Question about Abit : AL8-V LGA775/945P/FSB1066/ATX Motherboard (MOTAB15)
Abit al8-v 9.0 error code - Abit : AL8-V LGA775/945P/FSB1066/ATX Motherboard (MOTAB15)
Hi I am working on a abit A 17 mother board it was taken apart by my nephew. I think I have every thing back togather, but when I turn it on it beeps and shows code 92,well I think thats what the l e d box...
Hi, you can download a manual here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket 478&pPRODINFO=Manual
The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Here is a list of beep codes:
Basic Beep Codes for ABIT AWARD BIOS Motherboards
  1. No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
  2. One beep - board is working fine
  3. One long beep then machine shuts down - faulty, improperly installed or missing CPU
  4. 1 short(Beep) System booting is normally
  5. 2 short(Beep) CMOS setting error
  6. 1 long - 1 short(Beep) DRAM ERROR
  7. 1 long - 2 short(Beep) Display card or monitor connected error
  8. 1 long - 3 short(Beep) Keyboard Error
  9. 1 long - 9 short(Beep) ROM Error
  10. Long(Beep) continuous DRAM isn't inserted correctly
  11. Short(Beep) continuous POWER supply has a problem
  12. A two-tone siren, generally caused by overheating or out of specification voltages
  13. Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
Sep 07, 2011 | Abit AI7 Motherboard
Wont boot up abit ag8 error code f.o tried
F.O. code points to button reset? This one is beyond me, suggest you see if the reset button is sticking on and causing it not to boot ( try bypassing this and the power switch and fabricate a switch to power the board on)
Jan 01, 2011 | Abit AG8 Motherboard
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
What is the 'EE' Error code on the board mini display?
From ABIT WEB site:
http://www.abit.com.tw/faq/code.html
E0~EF Boot clock initial programs 00->EF Memory damage 1. Clear CMOS 2. Change memory 3. Send to RMA at last
Now, try to clear CMOS and/or change memory RAM.
Oct 18, 2009 | Abit IT7 Motherboard
Hello. I'm portuguese and i have an abit fatality an8 soket 939 and i have a problem with the motherbord. She stop in the error "9.0" " AWARD BIOS TAKE OVER BOOTING JOB". What i have to do? What are my...
This seems to be a common problem with this board. That error could mean any number of things from a loose cable to a fried chip. Flashing bios will not get rid of the problem.
Take a look at this article.
http://techspotlight.today.com/2009/06/03/abit-motherboard-post-code-error-90/
Good luck,
Hank
Jul 29, 2009 | Abit Fatal1ty AN8 SLi Motherboard
Abit beep code error and LED code of 87
Hi had similar problem today, 1 long 4 short beeps - so not exactly the same.
I ended up resetting the CMOS - and this fixed my problem.
Hope that helps!
Jun 06, 2009 | Abit AX8 Motherboard
Have a Abit A17 mother board that posting a 25 or 5D error code
I picked this up from an abit forum, It appears that it is quite common, look here, http://forums.hexus.net/abit-care-hexus/104674-abit-ab9-pro-code-25-error.html
Dec 21, 2008 | Abit A17 Guru Motherboard
Recieving error code FF and pc will not boot/recognise harddrive
the problem it is in harddisk
is that u have ur smp (power supply)
just check the power supply & insert the cable
properly in to the slot of motherboard & check whether the display has come if it comes than boot the xp cd if problem occurs go to nearest shop of computer
Dec 04, 2008 | Abit AV8 Motherboard
Abit A17 motherboard error codes
check your ram and also clean yopur processor case reattach it.
then restart pc.
Mar 31, 2008 | Abit A17 Guru Motherboard
Abit : AL8-V LGA775/945P/FSB1066/ATX Motherboard (MOTAB15) Logo
94 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Rommel Balcita
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
