Question about DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker
The infuser is stuck and wont come out. The warning light for the grounds holder stays on even tho the grounds holder is in the machine
The warning light for the coffee ground holder stays on, even tho the holder is in the machine. The infuser is stuck and wont come out.
EwingElect
  • 276 Answers
SOURCE: Delonghi coffee machine making an aweful noise,
Hi. Husband asks: When you first turn the machine on at the power point, does it make a motor sound and then stop, or is the awful noise apparent at that time.
If the awful noise starts as soon as you turn it on, then most likely there is a motor problem which will need to be seen by a Service Center.
To locate information about De'Longhi in your country, refer to http://www.delonghi.com/
Posted on May 24, 2010
Sebin
  • 712 Answers
SOURCE: Hi I have a delonghi
How old is the machine?
Posted on Oct 23, 2010
SOURCE: Instead of depositing nice rounds discs of coffe
I had the same problem about a month ago and contacted customer services because its still in warranty - they suggested it may be the diffuser and sent a new one - which solved the problem. The attached invoice showed it as costing GBP 15.03 (although it was free under warranty).
Posted on Nov 09, 2010
mnwarfield10
  • 452 Answers
SOURCE: spills half of the coffee into the machine .when
you need a part replaced and serviced 07779933829 uk
Posted on Jan 25, 2011
mnwarfield10
  • 452 Answers
SOURCE: Help! The warning light regarding
motor no good may be pcb needs testing...
Posted on Mar 04, 2011
Delonghi magnifica has exclamation
Switch the machine off, AND pull the plug, wait 5 minutes (to be sure) and turn it on. Then turn it off again, now the infuser should return to it's normal position where you can take it out.
If the descale button is still flashing, try descaling again. Was the procedure interupted before? That would be a reason the light keeps flashing.
Bert
Nov 19, 2015 | DeLonghi Coffee Makers & Espresso Machines
Unable to remove infuser, no warning light, reset multiple times, brews coffee fine
You should go to test mode and try moving infuser up and down to position when you can take it out it needs some skill of timing. After that you need to disassemble infuser completely clean it up and lube with special food grade lube. Also there could be a problem with transmission kit that cause this problem.
Mar 22, 2014 | DeLonghi ESAM3300 Magnifica...
When the water is hooked up and turned on it wont stop running
your inlet solonoid is staying open,valve is stuck open or the coil on valve is defective or if machine uses a lvl board the probe or board might be gone.
Sep 02, 2011 | Bunn Infusion ITCB DV Coffee Maker
Yesterday and today the machine did not come on as normal it said press next + change, nyesterday when I did that it said generic alarm, but then worked, today the generic alarm would not go off. the book...
I had the same problem with the infuser stuck at the top and the triangle light staying lit. I fixed it by unplugging it from the wall. I then removed the side panel and the back panel.
Facing the rear move the sprocket that the motor drives. The best way to start it (if it is stuck) is with a flat screen driver on the right side of the motor and push the sprocket towards the front. Once it starts you can either pull the belt from the other side or push it from the right side. It took 10 minutes to get the infuser to completely come down.
After that I pulled it out and cleaned everything. When I put everything back together the light stayed on and the machine would not respond. I did fix it by turning on the machine, pulled the power plug, and when I plugged it back in the system went through its cycle. Everything is fine now.
Jun 25, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
The infuser seems to be stuck to the side and I cant get at the red release button on the right hand side
Put back together, turn on the machine, then turn of the machine with the power button on the machine, then turn of the power point, should be back in place to push in both red buttons, enjoy your working machine and coffee, cant find an answer for my issue
Jan 02, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Took tray and grounds tray out to clean and it won't go back in - it is jamming. Have cleaned inside but still stuck. Tried pulling infuser out but this is stuck as well. Appears that central unit has...
I had this problem last night. The infuser was stuck down too low and the tray wouldn't slide in. I got the solution from FIXYA, and it worked for me.
First make sure machine is off at power, then put just the coffee grounds collector and not the whole tray back into place, gently close the door, and then turn the machine back on. At first I couldn't close the door, but I fgured that the grounds collector was a bit too low, so just put something in there to hold it up while I shut the door. Turn the machine back on at power and HEY PRESTO, it all started up again, and then the infuser moved back into correct position.
Make sure you have a cup handy just incase water starts to rinse out.
Hope this helps
Tania
Sep 10, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Can't remove infuser to clean it
Turning off the power with the button is not enough. Instead, to remove the infuser: unplug the machine, wait a few seconds, plug it in again and turn the machine on. Even though you are technically turning it on, the machine will sense it was not turned off in an ok way, so it will "properly" shut off (and unlock the infuser).
May 06, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Magnifica gives Generic Alarm Message - Infuser stuck
My infuser was stuck in the down position, When I called customer support the told me some easy steps to fix this problem..try calling them
Nov 28, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
