Question about VIA Vectro VT6212 (A62124) Serial Adapter
Via sata card
How to install the card in server
  • rahulhol Oct 11, 2007
    ho to install via sata card
In control panel not see audio icon and other device icon
I used to own a dell server with windows 2000 pro that ran Realtek audio drivers, and from memory it had a PCI sound card on the motherboard.
May 10, 2012 | Dell POWEREDGE R710 E5520 226G 2P 4GB...
After installing sd-via-1a5e1ir boot up gives -- pxe-2.1 build 083 wpm 2.0 rpl v2.74 110-out of memory space for option roms. rom unable to run due to memory constriants. bus/dev/fcn:...
Give this a try:
Restart the computer and enter the BIOS screen by pressing the F10 key at the first screen.
In Computer Setup, set Advanced > Device Options > NIC PXE Option ROM Download to DISABLE to prevent PXE option ROM for the internal NIC from being downloaded during POST to free more memory for an expansion card's option ROM. Internal PXE option ROM is used for booting from the NIC to a PXE server.
May 03, 2011 | SYBA SD-VIA-1A5E1IR PCI SATA / IDE / USB...
Connect ide or sata drives to a dell poweredge 2600 for additional storage
Yes and No..
The standard machine only allows SCSI, (no IDE or SATA or SAS connectors...
However SCSI drives are not cheap.. so
To overcome the power issue (you will notice there are no 4 pin molex connectors, or sata power connectors). However there is a 4 pin molex socket on the SCSI backplane. You can use one of those molex adaptor cables (one connector to many) to get power, from the molex you can use a 4 pin to SATA power connector.
Next step is to decide the drive you want to use. I personally use SCSI, SATA, SAS and IDE in mine (overkill I know).
Cheapness says use IDE or SATA. You can get a pci IDE/SATA controller card on ebay dirt cheap (PCI cards are compatible with the large PCIX slots), they dont take the entire "socket" up but they work (be carefull here, there is one 5v pci socket on these machines, and 6 pcix sockets, the pcix sockets will accept 3.3v pci cards (look at the notches).
Next you have to mount them, with a bit of jiggery pokery you can feed the IDE/SATA cables past the SCSI backplane into the hot swap bay. (If you dont have any empty caddy's pick them up off ebay), just remember you cant just pull em out like you can with the SCSI's!) - or use one of the 5 1/2 media bays.
Plud the other ends into the appropriate controller card (as installed in the PCI bus).
Load up the OS, install drivers (if needed - these should come with the pci card(s), use the disk manager to initialise/first format the drives etc.
All done.
I have done this myself running a 2600, with 2X U320 72gb SCSI (on Raid) 1 x IDE CD/DVDRW in Media bay, DAT 27 SCSI (channel B) in the second media bay. 2x 146gb SAS on a DELL SAS pcix card (in 2 of the hot swap bays) and an old 160gb IDE HDD (Funilly enough theres a bit towards the back of the two fans on the SCSI backplane that if you press the 3 1/2 drive against seems to fit perfectly in this place and stay there! (I think thats fluke to be honest).
All done :)
Jan 04, 2010 | Dell PowerEdge 2600 Server
Gateway e-9425r was setup to boot via PXE. I want to boot off a raid. Have 2 250gb sata drives in system. Loading raid driver from gateway site on floppy. Windows install and bios don't detect raid or...
Copy RAID driver to mini diskette.
Boot server using Windows Server 2003 CD
The moment you see the blue setup screen press F6
After the setup runs for a little while it will ask you if you have any additional drivers you need to install
Then insert your mini diskette with the RAID driver and respond to prompts to load it.
Windows should no recognize the RAID controller and let you complete the installation.
Aug 10, 2009 | Gateway Computers & Internet
Installing windows xp on an IBM X-3200 machine
power off the server
connect the SATA HD direct to the sata connector on the motherboard.
turn on the server with XP CD and use the drivers on servers DVD companion
download LSI controller driver for XP and Intel chipset from the web and install, once the controller are set power off the server.
put the SATA HD back on the SATA Bays (Server front)
Turn on the server and DONE!!!
May 30, 2009 | IBM SYSTEM X3200 M2 E4600 2.4G 2GB 2MB...
Drive Options with a Dell Poweredge 2600
I would definitively not recommend to remove the backplates, unless you want to ask for serious trouble with your system.
I would install a PCI SATA adapter card (one like these) and connect your SATA drives to it.
May 27, 2009 | Dell PowerEdge 2600 Server
Hard disk no detect in installtion of window server 2003 32 bit oprating system how to install windows server 2003 (32bit) in ibm server x3400
You need to give windows installation the drivers for your Sata-Bus by pressing F6 while the installation load the drivers (like when we want to install on RAID drive). or do the following method follow the links in that page for Slipstreaming VIA Serial ATA drivers and the other link to create a boot CD Creating a bootable Windows CD with Nero.
it's all in the following link: http://weblogs.asp.net/jkey/archive/2005/08/28/423901.aspx
Apr 12, 2009 | IBM x3400 Server
Intel DG31PR Motherboard
Did you get an error message during install of the (system with the SATA 160GB drive)? Make sure the 160GB drive is shown in the bios. Than go to the title, Boot in the bios & make sure the SATA 160GB is listed in the boot order. (Preferred 3rd. boot device)
Please go to the SATA drive's manufactures site & download either their bootable floppy or CD setup software. (It’s free)! Use their software to setup the FAT & cluster size on the drive. You can even set other features that neither the bios or windows can do. Format the 160GB drive with the software as well. The manufacture's software does a better job than windows. If the 160GB drive is a SATA 2.0 leave the jumper on the drive alone. The Desktop Board supports four Serial ATA channels (3.0 GB/s) via ICH7, connecting one device per channel.
Again, please run the manufactures setup software for your SATA 160GB drive. (Disconnect any other drives that may be in the system until windows is installed).
Intel's web site here: http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2839&lang=eng
Good luck ameyaniks!
If I missed something, just let me know.
Mike
Sep 11, 2008 | Intel DG31PR Motherboard
Add SATA hdd to via KM266PRO-8235 MOTHERBOARD
Have checked for driver checked for SATA Adapter. first install driver
Apr 15, 2008 | VIA Jetway V2MDMP MB AMD SKTA/ KM266Pro/...
VIA Vectro VT6212 (A62124) Serial Adapter Logo
42 people viewed this question
Top VIA Computers & Internet Experts
David
David
Abhinandan  Patil
Abhinandan Patil
jason
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
