Question about Home
Aquafine sensimatic water softners
Model#ACS20 tank is filled to the top with water.No clue what to do about it
2 Suggested Answers
h2oservices
  • 306 Answers
SOURCE: Aquafine Sensimatic will generate manually but not automatically
I am not familiar with this brand. If it is not regenerating automatically that usually indicates it is not metering the gallons/usage (there should be flow indicator FLASHING on the control board) or the programming was reset to factory specs causing unit to not regenerate often enough and running out of capacity. If you can post a picture of the unit it will help.
RJ
Posted on Nov 25, 2011
Every time the water softner regenerates the tank where I place the salt is overfilling. I've tried to break up any salt bridges and this isn't helping. It seems that the soft water is not getting out...
hi . sounds like the check valve ? float mechanism is stuck or seized. When you open the brine lid you should see a hollow tube in one of the corners. some have a cap on top which helps keeping salt out of the chamber so the fill? shut off valve doesnt get blocked or stuck. . You should be able to see the fill hose on top and reach down and lift the rod up and should go back down on its own. It works like the toilet flush tank valve works. Good luck.
Nov 19, 2017 | Northstar Water Dispensing & Filtration
RJ
Nov 21, 2011 | NRS Fleck 5600 - 64,000 Grain Timer Water...
My top loader whirlpool (3yrs old) appears to be causing stains: after careful monitoring it appears the fabric softener container conitunes to leak/drip/run down the central column - so staining sheets,...
You can try a few differnt things, staining is usually caused by not hot enough water to disolve or hard water issues. A Washer cleaning use one gallon white vingar fill up washer with hot HOT water let sit over night than run washer next day on HOT hot. Second try washing in warm to hot water dluting softner more breaks down better. Also dluting the softner more in the cup will help washing in cold causes alot of these issues, Make sure water heater turned up hot enough, make sure washer has hot water fill?
Aug 23, 2011 | Whirlpool Washing Machines
The water softner is now filling up with water also the is water in the the overflow its sits in
The softener is not drawing brine during the regeneration cycle. The eductor assembly may be plugged or you may have a bad seal internally. It will keep filling the salt tank if the float assembly is not working properly also causing the salt tank to overflow.
RJ
Dec 28, 2010 | Culligan Under Sink Water Filter
Dirty Water in water softner tank
Solar salt is full of sediment and even stones at times. Al that white scum on top is the reaction between the salt and sediments in solar salt. All that sediment gets drawn into valve during brining and causes many problems. That stuff is cra***. Use either Dura cube or Hardi cube salt and you will not have this problem again. It is available from most water treatment dealers
RJ
Dec 29, 2009 | Culligan Sediment Water Filter Heavy Duty
I just had a mouse surface in my holding tank how do I clean that out? do I add bleach and cycle the water softener?
The mouse must have been in one of your product bags...depending on the deterioration of the carcus; you may have already injested some of the decomposing material.
1. Turn off the water supply and remove the top cover
2. Make sure you have rubber glvoes. Drain the holding tank and remove and dispose of the remaining salt tablets/product left in the tank.
3. Yes, clean the tank with a disinfectant (bleach) and rinse thoughly. Be sure to rinse the tank...you don't want high levels of bleach in your supply lines.
4. Fill with new/clean softner tablets and return unit to service.
Nov 02, 2009 | General Electric GE SmartWater Household...
Hi my haier washing machine does not take water into softner compartment of draw but does take in water. would appreciate any help thanks.
Could be faulty fill solonoid valve coil/ has 2 coils one for cold rinse water other for softner. could also be dirty soap tray of course..Good luckl
Oct 24, 2009 | Haier HLF11P 6 cu.ft. top load washer /...
Softner Compartment won't drain
this may be a faulty valve that allows the water to fill the softner compartment.to check the draining capability remove the drawer and take it to a sink make sure it remains level you you sink tap or a cp of water and fill the compartment almost to the top and it should start draining once it starts to drain stop putting water in and watch it. it should finish draining by itself there will be some water left in it but only a small amount. if it does not drain clean it out.
Sep 24, 2009 | Samsung WF337AA Front Load Washer
Washing machine faberic softner try fills with water when in use.
hot water valve inside unit may be faulty ck it to make sure that it is powering up and then make sure it is operating. the cold and hot valve are one unit on most washers so the unit is replaced as one. if its a front loader than there might be a one way ck valve malfunctioning or the unit keeping intoducing water into the unit even though it is at the level it should be at. top loader then the level sensor is jacked and needs replaced.
Jun 12, 2009 | Frigidaire GLTF1670A Front Load Washer
Fabric Softner not leaving dispenser
Run some vinger through it. Fabric Softner leaves a filmy residue that can clog it up.
Jan 11, 2009 | LG DLE5932W Electric Dryer
Home Logo
73 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
