Question about Refrigerators
Model schreiber apm6852 - Refrigerators
2 Suggested Answers
SOURCE: Schreiber APM6852 Hi, I've cleaned my fridge today
Most units use a door switch to turn the light on/off. Its usually located on the edge of the frame so the door closes on it to make/break the circuit. Switch could be bad or disconnected. Also your bulb may be bad, new doesn't not always mean good! Also look at the center contact in the bulb holder you may need to pull it up a bit for it to contact the bulb center pin. DO THAT ONLY WITH THE UNIT UNPLUGGED FROM THE HYDRO!
Posted on Aug 13, 2014
Owners manuel for Radio Shack Pro-2039
Nope... seems that since Radio Shack folded up it's tents almost all of the old links have dried up! And GEE, I had one of these scanners but have no idea where it is now?
A FEW of the exceptions follow...
PROGRAMMING
This Link is for the Pro-2021 BUT your PRO-2039 programming will be much the same!
Radio Shack Realistic Pro 2021 Scanner Programming and Overview
This link may help you too but it's a much more advanced scanner!
RadioShack Pro 2050 Scanner Programming Tutorial Police Scanner
PRO-2039 SPECIFICATIONS RigPix Database RadioShack Realistic Pro 2039 20 7462
GENERAL Type:VHF/UHF receiver/scanner Frequency range:66-88 / 108-174 / 380-512 / 806-960 MHz (Europe) Tuning steps: Mode:AM/FM Channels/memory management:200 regular in 10 banks @ 25 ch/sec
10 monitor Power supply:Mains Current drain/power consumption:Max 13 W @ 230 VAC Antenna impedance/connector:50-75 ohms / ? or built-in telescopic whip Dimensions (W*H*D):190*80*180 mm (7.5*3.12*7.12") Weight:1 Kg (2.2 lbs) Other features: RECEIVER SECTION Receiver system:Double conversion superheterodyne
1st IF: 10.7 MHz
2nd IF: 455 KHz Sensitivity: Selectivity: Image rejection: AF output power/speaker:1 W at ?% distortion / 8 ohms External speaker connector: MISCELLANEOUS Manufactured:China, 199x-199x (Discontinued)
For "PURE AUDIO" there is a MODIFICATION/Link:
http://schreiber.pl/mods.dk/mods.php3-radio=radio_shack&model=pro-2039&selectid=1855.htm
ANTHONY
Dec 21, 2017 | Radio Shack Radio Communications
Schreiber APM6852 Hi, I've cleaned my fridge today and defrosted the back of it, but now the light doesn't work in the fridge, I've changed the bulb, but still nothing! Have a turned the light off...
Aug 13, 2014 | Refrigerators
Schreiber app6302 integrated fridge
Sounds like the door has twisted
a quick fix is to place an object like a soccer ball
on the floor in front of the fridge while the door is still open
Pushing the top of the door slowly try closing it against the ball to twist the door straight
this is a trial and error aproach that does need a bit of force however it does often work and saves the alternative which is dismantling the entire door
Apr 14, 2014 | Refrigerators
Schreiber fridge
I want the fridge glass for schreiber HTI 2121 model APM6514. Where can I get it please
Jan 13, 2014 | Refrigerators
My hygena/schreiber tall intergrated larder fridge has stopped getting very cold. I thought the thermostat had stopped working .As insructed I turned it off waited 30 minutes and turned it back on. I...
Check where the compressor is and right next to the compressor should be a fan .Check to see if fan is running ,if it is then check the final type coil to make sure they are clean .
Sounds like your unit is shutting off on high head pressure
Jun 22, 2017 | Refrigerators
Instruction manual for Schreiber apm6121 fridge
How do you clean drain drawer if fridge is integrated into unit?
Nov 03, 2010 | Refrigerators
Not keeping cool any more. schreiber amp 6325
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
most common problem is a bad start relay on the compressor. in rare cases the compressor may be bad. if you are mechanically inclined you can replace the relay yourself for less than 50 dollars. you will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
thanks,
Mar 22, 2009 | Refrigerators
I have a schreiber fridge freezer. Display is showing H for fridge, freezer is ok. Can anyone help? Thanks Anne
APM6855 Built in fridge freezer If Fridge is not cooling & freezer is ok then try a defrost by switching off for 24 hrs Then switch back on. it should be OK. If this does not work it is probably the door switch faulty , this should switch on the fan when door is closed. The fan is then controlled by thermostat sensor which switches fan off/on when required.
Nov 15, 2008 | Refrigerators
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
