blower-without-oil-36071.html
Jul 12, 2016 | Craftsman 25cc 2-Cycle Gas Blower/Vac
Oil petrol mixture for Rockwell 26cc weedeater
Two cycle engines run on a mixture of gasoline and oil. Each engine type is designed to run on a specific gas-to-oil mix ratio.
IMPORTANT: Use only oil that is labeled for use in "Two-cycle" or "Two-stroke" engines. Home Depot and other stores now have "premixed fuel" of gas and 2 cycle oil.
To mix two-cycle fuel, start by putting correct amount of oil in gas can. Then slowly add correct amount of gasoline. Do not try to mix gas and oil directly in gas tank of equipment.
IMPORTANT: Do not use any fuel that is over 30 days old. Do not mix more fuel than you are likely to use in a month. Old fuel can gum carburetors and prevent starting. Always use fresh fuel.
The chart below shows correct amount of oil per gallon that each mixing ratio requires. Expect that yours will be between 32 gas to1 oil and 50 to 1. 32:1 and 50:1 are most popular.
Ratio GAS:OIL UNITED STATES OIL per 1 U.S. GALLON Gasoline
(128 oz.)
*INTERNATIONAL OIL per 1 IMPERIAL GALLON Gasoline
(160 oz.)
*INTERNATIONAL OIL per 1 LITER Gasoline
(metric)
32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
Jan 01, 2015 | Weedeater Garden
Honda umk431 trimmer:I accidentally put 50:1 gas, clogged
try replacing the spark plug first. it may have burned on carbon after the two stroke oil
Apr 01, 2010 | Garden
Wht is the gas to oil ratio for a homelite vac
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual":
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline.
Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US).
Do not use automotive lubricant or 2-cycle outboard lubricant.
NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period.
PREMIUM EXACT MIX (50:1)
GasolineLubricant
1 gallon (US) 2.6 oz.
1 Liter 20 cc (20 ml)
1 quart fuel:3/4 ounces of oil = 1 Gallon fuel:3 ounces of oil or slightly less than 43:1. Not what a current manual recommends.
If properly adjusted your blower will operate fine on 50:1 regardless of what the manual reads. HTH
Lou
Jan 31, 2010 | Homelite Leaf Vac Attack
Need to know gas mixture
GasolineLubricant
If properly adjusted your blower will operate fine on 50:1 regardles of what the manual reads. HTH
Lou
Jan 29, 2010 | Homelite Consumer Products Backpack...
Echo gt 2000 wont start
Mix the fuel/oil ratio an ounce of two cycle oil to a quart of gasoline or 4oz of two cycle oil per gallon of gasoline. I don't think that the fuel mix is the problem though. Check the screen at the exhaust port and clean out any carbon build-up found there. I would clean or replace the in-tank fuel filter as well. Anyway, hope this helped and best wishes.
Aug 18, 2009 | Craftsman 25cc Gas Line Trimmer
What is the fuel oil mixture for a homelite gas trimmer model ut20779
Hi a safe fuel mix is 25:1 but most homelites run a mix of 32:1 either one should be ok
Jul 03, 2009 | Garden
I nww=eed to know the fuel mixture for my homelite gas blower
If you ran plain gas in a 2-cycle engine and it seized... you need to buy a new one. 2-cycle engines depend on oil in the gas for lubrication. If you run straight gas, there is no lubrication, the engines overheats and seizes. The end, unfortunately.
May 25, 2009 | Mtd #TB4SC 25CC 4-Cycle Gas Blower
38182 toro snowthrower will not start because i think i did not add oil to gas & ran engine for a while. what did i do? how do i fix? tried to start with holding in electric start button for several...
I USED TO WORK AT A HARDWARE STORE AND A LOT OF PEOPLE ALWAYS HAD TROUBLE WITH 2 CYCLE ANYTHINGS(GAS & OIL MIX).IF IT IS AN ELECTRIC START MAKE A FRESH MIX OF GAS AND OIL TO SPECS BUT USE A LITTLE MORE OIL THAN INSTRUCTED(THIS WILL NOT HURT THE ENGINE).ADD THE GAS AND OIL MIX TO TANK. PUT CHOKE TO FULL, PRIME IT 5 OR 6 TIMES PLUG IN THE ELECTRIC START AND PRESS THE BUTTON AND HOLD IT DOWN 'TIL YOU HEAR THE ENGINE START TO REVOLVE.THIS MAKE TAKE A FEW TIMES BUT IT WORKED FOR ME.YOU HAVE NOTHING TO LOSE BEING THAT THE ENGINE MAYBE SEIZED ANYWAY. GOOD LUCK !!
Feb 23, 2009 | Heavy Machinery
Troy-Bilt Blower/Vac 31cc, 200 MPH, 405 CFM Logo
390 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
