I have a Bauhn Universal Notebook adapter that doesnt seem to be working - can it be reset
Generally when the adapter is plugged in a red light will show how much power is getting used although for some reason its not working and no red light numbers are on. Can this adapter be reset
bestdarngood
  • 3037 Answers
SOURCE: cant get tv to turn on
what color does the light on the front of the tv show and is it flashing?
Posted on Apr 05, 2008
  • 4 Answers
SOURCE: Acer Aspire 5100 Red Battery Light
Make sure your universal charger is EXACTLY the same voltage as the old charger. I had a dell laptop that someone and had a universal charger on it and the cpu would always run in powersaving mode and the battery wouldn't charge so I bought a dell replacement off of ebay and it fixed it. Just a side not, the battery light would flash red non stop.
Posted on Feb 26, 2009
leecom72
  • 4806 Answers
SOURCE: Doesnt stat up and no light showing charge
Here's one way to determine the problem.
Take the battery out and try to boot on AC power only, if it boots turn it back off, reinsert the battery again and try to boot.
Sometimes you just have to take the battery out and plug it back in again, with others it is the battery and you have to leave then out until a replacement is bought.
If it still won't boot on AC only, remove and reinsert the memory, try to boot the computer and listen for any beeps.
Post back if you need further assistance.
Good luck.
Posted on Aug 03, 2009
  • 3940 Answers
SOURCE: i had the battery not recognized on boot up. then
the Dell AC adapter has a sensing pin so the bios can determine the wattage of the adapter. If the system cannot ID the adapter, the battery charger circuit is disabled. You'll need a functional DELL ac adapter to get the battery to charge
Posted on Sep 26, 2009
Testimonial: "thanks for the prompt response."
pumpkinman
  • 1147 Answers
SOURCE: notebook power button is blinking red when I try
sounds like bad adapter.red blinking light means dead battery.so if charger is bad it will not power the pc or charge it.
Posted on Oct 17, 2009
How can I adapt a universal remote control to use with my Bauhn 1 TB HDD PVR with Twin Tuners - Model No. AS-PVR1000R? Current branded remote displays no infrared light.
Universal remotes have codes for TV's programmed into them, not this kind of equipment. So unless you can get the codes the remote will not work
Mar 31, 2017 | Universal Remote Control Televison & Video
My Laptop doesnt turn on how do i fix this...help!
Already answered today - take battery out and try.
Mar 16, 2015 | HP Compaq 2510p Notebook PC
Audiosonic tv codes
I also need the code for a audiosonic universal remote for a bauhn tv thankyou.
Dec 18, 2013 | Car Audio & Video
Adapter is connected but the doesnt come up to say its plugged in and won't charge, if you move the adapter about and keep it in the same place when it lights up it works but then if you move it it comes...
There must be a problem in the wiring of your adapter.Get it checked by a professional to avoid permanent damage to your laptop and adaptor.And if its not charging the laptop,it means that there is no proper supply from the adaptor to your laptop.
Mar 27, 2011 | HP Pavilion dv5-1138nr Notebook
Laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Power trouble
Try another known good AC adapter. You could try a universal AC adapter (targus/Igo or kensington). Call around to see what computer stores in your area will let you try one before you buy it.
If that doesnt solve it then you will have to take it somewhere to be disassembled and repaired.
Dec 24, 2007 | Toshiba Satellite M45-S355 Notebook
The Aspires should have no issue booting without the battery installed. Have you done a static reset? (i.e. hold the power switch for 20/30 seconds without power or battery in) And the voltage range on the Aspire 5100 should be +19v - +20.5v on the inner part of the connector so it might be worth checking that the power adapter is outputing correctly.
If it works without battery, then it can be checked by testing the voltage between pins 1 and 6 on the battery (the ones either end) and should be 7.5v or above if the battery is charging correctly.
Hope that gives you a starting point, if you've done all those things already then appologies and best of luck with it.
Dec 10, 2007 | Acer Aspire 5100 Notebook
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
