Question about Apex Digital Televison & Video
Stb 236 firmware - Apex Digital Televison & Video
Connecting rca tv model#F20352SF to a tv converter box
  • Connect ANTENNA OUT of STB to antenna terminal on rear of TV OR, for better picture, connect 3-wire cable to color coded L AUDIO, R AUDIO, and video outputs on rear of STB and connect other ends to L AUDIO, R AUDIO, and video inputs on rear of TV.
  • If STB connected to antenna terminal of TV, set CH 3/4 switch on rear to whichever channel is NOT used in your area.
  • Connect antenna to ANTENNA IN of STB
  • Connect STB to power and use STB remote to turn on
  • Turn on TV
  • If STB connected to antenna terminal of TV, use TV remote to select channel 3 (or 4).
  • Use STB remote to select SETUP and perform channel search.
  • Use STB remote to change channels.
Oct 23, 2016 | RCA Televison & Video
Sato cx200 firmware
You can check this link for the software for this printer and see if that is the old software that you're looking for http://www.satoworldwide.com/our_products/software.asp
Oct 22, 2008 | Office Equipment & Supplies
Phone no start
sounds like a "bootloop" caused by a bad flash of firmware or a rom that wasnt compatible. go into recovery and flash the stock rom
http://www.droidvan.com/2012/06/link2sd-on-stock-rom-s5660dxkt8-236.html
Mar 19, 2014 | Nokia C7 (8 GB) Smartphone
After i connect my apex stb 236 i try to upgrade my software to new one and i made mistake with chosen other version. does the reciver have any option of restore default ?
I guess this is not going to help for the one who originally asked the question, but I have recently done the same mistake and managed to recover my device. Hope this is going to help anyone out there.
Prepare a pendrive with a proper firmware version and follow the bullets below at your own risk (although you probably got nothing to lose at this point):
  • Disconnect the device from power supply
  • Use a screwdriver to remove the black lid
  • There are two PCBs lying in there connected to each other by three set of wires.
  • Disconnect the set of wires which is closer to the front panel (one side should disconnect quite easily)
  • Plug in a pendrive with a proper firmware version
  • While those wires are still disconnected, connect the device to power supply and then turn it on
  • It should boot properly and load the firmware from pendrive
  • When firmware loads successfully, turn the device off, unplug the pendrive and close the lid.
  • Congratulations! you have just restored your STB236 !
Dec 19, 2010 | Apex Digital Televison & Video
Can't see or listen to stb when changing input source and go back
Maybe the STB detects that there is nothing "listening" on the other end of HDMI and turns its output off. Does it work again if you turn off+on the STB without touching receiver?
Jan 18, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Cuando prendo el reproductor se apaga y lo prendo y se vuelve a apagar y asi hasta que lo sucecivamente bloqueo
Descarga el firmware de la pàgina de soporte de philips y actualìzalo. Eso deberìa reiniciarlo a los valores de fàbrica. Posiblemente pierdas los datos que tengas en la memoria del reproductor.
Nov 04, 2009 | Philips GOGEAR SA6045 MP3 Player
NECESITO PORFAVOR EL MANUAL DE USO DEL MODELO, NN-ST657W
Si sabía el problema que podría asistirle mejor así que debo conjeturar: Ninguìn calor: maìn magnetrón, fusible soplado, maìn diodo del condensador, abierto o puesto en cortocircuito. Si sopla el triturador es probablemente un maìn magnetrón. si simplemente ninguìn calor es probaby el diodo y el condensador.
May 17, 2009 | Panasonic NN-S954WF Microwave Oven
HDMI crap out
I got the solution. Contact Customer Service, ask for LEVEL II Tech, and ask them for the old firmware. It will take a lot of pressuring, but they will send it to you and then it will work fine!
Feb 02, 2008 | Televison & Video
Televison & Video Logo
44 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
